Question about Dayton Psc Blower 960CFM. 1030RPM 115/230volts 60/50hz # 4C830
Trying to replace a blower the blower has a white and a black wire the conduit has a white, black and a green? how is it wired?
  • 5,603 Answers
Match the black and white colors and the green goes to the metal frame of the blower.
Posted on Nov 13, 2009
  • jhreeves Mar 02, 2013
    Thank you that worked perfectly
I need the wiring schematic for a Hampton Bay 52' ceiling fan with lights, has 2 pull switches and a slide switch.
You should have 5 wires to connect. Green is ground and it may also be a bare copper wire, White is neutral, black and the other are hot, they control the fan and the other controls the light. IF you are hooking them into a conduit box that has white black and ground (which is bare) you hook the grounds together and then hook the whites together and then the other two from the fan connect to the black wire in the box.
Jun 16, 2015 | Hampton Bay Dryers
Red lite on the straight blade indicator plug (PS5266XGCMCCV4) This is a line that runs under ground to an outdoor chicken coop. I'm sure the wiring is correct, if black plasticed wire to brass screw...
You have the connections correctly done. I hope that you ran the wires through plastic conduit for the under-ground run. What is connected at each end? Is the circuit causing the source breaker/fuse to trip? Are you making direct connection to your house service panel or just plugging the extended wiring into a socket in the house? The hot black wire should go to the breaker/fuse, the white wire should go to the neutral bar, and the ground wire should go to the ground bar. Hope this makes sense and helps!
Nov 06, 2010 | Garden
I am replacing an in-wall timer switch that controls porch lights. Old timer has only two black wires, that were hooked to the 2 black wires in the wall. The new timer (GE 15086) has black, red, white...
Did you get instructions with the switch? Does it say what is line and what is load? You can hook the green and the white to the green, it won't hurt, but I think one of the colored wires is in and one is out, you have to find out which one is hot. Got a tester? The new timer is polarized for modern electricity, which hasn't gone into effect yet, it is coming. Your house wouldn't have it. If it does, you will know by the fuse box being separated by ground and neutral, the old ones were wired together. If it is, the new switch will only work with the white wire to neutral and the green to ground. Now that you are totally confused. try wiring it up with the green to ground, red and black to to the 2 blacks. See what happens. Hope this helps.
Oct 13, 2010 | GE 60minute Automatic ShutOff Timer Switch...
NEED TO KNOW from scratch,step by step,how to wire 2 exhaust fan to double single pole switch? What is the proper breaker,type of wire and do you any kind of thermostat.
hi,
okay three wires into switch box? hopefully. it will need a 25 amp breaker at the panel, remove the one in the panel and take it with you to the hardware store get a 25 amp replacement. the conduit that runs the old fan should be sufficient or use 16 gauge conduit.
okay locate your power in wire conduit with tester. now all the white neutral wires go together take the black power wires and install it to one side of the switch make a small jumper wire and that must go from the black wire you just installed to the same side of the next switch. the two black wires coming down from the ceiling go to the empty side of the switches, one wire for each switch. depending on what you want, you can use a standard 240 volt wall heater thermostat for the ceiling heater or just use a switch, since those are just mostly used for when your in the bathroom.
if you only have one wire coming down from the fan your going to have to go up in the attic and fish a new wire for the heater and night light nutone makes a special three switch setup for one box for that fan, you might want to buy that, it may come with a wiring diagram too.
any questions write me back, your setup may be different..
ground wires all go together and are green or arent insulated be careful , take time
jm
Jan 02, 2010 | Broan-NuTone N-769RF Combination Light Fan...
Weatherking gas furnace and need help with transformer wiring
on 120v units most likely will be white should be common,black should be hot,brown to capacitor, and green to ground transformer sounds to be wired correctly.
Jun 26, 2009 | Heating & Cooling
Low voltage wires
I just tested a mastercool control box and found these 4 control wire colors:
Red (24v supply)
White (pump)
Green (low blower)
Yellow (high blower)
The yellow acted as a common for testing when the blower was not on high.
Blower on low just green has 24v.
Blower on high green and yellow have 24v.
If there was a fifth wire added hopefully it would be a ground wire.
There was also the low gauge wires that were black, white, and ground that were not control wires and delivered power to the control box.
May 05, 2009 | Mastercool 67680 Evaporative Cooler Air...
We have a Jenn air jed8430. It was installed but never supplied power to it or tested. We want to make sure the wires are right before powering it up. Black is with Black. Red is with Black with Red...
I just looked, and there is not a wiring diagram available on the web for this unit.
I am concerned about the black with red stripe to red.
Check to see if there is a wiring diagram somewhere on the unit (there wasn't one in the installation instruction or manual for this unit.). I believe the red wire on the house side goes to the black/black wire on the cooktop side (so I believe you are correct on your concern.).
House side green should be to the coiled silver cooktop side silver wire.
But the wiring diagram will confirm these things.
I think the black/red stripe is for the blower.
Jan 28, 2009 | Jenn-Air JED8430 Electric Cooktop
Blower stays on with new themostat
Check to see if there is a short between the green wire and the red wire. Green is the fan control wire for AC. Sounds like some wires may be touching. How did the old t-stat get fried?
Jan 02, 2009 | Honeywell Programmable Thermostat Heater
Disconnecting green wire from thermostate did allow furnace to run properly but every time I want to switch back to heatpump I must reconnect green wire again.Here is how wires are connected to...
Try this.
A T-stat.
Orange = O
Red = R (with existing jumper)
Black = C
Yellow = Y
White =W1 (Or AUG)
Green =G
At airhandler/furnace.
Green = blower wire (usually green, double check with schematic)
(Green should not go to the HP.)
Orange to HP
Red to red and to HP
black to blue (or C) and to HP
White to W
Yellow to HP. (It may also go to a "float switch" if installed. but that will just be a safety switch on the drain pan in case the line clogs and it overflows.)
The green is typically used for the blower motor. (furnace only)
The orange is used for the reversing valve. (changes from AC to heat, is located in the HP only)
Blue is typically used for common (or "C") but they may have changed it to black due to a broken wire, or other problems.
The only wires going to the HP should be
Red
Blue/black
orange
yellow
Orange should not be going to the furnace at all.
HP wiring should be
Orange to orange or O
Red to R or red
Blue/black to blue or C
Yellow to Y
Dec 09, 2008 | Heating & Cooling
Dayton Psc Blower 960CFM. 1030RPM 115/230volts 60/50hz # 4C830 Logo
67 people viewed this question
Top Dayton Tools & Hardware - Others Experts
Bill Boyd
Jerry Pitts
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Dayton Tool and Hardware - Other Expert? Answer questions, earn points and help others
