Question about Amana AGR5844VD Gas Range
Hot do I clean the burner base. I had a spill on a new range
I did the same thing and used EASY OFF. just follow the cold oven instructions it worked great. also use a SCOTCH BRITE pad and a sponge to finish.
Posted on Nov 13, 2009
Gas burners clicking noise not lighting
Have you dis-assembled the burner assembly and cleaned them out?
Dec 23, 2013 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Gas burner with hot jello spill spark won't turn off
Sounds like the sensor telling it that the burner is on is shorted out with the jello. turn off the power so you don't get shocked and then give the entire assembly a good cleaning.
Sep 15, 2012 | GE Profile JGSP44 Dual Fuel (Electric and...
Vegetable oil spilled from pan and around sealed burner. They burner no longer ignites even though I can see a spark coming from the igniter
This can be tricky, but if you have the same range model that I have, it has a little central cap on each burner that acts as the flame spreader and the working top of the burner channels.
The igniter is off to the side and actually has it own little drilled-in hole just above the business end where you see the spark. Spills, especially big, greasy spills, can get into the hole and harden.
Than narrow little hole simply needs to be cleaned out. Find a small stiff wire and bend it in a long L shape. Work the long end into the hole from either end - wherever you can find the way in... those spills can be awful. **** it out really good so the little gas channel is free of blockage andyou should be good.
You don't have to take anything apart, just get down close and look. On my stove, the hole is in the center of a little raised bump in the burner casting when you look at the center of the burner with the little flame spreader/burner cap off.
Apr 11, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have a kenmore gas range model # 665.75775 the strikers work to light the burners but they will not light do I need to clean the burners and if so how
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jun 19, 2010 | Kenmore 75022 / 75024 / 75029 Gas Kitchen...
The front burner won't light.
I assume the other burners are lighting and the spark ignitor is working - if so try cleaning in and around the burner. a spill could have caused this problem. this should be a sealed burner model - if so make sure the burner top cap is on and seated correctly and or not gunked up with a spill. also check to make sure
May 25, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
We had the oven on, and steam came from area behind the back right burner. Food burned a little bit.
Hello- Oven vent exits this area. Very hot exhaust - you will see smoke and or steam when sumpthin burns. Scrape and clean spills w/water. Avoid 'self-clean' function- NOT healthy for ANY range-no matter what the salesman said. - Hope this helps- ED
Feb 28, 2010 | GE Spectra JBP78 Electric Kitchen Range
Igniter Problem on One Burner
Peace,
ngafm here at your service,
You may have some food that spilled into the burner and it could be causing the gas not to fully flow out of that one burner.
Or you just have a bead igniter.
If you have sealed burners and the cap and burner where the gas comes out, is removable by hand without tools!
You may want to check the gas holes in the removable burner is clear and or clean them out if they are clogged.
How old is the range?
I hope that these measures will help you remedy the problem simply and easily!
Bless you,
ngafm
Please give me a good rating in at this site before you sign off!
Thank You
Sep 04, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
MAYTAG Model ME5770AAW Ceran Top Stove
the lights come on but the burners will not heat up what would be the issue
May 31, 2008 | Maytag MER5775Q Electric Kitchen Range
May tag gas range 30 inch
Peace,
i think that gurgling noise is the gas trying to get out and is neing blocked by a over boil or food spill on the sealed burner with the holes clogged!
Bless you,
ngafm
Thank You
Feb 04, 2008 | Maytag MGR5751AD Gas Kitchen Range
Amana AGR5844VD Gas Range Logo
52 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
