Question about Sony Ericsson Walkman® W995 Cell Phone
For some reason my w995 has stopped charging when i plug the charger in nothing happens
Where can you get this fixed or can you do it yourself????
Posted on Jan 06, 2010
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
Hi i'm having trouble charging my phone (sony ericsson w995). i have 3 chargers and when i plug each in the phone does not charge, however the headphones work perfectly well in that I can listen to music...
I think you have asked this question previously.......... Same answer.
The charging port of your phone should be the cause of the problem. It's either the charger is not contacting the charging port well enough or the charging port might be defective and needs to be replaced.
Use a pin to scratch the surface of the charging port and try again. If that doesn't work, then know for sure that you will have to replace the charging port.
If you feel you can do the replacement yourself let me know when you get a charging port replacement so that I can direct you.
Good luck.
Mar 21, 2011 | Sony Ericsson Walkman® W995 Cell Phone
I've my had sony ericsson w995 for almost a year now and i've never had any problems except one. If my phone goes out of battery the phone completely dies. when it comes to plugging it into the charger...
go to sony site,pick your mobile phone,for update,download update service in your computer,and follow the instructions.you need to have the usb cable.your phone will be good as new.
Mar 20, 2011 | Sony Ericsson Walkman® W995 Cell Phone
When i plug my charger into my w995 in appears to be charging but the battery power level doesnt go up???
depending on you have service with you may need to take it in to your nearest retail store and let them troubleshoot it for you may have a charging port malfunction
Dec 07, 2010 | Sony Ericsson Walkman® W995 Cell Phone
My W995 has not been charging for a while now, i have at least 3 chargers and my brother also owns a sony ericsson phone and the chargers work on his phone. Now i have to charge it through a usb on a spare...
The problem you are facing with the phone is definitely not from the charger but rather from the phone itself,
The charging port is worn out,hence its unable to transmit power into the phone mechanism,which makes the phone unable to charge.
The solution is to replace the charging port of your W995 phone,this will definitely solve your problem,
If you need assistance in disassembling your phone,please get back to me as soon as possible.
Be cool..
Aug 15, 2010 | Sony Ericsson Walkman® W995 Cell Phone
My W995 won't hold it's charge. It will act like it's charging but only go up to around 20% charge but will not hold it.
will the charging piece if messed up, what i will do is and it always worked, I'd rap my charger wire around the phone when it is plugged in the phone so it holds, but thats the best way and it should work for along time, b/c it will cost more than the phone to fix this issue
Apr 08, 2010 | Sony Ericsson Walkman® W995 Cell Phone
My sony ericsson w995 does not charge when i try chargin it. The charger is fine because i tried it in my old sony ericsson and it worked fine but wont charge sony ercisson w995. How come
That only means that you got battery problem of your phone. Replace the phone battery with a new one. If your old sony ericson phone battery can be fit to your w995 then you can try to use it.
Hope this could help..
Mar 28, 2010 | Sony Ericsson Walkman® W995 Cell Phone
My sony ericsson w995 won't start,ive tried charging it...but all that happens is that the red light on the back flashes...ive tried everything,please help!
Very simple.Just follow this steps:
1. Connect the charger.
2. While the charger connected, open the back cover and close the cover again. Your phone can be switched on now. This is because this phone got sensor that ensure the back cover always closed while the phone operate.
3. If the above steps not working, try remove the battery while the phone is connected with charger.
~ Please encourage me to help people like this by donating small amount to my PayPal account.Thanks dude.
My PayPal id : ruzaini88@gmail.com
Feb 19, 2010 | Sony Ericsson Walkman® W995 Cell Phone
Nothing happens
The charger connection is sensitive on the Reflex Pro. It isn't uncommon to plug in the charger, see the light flashing, then when setting it down a slight movement of the cable stops the charging (light will stop flashing). Try connecting the charger again (if you haven't already) and let it charge for about an hour. While getting a good charge can be frustrating, it is worth it for the 4 minutes of fun to follow :-\
Aug 16, 2009 | Spinmaster Air Hogs RC Reflex Micro...
My sidekick 2 won't charge
mine stop charging sometime ago, and I switched to a nokia 3310 charger and its been working fine since. might be a little tight going in at first. good luck.
Aug 10, 2008 | T-Mobile Sidekick II
Sony Ericsson Walkman® W995 Cell Phone Logo
177 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
