Question about Kenmore Dryers
Dryer Belt Replacement Sears 80 Series Model: 110.8867291
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Posted on Nov 14, 2009
4 Suggested Answers
smartr10U
  • 1305 Answers
SOURCE: belt replacement
Visit youtube.com and type in Kenmore dryer repair. You'll find step by step instructional videos to service your unit.
BUT.... You've probably burned a belt, but this may only be a symptom of another problem. Something caused the belt to freeze up and burn on the motor pulley.
Check the roller bearings while it's apart... Make sure that the motor's turning free and all related rollers, pulleys etc are in good shape... save yourself from having to open it up twice..
Good luck and let me know how it goes.
k
Posted on Jun 22, 2009
hunter19_46m
  • 7482 Answers
SOURCE: belt size
Try these two websites, I believe they will have what you need.
Good Luck,
Hope this helps
Posted on Oct 28, 2009
  • 1122 Answers
SOURCE: I have a Kenmore 110 60812990 80 series dryer
bad heater box fuse,get the model number from inside the dryer door,and go to your local appliance parts store and give them the number and they will get you a thermal fuse kit,remove the back of dryer and you will see the heater box on the right side
Posted on Feb 03, 2010
Kenmore 80 series dryer where is the model number?
It is most likely inside the door, there should be a model number stamped
Dec 01, 2013 | Dryers
Does a kenmoore 80 series have glides
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-PYE2300AYW/3048/0151200?pathTaken=&prst=0&shdMod=PYE2300AYW
go here and you can see the parts in your dryer,if the model isn't a maytag pye2300ay then just put your model number in there and it will show you,kenmore doesn't make anything,you go by the model number if it starts with 110. it's a whirlpool,if say 417. it's frigidaire made but the maytag model you sent has rollers and i would say if you have a kenmore 80 series it has rollers,you can buy a kit that comes with the rollers,belt and belt pulley
Nov 14, 2013 | Maytag PYE2300AY Electric Dryer
I have a kenmore 80 series 110 dryer. The drum will not turn on its own but will by hand. It still heats and sounds like the motor is running
the belt has come off or broken, you more than likely have a Whirlpool dryer which Sears places the Kenmore name on, click this link to see how to get it a part to inspect the belt http://www.applianceaid.com/wpdryer_how-to.html
Sep 10, 2011 | Dryers
I have a Kenmore Electric Series 80 Dryer that the drum inside won't turn but it heats up and smells hot like something is burning. I can however turn it manually.
Remove the top and the front panel to remove the drum after you purchase a belt and teh idler pulley that Sears selles for your dryer. The pulley's bearing has froze up causing the belt to burn up and falling off
Jan 22, 2011 | Kenmore Dryers
My sears kenmore 80 series dryer does not turn on. i can hear the timer.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 19, 2010 | Kenmore Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
How do i get to the drum belt on an 80 series kenmore dryer
You do the belt from the front. It involves removing the top so the front can come off to get the belt around the drum. eric
Jun 11, 2009 | Dryers
Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Feb 20, 2009 | Kenmore 73952 Gas Dryer
Kenmore Series 80
You can find an exploded view at Sears Parts Direct, as well as get P/N's for the parts needed. I suspect the roller assembly came apart which caused the belt to fail.
You will need your Model number to locate the exploded view. If you can not figure out the routing from that, then order the service manual from Sears. It will show the routing and describe how to assemble and test most all aspects of the appliance.
Jan 15, 2009 | Dryers
Dryer wont turn
Yes, it will save you alot of money and work just fine. You will have to shut off the dryer, turn off the gas and/or electric(disconnect it to be sure it is power free). Look at dryer carefully as you may be able to access the belt from the lower front. The belt is easily available at Sears Parts Stores. Do not use it until fixed as it might overheat!
Dec 09, 2008 | Kenmore 63942 Dryer
Dryers Logo
144 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
