Question about Fellowes Powershred 320C Shredder
All lights turn on as needed and has power but won't grab paper to shred
  • 561 Answers
Suspect paper jam try using reverse button the dislodge paper.
suspect paper feed sensor is blocked or damaged there is a light beem in front of the teeth that starts the shredder if this defective the shredder will not start.
suspect a panel or bin is not correctly seated causing the shredder to not start.
Posted on Nov 13, 2009
I dont have the original bin for an Infoguard SX100M. It runs if I hold it and push in the red button with a screwdriver. When I try to load the paper, the shredder doesnt grab it. Any fixes?
I can't imagine holding the red bin interlock button depressed with a screwdriver every time I wanted to shred something but hey, whatever works!
Your shredder does not grab the paper because an internal "page in" sensor is damaged, defective, or blocked by shredded residue.
Aug 10, 2016 | Shredder Office Equipment & Supplies
My shredder won't shred
If the motor will not run, then probably there's paper clogged in the shredder. Turn over the shredder, after unplugging the power cord, and remove the papers.
If the motor will run but not shredding any paper, then the drive gear has broken teeth. This is not usually worth fixing.
Hope this helps.
Mar 27, 2015 | Shredder Office Equipment & Supplies
My kobra shredder won' shred when we put paper in lights are on
Is the discharge at the bottom where the shredded paper comes out clear? If its blocked by paper etc, it will not shredd.
Aug 19, 2014 | Office Equipment & Supplies
Anti jam light is on unit will not run
The "anti-jam" light actually is a jam light and it is notifying you that the shredder is jammed. If you turn off the power and examine the shredding unit you will find shreds of paper stuck in the mechanism. Removing all of the shreds will get your shredder back in operation and the anti-jam/jam indicator will be off
Apr 15, 2013 | Office Equipment & Supplies
Constantly runs when on auto and won't accept paper
Shut off power and turn the shredder upside down. It is highly likely you will find shredded paper jammed in the mechanism, especially near the center where the feed sensor is located. A thorough cleaning should get your shredder operating again
Feb 02, 2013 | Staples SPL638X (CrossCut) Shredder
Royal VF700 won't barely shred one sheet of paper. It givexs the overload red light when 1 sheet of paper has just barely started to be shredded.
Royal. Haven't heard of that brand. Could get in contact with tech service, but it's probably easier to grab a new paper shredder.
Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Royal VF700 Cross-Cut Shredder
My paper shredder stopped working
First things First...UNPLUG THE UNIT. It sounds like it has been fed too many pages at one time. You may also want to dump any shredded paper so there is plenty of room for the shredder blades to pull in the paper. If the paper catcher is too full the blades can grab shreds from the bottom and stop the blades movement. Just be careful. Shredders can be dangerous.
Jun 01, 2009 | Office Equipment & Supplies
Paper sensor broke.
Can be it's never turned on from the power
Depends on brand, but check the green light is showing on
Check the lid is porperly sitting
Check the bun has enough space to take more shred.
Hope it helps...keep the hope :)
May 19, 2009 | Fellowes DM15C Shredder
Shredder won't grab paper
there has to be something in the path.
once you put the paper in it triggers a sensor that rotates the blades and grabs the paper there is nothing else in between the entrance and the blades. get a flash light and lok in to see what is blocking the path.
unless there are some paper in between the teeth /blades, that need to be cleaned out.
Sep 05, 2008 | Fellowes PS60C-2 Shredder
Fellowes Powershred 320C Shredder Logo
389 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
