Question about Dishwashers
The fridge is not making ice
The fridge is not making ice there is water but the ice is stop coming every thing is ok it is only the ice ?
  • 460 Answers
The ice maker feature in your frig. went south. have a service guy install a new 1 for you..
Posted on Nov 13, 2009
  • 998 Answers
Clean coils in back or under fridge
Does not make ice
This can be be several different problems. The simplist solution is the water supply, make sure the valve is on to being water to the fridge. Make sure the icenaker is on. If you have an icemaker arm, make sure its down. The fridge water filter can stop flow of water to the icemaker, if its old, change it. Check those things and then see if you get ice, if not we can continue
Nov 16, 2014 | Kitchen Appliances - Others
G E Select ice maker has stopped making ice
First, check the filter and make sure it isn't clogged. Second, check the water line and more importantly, the valve that feeds the water to the fridge. It should be 1/4'' line and usually has a saddle valve installed off another larger cold water line. Saddle valves have a tendency to rust and clog. these are simple fixes, generally. IF all these check out OK, Check the water valve inside of the fridge, where water line comes in..Hope this solves your problem.Good luck DW
May 11, 2014 | GE Ribbon Module for Select-Top Modular...
When i close the door on the freezer side the water trickles down the front panel
This could be a leaking water valve. First thing I would suggest is to turn the water supply off under the sink or behind fridge wherever its located and see if the leaking stops.If so then you'll need to replace the water valve on fridge. If this doesn't work look up inside the ice chute on front of door and make sure the flapper is closing all the way when you get ice. Warm air coming up into freezer because the flapper is not sealing tight can cause water to run down front of fridge.If this is the case there is usually frost buildup on the ice chute on the inside of door.
Oct 25, 2013 | Refrigerators
Maytag Fridge MFI2568AES - Ice maker not filling
Check water line going to fridge and ice maker! Does water come out ok?
Jun 17, 2012 | Maytag Refrigerators
Ice Maker stopped working -- new fridge 3 months old.
Good day,
Icing could be one problem. The first thing to test is the water supply to the machine. Shut the house off at the meter. Remove the line from the water valve at the machine. Insert the line into a bucket while someone else turns on the water at the meter for a 15 second count. It should come out forcefully, not weak or just dribbling.
If it's bad, then the line and the fittings where it connects to the house supply should be inspected, and cleaned or replaced as needed.
If it is O.K. and the machine is under one year of age, it is under warranty and you should call your selling dealer for a free service call.
Jun 30, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
There is no ice and no water coming out of the ice dispenser
You dont say if it quick making ice. First check to see if water is coming to the fridge from under the sink. If so that is a two chamber valve on the back of the fridge one side water for drinking and one fror ice making check the two coils. That probably has to be repaced. If its still making ice but not comming out the a swithc or lever is not activating in the door.
Apr 21, 2010 | KitchenAid KSCS25FKSS Side by Side...
Refrigerator
it would have double solenoid where water enters fridge at the back. Possible screen is pluged inside the solenoid. Possible one solenoid is burned out. Sometimes the water entering to ice maker would freeze inside the tube and stop water from filling ice maker. Check those things for now. Another thing to ckeck to make sure nobody pulled the icemaker arm up to stop icemaker
Jan 08, 2010 | Whirlpool GS6NBEXR Side by Side...
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
Water is leaking into fridge, ice maker making hollow ice
Make sure when the icemaker fills its not causing the leak ...... other than that you have a clogged drain in the freezer section .... easiest way remove everything unplug for 24 hrs with door open .... manual defrost ....hehehe ..... plug back in u should be ok if reoccurs call for service
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Kitchenaid fridge (ksrw25crss02)icemaker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispencer.
hi kev215,
welcome to fixya.com.
Huuum at your service.
You said, the ice maker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispenser.
The first thing I would ask is when did you last change your water filter in the fridge?
Or if it's an older fridge with an inline filter behind the fridge!
check the shut off valve for the water line that leads to you ice maker. under the sink or in the basement or where ever the line comes from. I've seen where someone turned the valve a little clockwise unbeknown to the home owner and stopped or slowed the water flow.
The water line should be checked too, for any kinking that may be running behind the fridge or some unseen place!
How old is the fridge??
Let me know,
Thank you Huuum
Sep 23, 2008 | KitchenAid Refrigerators
Dishwashers Logo
111 people viewed this question
Top Dishwashers Experts
