Question about Sony XM-2100G Car Audio Amplifier
REMOTE PLUG? WHERE CAN I GET ONE??? GOT THE AMP BUT NO REMOTE CONNECTOR
  • 563 Answers
Try RadioShack or visit the Sony website.
Posted on Nov 13, 2009
96, ford mustang, after market radio installation help! where to plug the amp remote wire for amp
The blue wire is a triggering wire of a low amp power for Amps or a power antenna. If it draws too much power (gets hot), use a relay for more power directly off the battery.
e,g..2 amp radio output and if the amps need 1.5 amp each that's 3 amp. Need a a relay.
Jul 17, 2017 | Ford Car Audio & Video
My tv only displays snowy screen with load static noise. When I unplug it and plug it in the tv turns on by itself and the snowy screen and load static are there.
check that the antenna wire is properly connected as the screen indicates that it is not working or connected properly
Jan 03, 2016 | Televison & Video
How can I repair/replace the remote "receiver" on tv for my 2004 Mitsubishi ws-48315 projection hdtv
This is a V24 chassis circa 2003/2004
First check the connections at your IR-receiver pcb. I was not able to ascertain a part# for this pcb, as the unit is over 10years old. There is,however, a part# printed on that pcb & you may be able to google that & locate the IR-pcb (that is your infra-red receiver printed circuit board)
try unplugging the connector on the IR pcb & plug back in both on the IR pcb (connector AN) & on the signal PCB(connector RF). you could have faulty wiring on either pcb or on the connect contacts.
Dec 26, 2014 | Mitsubishi Televison & Video
Where do i connect the remote wire?
There will be 1 connection that has 12v or power. Connect your power lead from the battery to this terminal.
There will be 1 connector that has GND, GRND. Connect this wire to the body of your car in your boot, sand down area first clean of paint and dust to bare metal. Easy place is your seatbelt harness under your rear seats.
Then there will be 1 connector saying RMT which is your remote wire.
This wire connects behind your head unit and then to the RMT connector on the amp.
The remote wire turns power on to your amp on when ignition is turned on. The amp will turn off when ignition turned off. The same way your head unit turns on and off.
Hope this helps, If you cant find your RMT connection, Please state make and model of amp and I will locate it for you.
Feb 05, 2013 | Hifonics Brutus BX 1205D Car Audio...
Stereo remote wire won't power on amp sony mex
The easiest check is unhook the remote turn on wire from the amp and use a small jump wire to bridge the 12dvc input of the amp and the remote turn on connector of the amp. If the amp powers on there is an issue with the remote turn on connection either a bad wire or bad output. If the amp doesn't turn on there is an issue in the amp wiring or the amp itself.
Nov 26, 2012 | Car Audio & Video
Mx3000 does not charge when in cradle. nothing
I agree with ceocass, however if you find that the contacts are clean and you have made certain that the charging cradle is plugged in you may simply need to replace the battery.
Please note that the replacement batteries for the MX3000 Universal Remote Control, p/n's Powercard PC046067-H & PC036067V3 have been discontinued.
TheBatteryStore.com now carries an alternative battery, p/n PL056067V3 which is a 2,100 mAh typical capacity battery that can be used as a replacement.
Please confirm that the connector type is the same as your battery prior to placing your order. We only carry this battery with the Version 3 connector which has a built in pressure release tab.
The link for the product page is: http://www.thebatterystore.com/replacementbatteryforuniversalremotemx-300037v2100mahli-ionpolymerrechargeable.aspx
If you have any questions please contact TheBatteryStore.com at sales@thebatterystore.com.
May 27, 2010 | Universal Remote Control MX-3000 LCD...
I have a PPI 2075AM amp.Plastic connector whats, what?
the sticker usually shows u the exact way the leads r set so just use the sticker
Aug 10, 2009 | Car Audio & Video
Remote control cable
Within the same manual, you'll find a section that may say: Additional Accessories.
The cable should be listed as an accessory item to order.
Contact Kenwood and ask them how to order the cable.
Oct 22, 2008 | Radio Communications
Pioneer GMH100 Amplifier
If you don't need the OEM plug, you can use the type of connector used to connect to the terminals of a speaker. You will have to tighten the terminal slightly but one terminal will span the remote and acc pins and will allow you to use the amp. You don't need to apply power to the 'ill' pin of the plug. Be careful with the pins for the plug. The amps are known to having weak connections that break easily if excessive pressure is applied to the pins.
Jan 05, 2008 | Car Audio & Video
Connecting a amp
It has a remote output if it also has RCA pre-outputs. The remote output wire is blue with a white stripe.
Sep 24, 2006 | Pioneer DEH-1630R CD Player
Car Audio & Video Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
