Question about Sharp Office Equipment & Supplies
After changing toner on my sharp, SF-2022 copy machine, the copies are coming out with black smudge marks across the paper? how/where should i clean?
  • applegte Nov 20, 2009
    ok, thanks for the tips, but where/how do i clean the drum, etc.? where would that be located? also im not sure that its using to much toner because the printed texts are light its just these weird black like smudge looking streaks going across paper, kind of like a picture thats been developed with bad exposure, i guess.
  • Sharp Expert
  • 257 Answers
This means the machine is over-toning ie using more toner than required caused by either improper toner or different brand of toner. The correct toner is sf 222T1. Replace developer and use the right toner and clean the drum and its blade. You may need to clean fuser rollers for cleaner copies.
Posted on Nov 20, 2009
  • Anthony Karuku Nov 26, 2009
    This shows you are not a technician. Please look for technician to fix it if you will get difficulty in following the following process.
    How to replace drum on sf 2022
    1. Open front cover by pulling it with two hands
    2. Pullout the developer unit
    3. Remove the front cover up and lower clips and pull it out
    4. Remove the waste container
    5. Unscrew the green screws you will see on the drum holder and pull out
    6. Unscrew the two green screw and remove the metallic lever and pull out the drum
    7. Wipe the drum with a clean soft dry cloth and its blade. If worn out replace a new drum and blade.
    8. Reverse the whole process to install again.
    President:
  • Sharp Master
  • 990 Answers
Hello sir; It's time to replace drum blade at lease, or you have to replace drum and developer,
Posted on Nov 14, 2009
Leaves black marks on copies
It could be leaking toner from the recovery area that sis on top of the dum, it removes any toner that was not transfered to the paper. You would have to remove it and empty out the toner.
Dec 11, 2012 | Toshiba e-Studio 232 Black and White...
Black lines on copies and on drum
There are a few things you can do to troubleshoot this problem.
  1. Be sure you are using new, clean paper
  2. Clean the copier's paper rollers, the marks may result from a dirty roller mechanism.
  3. Clean the copier bed's glass plate, smudges manifest themselves in the final copies.
  4. Clear any excess toner that has spilled in the toner cartridge chamber. Remove the cartridge, set it aside, then clean the compartment.
  5. Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy
If all else fails, try turning down the darkness of the copies in the settings, this can occasionally lead to lines and marks.
Feb 28, 2011 | Brother MFC-8460N All-In-One Printer
I channged toner in my sharp sf-2022 copier, now i have black smudge-like marks going across paper & the copys are real light begin to fade 1/2 way thru page? cleaned 1 of the rollers, helped a little...
Open front cover, you will see yellow knob, pull it down and pullout. Wipe the side with mesh with clean cloth and insert back. That's the main charge unit.
Pull the green lever to the left and pullout the transfer charger . Wipe the two wires carefully not to break them and insert back.
Do not try to remove the drum if you have no skills otherwise this should solve your problem.
Dec 10, 2009 | Sharp AL 1631 Copier
Smudges on paper and then when it does copy, ink is light.
hi,check copy cartridge or clean corotron wire.try to increase toner.send me result.
thank you.
May 25, 2009 | Sharp AR-5320 Black and White Copier
Toner can be wiped off after copying - smudges
Hello sir; This problem caused by fuser roller and presure roller in heating unit, you have to take apart check it out, may be bushing broken.
Feb 18, 2009 | Ricoh Aficio 2022 Black and White Copier
Copies come out of machine with huge black smudges
If the smudges are consistent, (roughly the same size and approximately in the same location on the page) it's your drum. If not it's your fuser.
Oct 09, 2017 | Computers & Internet
PC-65 (Canon copier)
A smudge across the copy can be in many different areas.
Some ideas.
The drum cleaner may be the problem as you indicate.
It may be a piece of paper ripped of dragging across the surface of the paper causing the smudge.
Also the fuser roll coating may be very worn and causing that.
One thing to try that can show you if the defect is on the drum cartridge, is start to run a copy, After the paper feeds and this is timing, shut the machine off when you think the paper should be about half way through the copy cycle, then see if the copy defect is on the unfused page, If it is smeared before it reaches the fuser, it is in the cleaning section, if it is not smudged, then it is most likely the fuser rollers are needing replaced.
First look for a paper fragment in the path, step 2 is to shut the machine down in mid copy and see if the defect is there.
The fuser is the hot area of the machine in the exit area, If you can take a flash light and look in there and see if you observe wear or heavy toner buildup on a roller then obviously thats the problem.
Jan 02, 2008 | Canon C130F Black and White Copier
My sharp sf 2022 machine, i need solution
mr engineer please check the drum mark sensor and clean it and also check the check the toner motor connector and do this program    c interrupt 0 interrupt ,44 copy key 07 copy key after stoping the machine off and then on but first clean drum unit maintenance code is 20 then copy key and then three times ca ca ca
Oct 18, 2007 | Sharp AL 1631 Copier
382 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
