Question about Apple Audio Players & Recorders
My itouch plays one song then wont play any more ~just sticks on the one!
  • 281 Answers
This can be caused by corrupt media files being put on your itouch, or by not having the right format of song.Make sure you got all your songs from itunes, or at least had itunes convert all your music before you put it on. Try restoring your unit through itunes, and see if this fixes your problem. If none of these fix your problem it can be a system board issue.Contact Apple to see if your unit is under warranty with this site: https://selfsolve.apple.com/GetWarranty.do
The serial number can be found on the back toward the bottom of the unit.
If you have any further questions feel free to contact www.wiredextreme.com.
Posted on Nov 15, 2009
Itouch speaker playing while headphones are connected.
1> Disconnect the ear buds from the itouch
2> Reset the ipod - by holding down the sleep wake button and the home button at the same time until you see the apple logo - the ipod will reboot
3> reconnect ear buds mace sure they are flush with the top of the unit ( no gaps )
play a song to test
**If it is still playing out of both - call apple for repair or go to apple store
May 10, 2010 | Apple iPod touch
Tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
Ipod 120 g classic will not finish a song or it will reboot
I had the same problem with a 30gig classic.
The songs would play fine on my wife's itouch.
I tried every suggestion I could find No luck.
I installed media monkey and use it to load my classic EVERY SONG PLAYS FINE. Using the same songs in iTunes they stopped playing completely .I didn't have this problem using 7.5 iTunes but the iTouch needs the newer version
Feb 28, 2010 | Apple iPod MA446LL/A MP3 Player
My itouch skips songs while it's on shuffle
All ipod devices track how many plays each song has. When in shuffle mode, the songs with more plays are in turned played more often. This can result in some songs playing multiple times while others are skipped;
//halfs
Feb 16, 2010 | Apple Audio Players & Recorders
Every time i go to play a song on my itouch it pauses the song autamatically and will not play any videos or songs on my ipod it will not play anything on you tube it automatically pauses the audio
PLUG IT INTO YOUR COMPUTER THEN ITUNES WILL POP OUT THEN YOU GO TO RESTORE AND IT WILL ERASE ALL YOUR MUSIC THEN YOU ADD NEW ONES THE SAME THING HAPPEN TO ME AND NOW IT WORKS... :)
Feb 07, 2010 | Apple iPod touch
My Ipod classic 80G has stopped playing music. what happens is after I select and then press play it will have the play sign on the top, but the song wont starta and after a few moments it then starts to...
Make sure that you got all of your songs off of itunes, or that they have been converted through itunes correctly. This is caused by songs being the wrong format, or that the song itself is corrupted. Try restoring the unit through itunes, and loading the songs back on. If you are running with your unit while trying to listen music this can also cause the unit to freeze up when playing a song. Any type of continuous motion can cause your ipod to not play songs. This is because the ipod has a hard drive inside of it, and when you move alot with a hard drive it cant read correctly. If you want to run with your unit, i would suggest getting a flash drive based mp3 player (ie itouch). If you have any further questions feel free to contact www.wiredextreme.com.
Nov 14, 2009 | Apple iPod MA446LL/A MP3 Player
I pod stopping mid song
change song play off Intro
Mar 18, 2009 | Apple iPod touch
ITouch replays same song over and over unless manually forward
Did end up fixing this by doing a reset of the settings on the iTouch. Working fine now.
Feb 02, 2009 | Apple iPod touch
Docked itouch emits song, but nothing through logitech speakers
Talked to both Apple and Logitech, and uploaded newest firmware ( had assumed since this was a recent purchase it had same), presto, it works.
Jan 29, 2009 | Apple iPod touch
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
