Question about Samsung Eternity Cell Phone
Shuts off after turned on not a battery problem we checked
My truck will not keep running it shuts down as soon as u turn the key
THE SECURITY SYSTEM IS SHUTTING THE CAR DOWN. IT IS YOUR OVERALL PROBLEM
May 07, 2015 | 2000 GMC Sierra
2002 mazda tribute, brand new battery. Would not start or crank, vehicle just shut down. After a few minutes, everything work, but still would not start and just shut itself down again. I have to wait...
check the starter motor itself. (go to napa or autozone where they can check it for free) When starters go bad they sort of ground out internally sometimes which kills the battery. Or the other problem, windings are burnt and so drawing so much current that it is more than the battery can supply. That would follow from your description of "everything work, but still would not start and just shut down" aka, turn key to power, all good as new battery, turn the ignition to crank, all dies... in a bit can sort of light up again, but won't crank. You might be able to whack the starter with a wooden stick (check on youtube for suggestions regarding your vehicle) to get it to a test location. Once running (while it is behaving like this) don't shut it off unless you are ok with being stranded wherever that is.
Nov 07, 2017 | Cars & Trucks
Turned key and nothing happened.. No lights, power, no click - nothing. Was just driving it and shut it off for short time. Took some fuses out and put back in. Turned key and car started. Shut it off...
sounds like a lose or bad conection on battery or bad conection to earth check leads from battery to chassy check leads from battery to fuses for any loose or bad conections
Jul 28, 2011 | 1995 Chevrolet Cavalier
Laptop shuts off
Turn off the laptop. Then, try to remove the battery and the power cables to it & then press and hold the power button ryanpajaro20_3.jpg for 8 secs. Reinsert the cables and battery to it. Turn it on and check if the monitor will quickly shuts off. If it is shuts off or if it does turn on and then off afterwards, the problem would be either power supply ryanpajaro20_4.jpg or the motherboard itself ryanpajaro20_5.jpg
You might try to use only the battery (if it is not empty) to check whether the laptop will stay on for as long as the battery holds through.. Otherwise, consult your PC provider to repair your laptop..
Mar 17, 2011 | Computers & Internet
Toshiba Satellite P205d S7479 shuts down suddenly when on battery. The battery is brand new.
Try to turn off the laptop
Remove cables and battery on the pc
Press and hold the power button for 5 seconds
reinsert battery and cables on the laptop
Turn on the laptop
Check if the PC still shuts down. If it is, try to connect the power cable without the battery. If it turns on, call your pc manufacturer to replace the battery....
Jun 21, 2010 | Toshiba Satellite A135-S4527 Notebook
Turn it on, the screen says ATT then shuts off
Check the battery if it needs to be replaced. Borrow same phone from a friend and use your battery on the other phone and check if it will turn on or will just do the same thing and shut off after the ATT... if it did the same thing...replace your battery.
May 12, 2010 | Motorola Mobility Z9 Cellular Phone
Monitor turns on and then shuts off
HAVE YOU CHECKED THE BATTERIES ,,MOST OF THEM DO,,MOSTLY 2 AAA BATTERIES
Sep 28, 2008 | American Diagnostic Corporation Advantage...
Shuts for no reason
Check the battery first..... alot of times a person will put a battery in a chager and let it sit. They will think the battery is fully charged but it may not be... In those battery packs there are a bunch of smaller batteries all tied together. Alot of times these commercial raios will run off of around 7 volts ( check the battery). The battery will only charge up to 7 volts if all the cells inside the battery are good. What I'm saying is for you to charge the battery up fully..... check the voltage listed on the battery then use a volt meter to check the voltage after the battery is fully charged. When a battery has just finished being charged usually it will be overcharged.... a 7.5 volt battery will be up around 8.5 volts for example. So check the battery right after its charged... expect it to be overcharged. If it seems OK, put it in the raio and key the radio for a bit to try and use up some battery power.... then check it again and see if it has dropped drastically. Your problem has to do with power... the first link in the power chain is the battery... check that out... then go to where the battery makes contact with the radio and make sure thats good.... inside the radio there will be a fuse but if thats blown you will get nothing... then the power goes to the switch. Battery... contacts...fuse... switch... that how the power initially gets into the radio. Most of these problems are battery related so I would check that first. If the battery does not have enough power when you transmit with the radio the radio will shut down.... turn off. If its not getting enough current the voltage will drop and once it gets low the radio shuts off. Usually with commercial stuff you will hear a "beep" when this happens. Your problem might be power related... theres alot you can check.
Sep 13, 2007 | Motorola AXU4100 (10 Channels) 2-Way Radio
Coolpix 8800 shuts down
Make sure to use good NiMH batteries. Another possiblity is a problem with the card. Borrow a card and see if it has any effect. check to see that the pins in the card slot are all aligned, none out of place. check that the card door and the battery door close firmly, with some pressure. The camera can shut down when it has a problem detecting that the doors are closed. When it does turn on, play with the zoom without taking pictures, zoom in and out, if during zoom the camera shuts down then you might have a lens problem, something is malfunctioning in the lens mechanism and the camera shuts down to prevent damage. Good luck
May 19, 2006 | Nikon Coolpix 8800 Digital Camera
Samsung Eternity  Cell Phone Logo
47 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
