Question about Kohler 1221-H-0 Seadream 6' Whirlpool Bath Tub with Heater
Unit starts on it's own without warning. i have to turn off the breakers at the panel. help!!
  • 125 Answers
Sounds like a bad circuit board in the system. change that and solve your problem
Posted on Nov 15, 2009
American Standard heat pump troubleshooting
If the compressor is not frozen, then it is most likely one of the starting capacitors on either the compressor or the fan motor. These can fail without warning and without any outward indication. They are shaped like small cans or oblong cans and have 2 or more wires that attach to them with terminals. If you are going to remove one or check them, Make sure the power is off first.
Aug 11, 2014 | American Standard 282999 4" Heat Pump Snow...
2003 Mercury Sable when apply brakes hard theft light comes on
check the over load circuit breaker for the lights going out. Run fault codes to find the ABS/ Traction control sensor problem
Feb 16, 2014 | 2001 Mercury Sable
Hello , this is Bobby and I have a Coleman Mach rooftop air conditioning unit Model # 8335B8964 when I turn on the unit ,it throws the circuit breaker . I have replaced the starting capacitor and the...
Here's a link to a service manual, with step by step tests to determine whats wrong. I'm thinking compressor shot, but this should confirm, and or help you determine for yourself. Be careful with those capacitors eh !! Read warning in service manual.
http://www.rvcomfort.com/pdf_documents/1976141_copy.pdf
Oct 19, 2010 | Coleman Mach 15 Air Conditioner
The dishwasher is 6 years old. 2 days ago it started clicking like to wanted to come on and the light in the handle was blinking. It started by itself without anyone in the room. We had to trip the breaker...
Please confirm if you have double drawer unit then which drawer has this problem. Do you have any code displayed on the LCD panel? What happens to the other drawer if you have one.
Sep 01, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Everytime my central air unit kicks on my circuit breaker trips. It didn't do this last year or even earlier this year
A circuit breaker 'tripping' everytime the AC unit kicks on 'most always' indicates a direct short (somewhere in the condensing unit), although it is possible that the breaker itself is bad - (but not likely).
Usually the cause of this 'short' will be - either the condenser motor in the condensing unit (outside unit) or the compressor - also in the condensing unit.
If you're mechanically inclined - and "very careful" around electricity - there is a fairly simple way to find out which component is causing the short.
Step 1 - Make sure the condensing unit (outside unit) is completely disconnected (electrically) , i.e. pull the fuses/turn off circuit breaker on outside unit and turn off thermostat.
Step 2 - disconnect the condenser motor (this is the outside fan motor). Note: when you disconnect the wires of the condenser motor "be sure" you mark/write their location, and wrap them in electric tape.
Step 3 - start the AC unit. If the breaker trips again you can pretty much rest assured it's the compressor that is shorted.
To prove it (without a doubt) - go to next step.
Step 4 - "be sure circuit breaker and thermostat is turned off" - and - 'reconnect' the condenser motor - and - then disconnect the compressor wires (mark wires and tape them).
Step 5 - Start AC.
If breaker doesn't trip - you know it's the compressor that is shorted.
If breaker 'does' trip again - then it's possible the breaker itself is bad (not likely) or there is a 'short' in the condensing unit's "wiring" somewhere (not likely).
My guess is that either the condenser motor or compressor is shorted.
Hope this helps.
Good Luck!
Jun 10, 2010 | Heating & Cooling
My air conditioner fan is broken, i think.
Fan may need a new start capacitor. It appears or sounds like the motor is not getting the puwe it needs I don'y know what "not fast enough" is to youm but those fans really dont turn very fast, There should be two fuses in a box near the outside unit/ One can bbe bad causing low power to unit. To ck the, There should be something on the fuaw to indicate it's blown. WARNING!! dO NOT TRY REMOVING WITHOUT TURNING OFF ALL POWER AT THE MAIN HOUSE SUPPLY CIRCUIT BREAKER, hIGH VOLTAGE CAN AND WILL, GIVEN THE CHANCE. iF IN DOUBT, CLL OUT A QUALIFIED SERVICE COMPANY.
May 25, 2009 | Goodman CKL24AR24 Air Conditioner
GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
To get elec power to my heater my breaker has to be in the off position
the laws of physics dictate that what you are saying is impossible.a unit can not run without power so you have done one of three things. the breaker you are turning off has no relationship to the ac. or the breaker is for the indoor , not the outdoor unit , or you have confused the position of the breaker in the panel with on and off.breakers on the left are on when pushed to the right . breakers to the right are on when pushed to the left. take a volt meter and verify you have power to the outside unit when breaker is in either position. then proceed from there.you have not stated if you have a gas, electric or heat pump heater. but if you have succeeded in generating heat without power we are millionaires, cause it has baffled scientist for thousands of years till now.
Oct 13, 2008 | Coleman Heating & Cooling
Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
Jan 02, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
Power button problem
Without being there to troubleshoot further, the first thing I'd recommend is checking the breaker. It'll most likely be in the breaker panel outside the house... in the BIG panel. This is a 240 Volt unit, so what you'll be looking for is a "dual" breaker. They'll be connected together.
I'll tell you what... here's the easy way to do it. Simply turn off, then turn on all the breakers in the big breaker box outside. Make sure you have all the computers turned off first, though. You might have to reset a few clocks, but that's OK. I'd bet this gets you cooking again. If not, post back.
Oct 13, 2007 | Electrolux 37 in. Designer Series...
Kohler 1221-H-0 Seadream 6' Whirlpool Bath Tub with Heater Logo
136 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
