Question about Ovens
Where is this Hi-limit switch located on this oven!!!!!!Maytag MER5755QAS
Can someone please tell me where to find the Hi-Limit switch on this oven? We have replaced the element and checked the oven sensor which seems to have power. I really believe it is this switch but I follow the wiring diagram and see nothing!!
  • 833 Answers
SOURCE: SMEG CC92MFX5 STAINLESS STEEL SIDE BY SIDE OVEN
Two things sharyn, first check the breakers. It is possible that one of two that control the stove tripped...they are in tandem. Shut them off and back on. If no fix: You'll have to remove and test the element. (if more than one element is involved here...it might be the thermostat) Breakers off, pull the element out and have someone take an ohm meter and test the unit. Still no good? Then it will be the thermostat or relay. Let me know what you find.
Posted on Dec 07, 2007
SOURCE: Dacor Oven
Depending on your model it is usually at the top behind the "grill" of the oven that is not working. Take out the screws aournd the oven latch (usually for cleaning) and slide out the grill. The limit switch is either over the latch or to the side. If it popped, just put it back with a screw driver. If that is not the issue, then it it could be a bigger issue.
Posted on Nov 20, 2008
Maytag317
  • 1136 Answers
SOURCE: maytag electric oven - MER5770AAQ. lower heating element not work
Hi, Unplug the oven and remove the element to test it. Check the element and see if there is continuity. If the element is open, replace it. It can be bad even tho it doesn't appear bad.
I hope this helps you.
Vic
Posted on Jun 20, 2009
  • 14 Answers
SOURCE: high limit switch trips and needs re-set
After grilling or cooking at higher temps leave the oven light on so the cooling fan continues to run for approx 1/4 hour, or whatever setting will keep the fan running...
Posted on Apr 22, 2010
vetteman3002
  • 2299 Answers
SOURCE: I have a maytag mer5755qab
It is possible that when the element blew that the control board blew and is what caused the element to blow the chunk out of it. You might want to check for any voltage coming from the control board.
Posted on Nov 30, 2010
How can i tell if the hi limit thermostat in my maytag wall oven is bad
test with a multi meter on each end of the wire prong connector, place each end of ur meter prong on both 1 and 2 of the connectors, and test for continuity ohms or a close circuit. have ur meter on a low ohms setting as the level of ohms is low. if it shows an open circuit or no continuity, its defective. Infinity is the meter not showing anything like a number 1 and not moving?
Apr 26, 2015 | Maytag MEW6530DDW 30" Electric Single Wall...
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Will not heat after clean cycle, got code but it did not return after being cleared by wife who does not remember code except for the letter F. Element or thermostat how do you tell which is the problem.No...
Hello, welcome to FixYa.
It sounds like the hi-limit safety thermostat may be tripped, that is the component that typically trips/activates during a self clean on many wall ovens & ranges.
Unfortunately you'll need to pull the oven from the cabinet to gain access to it.
If you pull/slide the unit away from the wall and unplug it you can replace the hi-limit...you will likely require two people or if you have a couple of "saw horses" or the like to slide it onto.
It will be a non-reset type hi-limit (based on the model number you posted) so needs to be replaced as I mentioned, doing so will get you back up and cooking in no time.
**Unplug or turn off the breaker of the wall oven first of course...safety first**
Once you remove the panel you will need to look for a switch/thermostat which looks like this...
Replacement part number is typically $30-$40US. # 3879224 and available on-line at vendors such as "appliancepartspros.com" "repairclinic.com" or "searspartsdirect,com" to name a few.
Let me know how you make out. Good luck. I'll watch for your reply and if you need anything further I'll be glad to help in any manner I can.
Regards,
Macmarkus :)
Sep 09, 2011 | KitchenAid KEBC147 Electric Oven
My home oven: Jenn Air W30400-C wall oven, built in 1996. Problems: ERC display gradually went away, along with ability to heat oven. I have replaced the capacitors on the ERC board, that has restored...
Hi haiste,
This problem only means that you have a bad ERC that needs replacement. You may order the part from Sears, call them at 1-800-252-1698. Just get your model number ready and they'll help you get the new ERC. Once delivered, it goes with the instruction on how you will replace.
Hope this helps.
Thank you for using FixYa.
Aug 24, 2011 | Ovens
Turbo chef is not heating up, coming up on it reads, f8 low heat
the problem with f8 like you have said LOW HEAT
, IF the oven does not warm up in time , which is usually 8 min , it goes into f8 fault code
now please check the hi limit button , on the back of the oven , left hand side, bottom corner, if it reset and starts heating, please check bottom element and temp reading IR , IF it rises very quickly and the elemnt is glowing red , please switch off the unit at the power point , you have problem with the solid state relay, if the temp is slowly rising , then you might only have an issue with the hi limit reset button thermostat, FIRST JUST CHECK THE RESET BUTTON
Jul 03, 2010 | TurboChef C3 Single Oven
Thermador oven sc302 no heat
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
1.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
2.
3.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
Mar 05, 2009 | Thermador C302U Electric Double Oven
Dec 07, 2007 | Smeg SE250XUK Stainless Steel Electric...
HOTPOINT ELECTRIC STOVE
two things---when you open the oven door do you see a button on the right or left side?if so thats a door switch and if its bad you will get no voltage to the element.the next thing is your hi limit is bad.this is a sensor that monitors the temp of the oven and if its bad you wont get any heat.some hi limits reset themselves others you have to manually reset them.let me know.
Jul 30, 2007 | GE JKP15 Electric Single Oven
Smeg single fan oven
You are right, it could be a thermostat or a heater problem. You should check that the heater element receive power. In case it receive power,the heater element should be replaced. In case it doesn't receive power, the problem is with the thermostat. In any case, check as well that all wires connected to the thermostat and the heater are in place. Good luck.
May 02, 2006 | Smeg SE250XUK Stainless Steel Electric...
Ovens Logo
168 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
