Question about Apple iBook G4 (Z0AZW13397068) PC Notebook
My computer will freeze at any given time or I'll receive a message that I need to turn off my computer and restart.
  • Apple Master
  • 739 Answers
This is known as a Kernel Panic. Sometimes it's an indicator of bad RAM or poorly seated RAM. Sometimes it's caused by one particular application making a wrong call. Does it happen randomly or is there a pattern showing?
Generally when I get one of these the first thing I do is a permissions repair (in Disk Utility) - if the computer will let me. If there's no improvement I look at the RAM. I remove it and then reseat it. If that doesn't improve things I resort to the installation DVD and do a reinstall of the system. If you've updaqted the system at all you will have to do an 'Archive and Install' and reinstall the various updates.
There are other options you can look at but they all take time and can cost money. The reinstall is often the quickest fix.
If, however, doing a reinstall does not cure the problem you will need to take it to a specialist for their advice and expertise.
Posted on Nov 15, 2009
    President:
  • 2,030 Answers
Clean out the computer especially the air ports and cooling fans....you may be overheating a bit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Nov 13, 2009
KDL52EX700 shuts down and restarts
If it is showing a blue scree of death (BSOD) and shuts down before you can read the error message try this:
Turn the computer off, then turn it on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Scroll down below Safe Mode and you will see an option to Disable Automatic Restart. Select it and reboot your machine. Next time it boots up you will be able to read the error message. You'll probably need a system disc or repair disc to fix the blue screen error message.
Mar 26, 2012 | Computers & Internet
Why is my acer aspire 5050-5459 continuously restating I can't do anything because when I do it restarts.
The default is for automatic restarts which does not let you see the error message.
  • Power off your computer,
  • turn it on;
  • immediately hit F8 several times a SECOND;
  • You'll get a screen that will have a number of options, one of which is turn off automatic restart. Check that.
  • Now you will get a "blue screen" message that will help diagnose the real problem.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Oct 12, 2011 | Acer Aspire 5050-3242 Notebook
Disabling restart on failure for presario sr2011wm
The default is for automatic restarts which does not let you see the error message. Power off your computer, turn it on; immediately hit F8 several times a SECOND; You'll get a screen that will have a number of options, one of which is turn off automatic restart. Check that.
Sep 28, 2011 | Computers & Internet
Disabling reboot on failure
Your response is very much appreciated. Thank you for using Fixya... Hope this information will help.
Pc always restarts upon booting
Sep 27, 2011 | Computers & Internet
Hang problem
Computers, no matter the make or the model, have a tendency to freeze up. This typically occurs when you overload the RAM on the computer and the laptop can not process any more information. When your laptop freezes, you are not left with many options, so you'll you need to restart the system.
1.Press and hold "CTRL," "ALT" and "Delete" at the same time. Wait and see if a prompt window loads. If one does you can select the program causing the crash and close it. This allows you to return to using the laptop.
2.Push and hold the power button until the system turns off. Typically, you need to hold the power button down for a few moments before the laptop shuts down.
3.Remove the power cord from the laptop if the power button does not turn the computer off. Occasionally this can occur, in which case you need to find an alternative way of cutting the power.
4.Flip the laptop over if the power button is not turning the computer off. Find the battery compartment on the bottom of the laptop and remove it from the computer. Momentarily the computer shuts down. Leave the battery out for a few moments.
5.Insert the battery back into the computer and press the power button. Shortly, the computer restarts and begins to load the operating system.
I hope you find it very helpful.
Aug 26, 2011 | Computers & Internet
I have samsung s5230... my phone doesn't receive message,, somestimes it keep receiving same messages. i used another phone to try if there is problem on network, but the other phone normally received...
I have the same phone.
I have the same problem. But i do solve it by restarting the phone.
When you receive same messages at a time by a same number. Then, Just restart your phone. It'll get back to it's normal. :)
Apr 19, 2011 | Samsung Star GT-S5233 Cell Phone
My computer is freezing up, won't do nothing
Freezing often occurs when your computer is receiving several commands at the same time.
First check your Startup Menu and turn off (uncheck) any programs that don't need to run upon starting up (Go to Start, Run, type in MSCONFIG, select "Start Up" tab and uncheck those needless programs). You can always turn programs on manually when needed (such as media players, games, Instant Messaging, etc.)
Second, check the Options or Preferences in your anti-virus and anti-spyware programs and make certain you don't have a constant scan occuring that will slow down your applications.
Third, turn off any programs or applications that might be running but that you're not using. The fewer programs you have running at one time, the less your computer has to process.
Fourth, when your computer freezes, click on your Control/Alternate/Delete keys at the same time and only once. A window will open called a Windows Task Manager. Select the "Applications" tab if it's not already selected, and highlight any programs which are "Not Running." Then click on "End Task" for those programs only. This way you don't have to restart your computer.
Fifth, notice those programs that seem to cause your computer to freeze and either remove them, replace them or reinstall them.
Dec 27, 2009 | Computers & Internet
EasyShare Application.
What operating system are you running on the 2nd computer. If it is new and you are using Windows Vista there is a good chance your software is not working.
try downloading another program to help you with your photography. You can still hook up the camera but you may have to use another program to work with the photos.
Jun 25, 2008 | Kodak EasyShare C663 Digital Camera
Computers & Internet Logo
50 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
