Question about Stoves 720EF Electric Double Oven
When turning the oven on it will not start up
When turning the oven on it starts up but then cuts out straight away and turns itself off
  • 250 Answers
Assuming the clock/timer has not been accidentally set, and this is what is turning it off, does everything go off on the oven including the lights and the display on the oven control?
If it does, then it could be the oven overheat thermostat kicking in.
Also is the cooling fan running normally in the background because if it isn't, this will cause the oven to overheat.
Posted on Nov 14, 2009
We started the oven to bake a pizza, set it to 400 and walked away. A minute later I noticed the oven had turned off, the display, everything. I can not turn it back on, the display is dead.
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | Ovens
Hi, we have a Blance BSO602 oven which has started to produce a burning plastic smell whenever it is turned on. It doesn't appear to be coming from inside the oven itself, and I know of no plastic which...
I'm guessing this unit is an oven only. Is it new or have you ahd it for a while? New ovens often smell for a little while. Probably the best thing to do is to remove the oven from its cavity and sit it on a stool or the floor. Remove the outer casing from the rear and the top. This should give you a pretty good look inside. If it's a major problem you should spot it straight away. Good luck.
Feb 24, 2011 | Ovens
The fan on my circotherm double oven does not come on straight away any more
Assuming the fan does start eventually, then I would say that the fan bearings are starting to fail.
You could try spraying the bearings with WD40,, but long term, you are probably going to have to replace the fan motor.
Hope this helps with your prob.
Nov 28, 2009 | Neff B1432 Single circotherm plus Electric...
My oven won't heat up properly
wire brush the oven pilot light orifix flame may be lessened due to carbon buildup then when oven lights its convextion pulls the pilot flame away from thermal coupling with shuts off gas (in case wind blows it out, it will STOP the GAS FLOWING. if the pilot full size (near 3/4 inch tall) then just try to position the thermal coupling nearer the flame (not right on it)
Nov 22, 2009 | Ovens
Oven W279U Serial No. 790191BD keeps beeping.
I turned off the power to the oven at the breaker box and left it off for several days. I restored the power this afternoon and there have been no more beeps. Spells and incantations may have played a part as well.
Aug 20, 2009 | Jenn-Air Ovens
Oven sometimes does not fire up
Is this a gas unit? There maybe a problem with the burner ignitor, it looks like a glow bar, if it is on it's way out, you will start to get intermittent operation, it should draw at least 3.2 amps, and is located right next to the bake burner itself, if this is an electric oven then there are a multitude of problems that may exist
Jun 15, 2009 | Ovens
Simpson oven 736 evolution turns itself on briefly then turns off
sounds like you have a control board problem
Jun 12, 2009 | Ovens
"loc" display
This just happened to me. I have whirlpool double oven accubake. The display went blank and i had to turn the breaker off. I left it off for several hours. When I turned the breaker back on my oven display read "Loc" in big letters to the right of the time. I held the start button down for 5 secs. The display went away and the oven started to work as if nothing had happened. I hope that is stays that way.
Dec 08, 2007 | Whirlpool Ovens
Oven will work for about half an hour and then turns itself off.
it sounds like the thermal cut out is broken can be replaced quiet easy need to disconnect oven from mains remove outer cover and has four wires two blue two white all with spade connectors can be bought from e spares on the web
Nov 04, 2007 | AEG B4101-4 Electric Single Oven
Stoves 720EF Electric Double Oven Logo
253 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
