Question about Minolta Maxxum 400si 35mm SLR Camera
How much dos this camera cost$$$ new - Minolta Maxxum 400si 35mm SLR Camera
  • Obertelli
    Obertelli May 11, 2010
    This question is meaningless. The camera has been out of production for a long time and is not available new; the manufacturer no longer exists having first merged to become Konica Minolta and then swallowed by Sony.
  • 685 Answers
That is many years old and not available new.
Posted on Nov 24, 2009
Dos not work with Windows 7
LOOK IN COMPUTER, IT SHOULD SHOW YOUR CAMARA THERE
Sep 05, 2012 | Samsung Digimax D53 Digital Camera
When my camera fall down the lens did not wanted to "turn off" , and my father tried with a "push" and now in a studio the guy that opened the camera said , that 2 parts in the lens are...
Yes he is ture. That broken part are called LENS GUIDE PIN. You can not repair it. Batter Buy a new camera because Lens cost near about a new camera cost. Thanks.
Feb 01, 2011 | Canon PowerShot SD870 IS Digital Camera
My camara dos not turn on it trays but a green light comes on then it makes a sound n turns off
this is a lens faulty problem.. unfortunately this is a faulty that you cant fix alone why it is very very probably that you must change the entire lens block of you camera. so you must look the value of your camera and see if the cost is not higher as buy a new one. sorry that i cant help you here better.
Oct 10, 2010 | Samsung DualView TL205 Digital Camera
What is the latest MS DOS version. is DOS 6 still good as promise?
Yes, MS DOS will still work on "new" motherboards & new CPUs, but *WHY* would you want to use it?
Sep 29, 2010 | Microsoft MS-DOS 6.2 Step-up Files
The lens of my camera dos not open
Well lens errors are very common in these digital cameras. Usually it's sand or grit interfering with the lens extension mechanism.
Follow the below steps to do a try to correct it -
1. Remove the batteries from the camera, wait a few minutes. Put a fresh (or new) set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2.  Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
3. Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots. If further you have the same problem it means there is a gear-motor alignment of the lens which moves in and out with the help of motor. This part is replaceable at an authorized Sanyo Service Center. Aprox repair cost is $120.
Good Luck!!
Thanks for using FixYa!!
Jul 07, 2010 | Sony Cyber-Shot DSC-P52 Digital Camera
My Samsung i7 has a cracked screen and now the touch screen does not work. Can this be fixed and what is the cost
The LCD touchscreen costs roughly around 60-70% of the cost of the camera+ service well...you may as well get a new camera for that cost. The best thing you can do in this case would be to sell it online on ebay or the like and get a new one. Atleast you will get some cash to get a new camera.
Dec 02, 2009 | Samsung i7 Digital Camera
Everytime I turn on my camera it says : Turn the power off and on again. It flashed the error E or F 91:01.
It sounds like you have a FLASH FAIL error message on a Sony Cybershot.
This solution was provided by acem77 at agorarequestdotcom:
1st I ordered the service manual from http://servicemanuals.net/index.html
2nd I downloaded a RM95 emulator program. this program actslike/replaces the remote commander sony techs use to change settings.
http://stanza.techfocus.net/camera/rm95.zip in side the zip is the RM95EMUL.EXE and RM95DUMP.EXE
3rd I made the LanC Interface Cable on this web site http://www.hardwareanalysis.com/action/printarticle/1464
the steps above save you $200 in service tools. The cable parts cost about $12 the manual cost about $30.
I can sell you a cd copy cheaper if you have the same camera.
when you are ready plug the cable you made into the (ext flash) or (lanC) port on the sony camera.
Put your camera in play mode and turn it on. Then start the RM95DUMP.EXE program in a dos prompt.
Type (RM95DUMP.EXE>factory.txt) this will save a copy of all the setting of the camera to your pc.
Now you did that run RM95EMUL.EXE.
You will need the service manual to know what settings to change.
I had to change these addresses to unlock page d with the flash error setting.
Set address to (reset all values to default after page d is changed and saved)
Page: 0 .address: 01,and set data: 01.
Page: 2 .address: 03,and set data: 00.
Page: 2 .address: 00,and set data: 2d.
Page: 2 .address: 01,and set data: 2d.
Page: 2 .address: 02,and set data: 01.
Cant change this setting until you change the above settings
Page: d .address: 67,and set data: 00 (if you have an error this will be 4 set it back to 0)
Write/save the new change to memory
Jul 16, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Print to a USB port in DOS in Windows XP
This is an interesting question .... I never thought much about using a USB printer in DOS!
Well ...this is probably the easy fix :
http://www.dos2usb.com/
Program called dos2usb which claims to do exactly what you want (15 day free trial download ....$19.99 to buy the program)
The harder fix that won't cost anything is to do some network jiggery pokery to redirect data sent to a parallel port to a usb port. Here's a link on how the folks at Dataflex did it :
http://www.decompile.com/dataflex/tips/usb_printer.htm
Jan 01, 2009 | Microsoft Windows XP Professional
I needed to change my harddisk & now i cannot start my windows since my disk is not usable anymore i do have an restore plus cd and a operating system disk but it keep saying that is doesnt work with...
Hi awasis,
If cost isn't an issue get a new hard drive, they are going pretty cheap nowadays. However, if cost is an issue you may have to reformat that drive. I really can't go into what's involved with that here. For one, I don't know your comfort level for working in DOS. You need to run fdisk in the DOS environment to format your drive. I would highly suggest you get some premium help here at FixYa.com so an expert can talk to you in relative real time. Sorry I don't have better news for you.
Thank you for using FixYa.com
Sincerely, cyyyd7
Oct 11, 2008 | HP Computers & Internet
I bought my tomtom on the 24.07.08 . you are telling me that my product code is out of date. i need safety camera update
My tom tom dos not come with safety camera update, This information i have to
download from tomtom home at a cost of 34 pounds.
Thank you. I will use FixYa if i come across any other problems . Cheers Paul.
Aug 04, 2008 | Tomtom GPS
Minolta Maxxum 400si 35mm SLR Camera Logo
Top Minolta Photography Experts
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
