Question about Brother IntelliFax-2820 Laser Fax
Brother intellifax 1250 will not copy or start to send - the copy stop and start buttons are dead
  • 7 Answers
SOURCE: BROTHER INTELLIFAX 4100
IF IT IS WHEN YOU SEND ITS NOT IN THE PRINTER SECTION YOU NEED TO CLEAN THE CIS UNIT BUT MOST LIKELY THE CIS UNIT NEEDS TO BE RERLACED
Posted on Oct 24, 2007
bowdo
  • 78 Answers
SOURCE: Brother IntelliFax 4100 sending solid black pages
It sounds like the CIS (scanner) has failed in both machines. Its no generally not a common problem. I would change one every six months if I was lucky.
It may point to something in your environment. I have have seen rust build up on the contacts of the scanner cause this problem. So if you have high moisture or are close to the ocean this maybe a problem.
Posted on Feb 14, 2008
leroyal
  • 2120 Answers
SOURCE: Brother IntelliFax-2820
What is your email address?
Posted on Oct 01, 2008
  • 159 Answers
SOURCE: Brother Intellifax 4100 unable to send fax but can receive
Is the fax sensing the paper you put in to send out? Check the little black levers that poke into the document area. They should move freely when you touch them gently with a finger, and return quickly when you take your finger off. If it can't sense the paper it won't try to send a fax. If, when the paper is inserted, the display changes from whatever it said to anything else, the paper is being sensed.
Let's try dialing manually. Just left of the 1 key is a button labeled "Hook." Pressing that will take the telephone line "off-hook," like picking up the receiver of a phone. You should hear a dial tone -- if not, try adjusting the speaker volume with the buttons just right of the numbers. Once you get a dial tone, dial a number, whether it's another fax, or your own cell phone. As far as the phone company is concerned, your fax is just a phone, calling another phone. If you can make a call, and the phone at the other end rings, we're closing in on the problem. If you can dial another fax machine manually, you can still turn this into a fax call, assuming there's paper ready to fax. After the distant fax answers, touch the Start button, and your fax should take over. If you can't dial manually, try unplugging your fax from the phone line, and replacing it with a regular phone. Can you make calls with it? If not, the fax is no longer a suspect - you have a phone line problem.
Are you at a business where you need to dial 9 to get an outside line? It's easy to forget that detail when you're using a fax, but it has to dial out just like any other phone on the system.
If you can't get a dial tone at all with the fax, but it works with the phone alone, the main board in the fax is probably bad. If you can dial manually, using the Hook switch, but the same number doesn't work when you dial xxx-xxxx-Start, that sounds like a main board problem, too.
Posted on Jun 11, 2009
  • 68 Answers
SOURCE: Brother Intellifax-2820, will not print incoming
You need to make sure that your machine is set to "FAX" mode,not"PHONE"mode and that it is in "AUTO"receive, not "MANUAL"receive mode.
Posted on Oct 05, 2009
We have the Brother Intellifax 4100E. It was working fine up until last week. Then it started not receiving faxes. We can copy, and send faxes, and receive the confirmation. I have checked the mode button...
Try calling the fax machine from your mobile and see if it picks up or if anything shows up on the screen of the fax machine. Is it possible that you have plugged the fax machine into the wrong telephone line? Try sending a fax to your mobile phone and see that the number is correct.
Mar 07, 2011 | Brother IntelliFax-4100e Fax
Unable to send or receive faxes
Fios is the problem. All fax machines are analog devices.
Apr 14, 2010 | Brother IntelliFAX 3750 Plain Paper Laser...
CANT SEND JUST RECEIVED. WHEN WE TRY TO SEND NOTHING HAPPENS AND INTELLIFAX 4100 BROTHER SHEET COMES OUT.
The same thing just happend to me. Check all the buttons on the machine and make sure there isn't one that is stuck. My "Fax" button was jammed and I didn't even know it. As soon as I wiggled it loose everything started working again.
Mar 15, 2010 | Brother IntelliFAX 4100 Laser Fax
I cannot send or copy MEMORY IS FULL
Press Menu/Set, 2, 5, 1.
Press ▲ or ▼ to select Off.
Press Menu/Set.
Press Stop/Exit.
Jul 30, 2009 | Brother IntelliFax-2820 Laser Fax
May the tellifax be used for copying only?
http://www.brother-usa.com/manuals/default.aspx?ModelID=455&ProductGroupID=2
This is the link to the manual, and yes you can make a copy, put your original in as you would to send a Fax, but press the copy button, and then the start.
Hope this helps
Ed
Apr 14, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Able to receive fax but cant send
sleep mode is just a status of the machine when it is in idle mode.you cannot turn this off however you can delay the time before the unit goes into a sleep mode.it has nothing to do when you are sending out faxes.so here are a few things you need to check when sending a fax (1)dial tone by pressing hook/hold button (2) insert the doc into the adf, make sure it will change to "enter fax # and start,or copy press copy (3) dial the number (4) wait for fax tones of the receiving unit before you press start. now if you can hear an operator on the line,that has to be verified with your phone company since brother machine does not restrict incoming and outgoing faxes UNLESS that is restricted from your phone line.
Nov 18, 2008 | Brother IntelliFax-2820 Laser Fax
Brother intellifax 4750e
if the copy comes out black and/or sends black the Contact Image Sensor in the scanner may be needed.
Hope that helps...
Jun 17, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother Intellifax 2800 Plain Paper "NO DOCUMENT"
no document mean that there is not paper in the paper feeding
Aug 29, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
27 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
