Maytag commercial front load washer MAF18MC3AS has 3 rinse cycles. can this be changed to 2 rinse
  • elvic415 Nov 13, 2009
    can wiring be diconnected or switched around to remove a rinse cycle
    Top Expert:
  • Washing Mach... Master
  • 75,822 Answers
To do this u would have to change the timer, the only folks that supply the 2 rinse cycle timer (if there is one) is Maytag.
Posted on Nov 13, 2009
  • 6,784 Answers
No. unfortunately, this is a preset situation. this is programmed into the main logic sector on the control. It is preset during manufacturing, and cannot be changed.
  • Michael Masters
    Michael Masters Nov 13, 2009
    NO. This is not recommended. You could short the main board.
  • Michael Masters
    I'm sure you were expecting a magic fix to manipulate the rinse cycle, but this is not a reality. Tampering with the wiring will cause more serious issue to occur. This unit is preset from the manufacture to run a standard 3 cycle rinse. this is standard.
    Tampering with the wiring, or cross wiring will damage your investment....
    Good Luck:)
Put detergent
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 14 years for me.
Jan 14, 2014 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag washer very loud on spin cycle
I know the exact sound you are hearing, I had the same thing several yrs ago on my old Whirlpool. I think it was something with the transmission, but what I needed was no longer available. I found a lot of info by entering the make/model nr in search box at appliancepartspros.com. You could also look atR44U61 RepairClinic.com
May 02, 2017 | Maytag Washing Machines
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    Washer won't drain/rinse/spin
    it may be a pressure switch fault. Remove the top cover (lid) and look for a round object with a small rubber pipe coming of it and a electrical connector with 2 or 3 wires, replace this part.
    Apr 12, 2009 | Maytag MAH8700A Front Load Washer
    Maytag neptune stops in mid cycle
    It sounds like your drain pump is going. Neptunes are suppose to neqarly dry the clothes with how fast it spins. A poor drain pump/motor, could cause this to be less effective. There could also be something in the drain lines. I would check that before you pay money on a pump though.
    Feb 28, 2009 | Maytag MAH20PD Front Load Washer
    Maytag washer shutting off on rinse cycle
    If the washer is not completing the Rinse cycle there may be problem with:
    Lid switch
    Motor coupler
    Belts
    Clutch
    Drive motor
    Drive pulleys
    Transmission
    Agitator
    Let me know if you need further assistance.
    Regards
    Ellin
    Sep 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Maytag Neptune rinse cycle doesn't start.
    cold water valve screen plugged or bad valve, just check it!
    Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
    Washer wont rinse
    you have a pump problem, need to lean washer back ageist wall go under washer. front left take off both hoses stick finger in pump remove all items from pump &hoses should work now
    Aug 04, 2008 | Maytag MAH2400A Front Load Washer
    My Maytag front loading washer does not fully rinse cloths MAH8700A. I purchased this washer about 6 months ago. I usually wash small loads but have noticed it doesnt matter what size load. When first...
    Is the drain path free-flowing? That is, does the water eject freely during spin/rinse? Maybe there's a restriction in the line, or it's too high above the washer.
    Feb 25, 2007 | Maytag MAH8700A Front Load Washer
    Shuts itself off before each Rinse or spin cycle.
    Maybe your spin or rinse cycle button is in the off mode. Refer to your user's manual, if you hv one.
    Dec 24, 2006 | Maytag Neptune MAH5500B Front Load Washer
    Washing Machines Logo
    74 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
