I have a Kodak c530. The battery door is broken. Company will send new door free with $15.00 handling fee. Can you guide me when i am replacing it? The part will not come with instructions. thank you.
Comments:
Jan 09, 2008
- THANK YOU VERY MUCH FOR WHAT SEEMS LIKE A SIMLE SOLUTION TO THE PROBLEM. I BELIEVE MY HUSBAND HAS A CROSS POINT JEWELER'S SCREWDRIVER. NOW I CAN ENJOY MY CHEAP BUT NICE DIGITAL CAMERA AGAIN. SHERYL YOFFE
Jan 09, 2008
- I AM GLAD YOU CONTINUED YOUR INFO. IT LOOKS LIKE ONE COULD JUST SOMEHOW GET THE PIN OUT AS ON A WATCH BAND WITHOUT TAKING THE WHOLE CAMERA APART. BUT NOW I UNDERSTAND THAT IS NOT AN OPTION. ANY OTHER TIPS? SY
Yes, While I have not had that model in my hands, I just started working on a C330. It looks very similar and it is not hard to replace the battery door. You will need a small cross point screw driver. One of the Dollar type stores or Odd Lots type place will have those cheap sets of 6 'jewler' screwdrivers.
Comments:
Jan 09, 2008
- You are welcome. The C330 I took apart had 6 screws holding the covers together. The back cover comes off in one piece, start at the bottom to separate them. The top section has clips to hold the two covers together. push on the back cover edge to undo the clips. The battery door has a pin to hold it in place. There is a small spring on the pin that will be loose.
I have the 530, You have to remove the 6 screws holding the covers together. The back cover comes off in one piece, you also have to remove the front cover too (which is held with 2 inner screws, you better use a magnitized screwdriver) please use caution not to disturb the inner board and parts.
Then use a thumb tack to push the holding pin completely thru(watch the spring so not to lose it) remove old door replace with new door, remember to replace the spring before pushing the pin and door back in place.....
Good luck, this can be frustrating if you dont have the right tools, and patience!
Was this helpful?
Yes
No
Popular Solutions for Kodak EasyShare C315 / C530 /
i have a kodak easy share c530.ihave inserted a new memory card and it keeps say Memory card...
(More)
i have a kodak easy share c530.ihave inserted a new memory card and it keeps say Memory card requiers formatting,ipresse continue to start the formatting but it keeps giving the same message how do iformat thecard please send message about troubleshooting to my email address
venkanna.hari@gmail.com
the camara won't charge in the dock printer stati. the light comes on green when i put the camara a...
(More)
the camara won't charge in the dock printer stati. the light comes on green when i put the camara a couple of hours latter is blinking red. tried the discharging/charging setting but it goes after some time to the green light and the back to red.
