Question about Refrigerators
What happen if water fall on the compressor problem:
  • 6,826 Answers
It should not hurt it,the electrical is sealed with a o ring seal,and it might be just the condensation off the suction lie,and that is to keep the compressor cool.
Posted on Nov 13, 2009
Have a scottsmanicemachine doesnt drop ice compressor on water on water runs on coils goes to harvest but makes no ice coil usualy have a ice buildup before it harves
The water runs over the evaporator coil(plate) until the ice gets thick enough, than when the ices touches a switch for the thickness you have it set for, it to go into harvest and the hot gas from the liquid line goes through the evaporator making the ice fall. If you are not making ice, it is the refrigeration system not working, so check the refrigerant, compressor etc like you would on any refrigerator or freezer
Dec 09, 2014 | Coffee Makers & Espresso Machines
I am finding brown flakes behind my whirlpool refrigerator. Why is this happening and how can I stop it? There is no ice or water dispensor on my refrigerator.
Hi Aaron !
I believe the brown flakes you are finding are coming from evaporated condensation. Let me explain ! As warm air and product hold more moisture then cold air or product when the door is opened and closed cold air in the fridge falls out and warm or ambient air replaces it. ( warm air rises and cold air falls ) The refrigeration process has an evaporator on the inside that is essentially colder than the temp you are maintaining the fridge at. Moisture is drawn out of the air and product and freezes to the evaporator thus drying the air in the fridge. When the compressor cuts out and the ice melts the moisture goes down the drain pipe and either collects in a container on top of the compressor or in a tray that has heated pipes from the refrigeration process through it. The moisture is then evaporated and leaving only the impurities of the air, dust and/or wet spills in the fridge. If you have a fan under you fridge or a breeze goes through there it is easily disturbed. Not a lot you can do as it is a part of the process. Wipe up spills, reduce door open times and keep door seal cleaned with warmed soapy water. Check fridge is level and square and doors close tight. Hope this helps tiger !
Apr 22, 2014 | Whirlpool Refrigerators
Serpatine belt comes off buick park ave. when driving through standing water
My bet is that one of the pulleys is misaligned. Could possibly be on the belt tensioner. Have you tried a new belt tensioner?
Also make sure the other pulleys do not have ANY play in them. Take the belt off and by hand check to see if you can wobble any of the pulleys.
If the shaft of any pulley is not perfectly aligned with the other pulleys, that pulley could cause the belt to slip off. Has the alternator, power steering pump, AC compressor been worked on or removed just prior to this happening? One of those might not have been reinstalled perfectly. A washer that is missing or in the wrong place can cause a belt to drift.
Mar 03, 2014 | Buick Cars & Trucks
Hot compressor
We cut compressor open to see what happened to it. Grounded and found couple more issues.
May 12, 2012 | Matsushita DD73C14GAU6 1/4 HP R134...
We have a T30 Air compressor and we found this compressor full of water inside the crankcase, where the oil is. and know when we turn it ON it start crearing presure inside the crankcase. do you know what...
As you probably already know when you compress air, the moisture in the air falls out and ends up in your tank. If you're rings are going bad, and allowing blow by into the crankcase, the moisture will go with it. Two things happen, first the water displaces the oil which rises to the top and probably goes out with the air,and secondly then the bearings and cylinders don't get lubed, and wear even more. You will probably require new rings, and depending on wear, boring and new piston(s)
Sep 24, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Frigidaire 70-pint dehumidifier won't work after winter
No reset button on the compressor... but this tip may give you some clues as to what is or is not happening..
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 04, 2010 | Frigidaire FDL60P1 Dehumidifier
Ac giving hot air i think a box is stuck?
Yes a blend/air door stuck could cause that. Is your AC compressor cycling/engaging as it should?
Mar 08, 2009 | 2005 Nissan Maxima
Loud noises, bangs and sounds like water falling
if it’s a banging sound--- I know one of the noises the system 2000 will make is a bang or rattle at the end of the run cycle, which we call "shudder stop". If this is your noise then I have to give you some bad news here. Sorry....... The only way of repairing this is by having your compressor replaced as it has to do with an internal problem in the compressor itself. There may be a silver lining, though, if you are the original purchaser and you have the receipt. Some of these systems came with a 10 year warranty on the compressor, so you might want to check this out.good luck
Dec 10, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Refrigerator is making a loid noise
** the y do sound directly related. water is dripping down your ice maker falling on to bucket? well a small amount of water is also falling onto the evaporator fan assy, freezing and the **ise you hear is that fan blade "cutting" through the ice.you can lift the arm turning the Ice maker to the off position, itll stop calling for water,and your **ise should stop as well
Mar 10, 2008 | Refrigerators
Freezer not freezing, everything is thawing.. only 3 yrs old, refrig part only 47 degrees
sounds like your compressor is not starting up. unplug your refrig then remove the start relay from the side of the compressor. shake the relay if you hear alot of rattling around in the relay then most likely that is all thats wrong. if it doesnt rattle alot then possibly the compressor is locked up and is bad.
when you shake the relay if its broken internally usually little peices of ceramic will fall out of it. so shake it over a peice of paper to see if that happens/..
Dec 16, 2007 | Jenn-Air JCD2290HES Side by Side...
Refrigerators Logo
13 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
