Question about George Foreman GR30 Indoor Grill
Bottom plate replacment
Need to replace the bottom grill plate. its non stick surface is coming loose. thanks.
  • 1 more comment
  • Anonymous May 07, 2008
    Upper and lower grill surfaces losing non stick coating in one year.
    There is no george foreman customer service available by phone or internet.
    Rick Fields
  • Rebba Jun 17, 2008
    My lower plate is bubbling and coming off. I mainly cook bacon on it. Am I doing something wrong?
  • Anonymous Oct 19, 2008
    the top and bottom surfaces have lost 80 percent of the teflon, I guess I should scrape the rest off and it might be safe to eat food prepared on this grill.
Hi found a solution. george foreman parts @consumer upper plate was 31.70 including shipping. ppow1 good luck
Posted on Feb 25, 2008
  • 1,019 Answers
theres lots of posts here regarding george foreman products.
there does,nt seem to be anywhere to buy replacement parts.
I,d suggest buying a new alternative product, with a more stable background, and reliable service and replacement parts. i.e russel hobbs or tefal et,c.
Mike @ Compurepair.
Posted on Feb 24, 2008
Bella panni sandwitch maker non stick problem
butter the bread .or spray the unit with PAM
Oct 08, 2016 | Kitchen Appliances - Others
Can't find my owner's manual ... how do you take the waffle plates off to convert to a grill?
Not certain if you're still interested in this, but there should be one spring clip on the top and one on the bottom which hold the plates in place.
One is located on the bottom, near the right side of the hinge.
This is the one on the bottom. Sorry about the image quality, but the limitation of 100K means I cannot get a much larger or clearer image.
This is the spring clip which holds in the bottom plate. Note that it is near the hinge in the rear of the unit, right-hand side.
This is the little clip in the front (there is one on the top and the bottom near the handles) which actually holds the front of the plate firm to the unit. This clip does not move, but it is necessary to get the plate under this clip, before securing the back with the spring clip.
I hope this helps. Note that you should be careful not to damage the non-stick surface when you work with the plates.
Jul 25, 2012 | Cuisinart Kitchen Appliances - Others
Nonstick coming off
No, the Teflon Coating is applied when the plates are red hot during manufacture
Jun 19, 2010 | George Foreman GGR62 Grill
Need to restore the non-stick surface on a GE griddle
Put a sheet of wax paper between the two plates for a few minutes while it heats up, then remove. It will transfer the wax to the grill so you'll temporarily restore the non-stick coating.
Oct 17, 2009 | GE Cooktops
Hi Sunlark,
I'm guessing your product is new -- the first couple of times you heat the elements, they're going to cook-off any chemicals that might have been on the plates as part of the manufacturing process. This may include any non-stick chemicals that might be bonded to the surface.
I personally try to avoid non-stick products as I'm leery of the Teflon/fluorine in the product, but I'm told I'm a little paranoid about things like that - - you have to use your own judgement.
If this smell persists after the first several uses, I'd contact the manufacturer's customer service people.
Go to
And click on "George Foreman" (lower-right portion of the page), it redirects you to a secure webpage where you can register.
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using,
Nov 10, 2008 | George Foreman G5 Indoor Grill
Seasoning Waffle Baker and Grill
FIrst, make sure there is some kind of fat or oil in the waffle batter recipe. This is the biggest difference between waffle and pancake batter. Go to Sams or a restaurant supply store and get a spray product like waffle-off. Spray lightly aftter every few waffles. Use lightly as heavy spray can cause build up. If you can't find this product use one of the PAM type sprays for BBQ grills or maybe an olive oil based product. Regular Pam sprays build up faster as they are not really designed for this. Don't try to wash the grids between uses as they need to keep the oil coating. (Like using a cast iron skillet) They will turn a dark brown. Just brush off crumbs or use a damp rag. Make sure the waffles are completely cooked as when not completely cooked they will seperate and be very difficult to remove. They are cooked when the steam stops coming from the sides. This will take 3 - 6 minutes. Don't preheat with the iron open or allow it to stand open for any longer than necessary. (It can overheat)
Apr 13, 2008 | Kitchen Appliances - Others
Non-Stick Surface is coming off
I do believe that you can contact the distributor in your area, or you can contact the manufacturer directly in Europe that will forward you to the nearest part supplier, do not forget to tell them where you live (city is enought) you have their contact in their webpage .
Jan 22, 2008 | Flama G1600 Indoor Grill
Non-stick surface damage
Contact these guys and they should be able to supply replacement grill plates cheaply; In general the current view is that low quality aluminium alloys, when used for cooking can put enough aluminium into the food over a long period of time to POSSIBLY influence certain conditions such as alzheimers disease, amongst others. There is a certain amount of aluminium in many things we eat or drink, regardless of what it is cooked in. If you use the grill every day then i would recommend replacing the plates, especially if the aluminium itself is becoming pitted, however I have used similar, lower quality grills before with coating worn and haven't gone mad yet. If in any doubt then replace the plates, but i think you are being over cautious here. If you find that food is now sticking to the grill, try grilling half a handful of salt with a little vegetable oil for 10 minutes or so, spread over the whole plate - a certain amount of "non-stick" can be achieved like this, although if cleaning the plates with detergent, this will soon need doing again. Hope this helps :)
Feb 13, 2007 | George Foreman GR14BWC Indoor Grill
George Foreman GR30 Indoor Grill Logo
473 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
