Question about Epson Stylus CX6000 All-In-One InkJet Printer
Paper will load about two inches and then will go no further but sounds like it is trying.
Replace all ink cartridges and reload software
Posted on Nov 14, 2009
Paper Jam when paper loads into machine from paper tray about 2 inches in when printing. Then it tells me there is no paper, load more paper? All the while I am hearing a sort of screaching sound when it...
It probably needs to be cleaned. There may be bits of paper stuck in the mechanism. In addition, if the printer is old or has been used a lot, the rubber on the feed rollers may need to be cleaned and roughed up a little bit to grab the paper more firmly when feeding it through. Also, when you load paper, don't load too much, and flip the sheets in the ream before you insert the paper to allow air to get between the sheets, making it easier to feed a page.
Nov 19, 2017 | Brother MFC7360N AllInOne Laser Printer
Code PC Load A4
This means that the printer is expecting A4 paper rather than letter size or whatever you are trying to use. Check your "Printer Options" on your computer and make sure that the appropriate paper size is selected. A4 is an international standard paper size that is 210 mm (8.27 inches) x 297 mm (11.7 inches) and therefore is just a bit narrower and longer than the American "letter" paper size.
To correct this, cancel the print job currently in the printer's memory, change the computer to the proper paper size, and send the print job again.
Jan 26, 2014 | HP LaserJet 4 plus Printer
Receipt printer paper reduction isn't working
Power the printer on and press the Paper button to see if paper will load.
If the paper doesn't load, make sure the paper isn't curled or creased, isn't loaded above the arrow on the left edge guide, and that the paper isn't jammed in the printer.
Take the paper stack from the tray; fan it before attempting to print.
Make sure the paper stack is leaning against the paper tray and not standing straight up in the tray.
If the Paper Out light is on solid, reload the paper, making sure the paper edge guide is adjusted to fit the paper's width, and then press the Paper button again to see if the paper will now load.
If the Paper Out light is flashing, turn the printer off, reload the paper, turn the printer back on, and try pressing the Paper Feed button again to see if the printer will now successfully load the paper. If the problem persists, power the printer off, remove the printer cable, and make sure all of the packing materials are removed.
If the problem is not resolved, contact Epson's technical support for further assistance.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
Dec 10, 2012 | Epson TM-T88V (Part C31CA85081) Power...
IMy wife pulled the paper tray completely out of
Loading your paper
Paper loading tips:
● Load paper with the side to be printed facing down.
● You can print photos and documents on a wide variety of paper sizes, from
8 x 13 cm (3 x 5 inch) up to 22 x 61 cm (8.5 x 24 inch). The 10 x 15 cm
(4 x 6 inch) photo paper is available with and without tabs.
● Before loading paper, pull the Main paper tray out (use the Main tray release or
the tray grips) and slide out the paper-width and paper-length guides to make
room for the paper. After loading paper, adjust the guides to fit close to the edges
of the paper without bending the paper. When finished loading paper, push the
Main tray back in all the way.
● Load only one type and size of paper at a time in the same tray.
● After loading paper, extend the Output tray extension to catch your printed pages.
Use the directions in the following table to load the most commonly used paper sizes
into the printer.
Paper type How to load Tray to load
Any supported
photo or plain
paper media
1. Extend the Main tray by
pulling it out with the Main
tray release or the tray
grips.
Load the Main tray
Chapter 2
(continued)
12 HP Photosmart 8200 series
2. Slide the paper-width and
their outermost positions.
3. Load paper with the side
Check that the stack of
paper is no higher than
the top of the paperlength
guide.
4. Adjust the paper-width
inward until they stop at
the edges of the paper.
5. Push in the Main tray all
the way in.
6. Make sure the light on the
Photo tray button is
turned off to enable
printing from the Main tray.
Load paper and adjust guides inward
1 Paper-width guide
2 Paper-length guide
1 Push the Main tray all the way in
Aug 03, 2010 | HP Photosmart 8250 InkJet Printer
Printer error to insert paper face down.
Have you tried cleaning the rollers, or resetting the printer? See here. For loading paper instructions, see also here. & here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 26, 2009 | HP Photosmart C5180 All-In-One InkJet...
Paper tray position
No, it sounds like you are doing fine. The machines are shipped with the paper tray in a "closed" position and they have to be expanded slightly (using the buttons on the bottom of the tray) to fit A4 size paper. The tray will then poke out about about 3 inches from the front off the machine as you described...this is quite correct and normal.
Jun 12, 2009 | Samsung CLP 300 Laser Printer
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
CANNON MP210 e3 SHOWING BUT NO PAPER JAM, C LIGHT FLASHING,B AND LIGHT ABOVE ON,PAPER GOES IN FIST INCH, MACHINE SOUNDS AS THOUGH PRINTING
I think it is not loading paper correctly. May be something struck in the way of roller. Or may be due to insufficient paper.
Another reason may be cover not closed completely.
Let me know if you need further assistance.
Regards
ELLIN
Sep 20, 2008 | Canon Office Equipment & Supplies
HP Photosmart C6100 All-in-One
Just click below;
Set Up the Printer Hardware
Remove packing materials, check contents of the box, connect the power cord, set the menus, load paper, and install the print cartridges. s.gif » Product Specifications
Minimum system requirements, connectivity, print cartridges, specifications for print, copy, paper, print margins, paper tray capacity, memory card, scan, physical size, power, and ... s.gif » Printing Instructions for 4 x 12 and 5 x 7 Inch Paper
Generic printing instructions. s.gif » Creating Borderless Photo Prints with the HP All-in-One Software
... 4 by 6-inch photo paper with tab (snapshot paper) ... Remove the paper from the paper tray and load the snapshot paper. Insert tabbed paper with the perforated, tear-off ... Click Photo Prints . The HP Photo Prints window will appear. ..
hope this may help;
Regards,
VOTIT
Jul 31, 2008 | HP Photosmart C6100 All-In-One Printer
HP C3150 Printer Continuing Paper Jam Errors
Sometime the ink jet mechnism is out of time or it gets stuck in the lock position. You might want to see if it looks like there crooked in the trays at the end of the printer.
Jul 04, 2008 | HP Photosmart C3150 Printer
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
37 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
