Question about Craftsman 4 Cycle Blower/Vac
I have a craftsman h horse chipper/vac and i cant
I have a craftsman 5 horse chipper/vac and i cant get it to stay running. it fires and runs for a second but then dies. what can i do
  • 486 Answers
Focus on the carburetor main jet.
On a float bowl carburetor, remove the bolt holding the bowl to the carb body. This is the main jet, clean the jet with spray carb cleaner, and also spray upwards into the center of the carb.
I have listed some basics to double check, not all may apply to your application. If you need more detail let me know. rwvanlue
Fuel Related issues that take a certain amount of time to appear
Depending on make and model of mowers:
a) Fuel tank outlet plugged (some have a screen filter,
some are 90' angle and plug with rust and debris inside the corner of fitting)
b) Fuel lines collapse when they are routed thru fasteners and between frame and seat decks
c) Fuel cap vent clogged
d) Fuel filter clogged
e) any fitting that has an orifice that can trap debris or rust will eventually become clogged
f) fitting on the side of the carburetor
g) some systems have a filter inside the line at the opening of the carb inlet
h) fuel pump
i) vacuum hoses to fuel pump
j) debris under inlet needle/seat on carb
Posted on Nov 13, 2009
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
I have a troy built chipper vac that starts but won't stay running it has gas and new spark plug
How old is the fuel in the tank and also look into the tank for water from condensation. If the gas is older than 2 months drain the tank and the carb bowel.
Nov 06, 2015 | Troy Heavy Machinery
I have a Craftsman 5HP chipper that dies within a few seconds of starting. Once it starts, I have to open the choke all the way to keep it from dying. It then revs up to extremely high rpm, then dies. ...
Hello, Check the float bowl for water. The gas can could have introduced water and is holding the float in the up possition not allowing enough fuel to enter the bowl to run correctly.
In either case you have a fuel restriction or a lean condition due to too much air.
hop this helps.
Feb 06, 2011 | Craftsman Heavy Machinery
Chipper/ Shredder runs for while on the amount you primed the eng
Check to be sure there isn't a small hole or crack in the priming bulb. If there is it allows air to enter fuel line, loosing the prime. Most have a collar that unscrews to remove it.
Jul 18, 2010 | Troy Bilt 24b - 060f766 5hp Chipper...
Mower dies when put in gear
have you checked the mower bed to see if its free to turn over,,if the bearings have sezed up or are tight this loads up the mower engine
Jul 05, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Need a leaf bag for a chipper/shredder/vac
That is actually a good price. MTD wants $225.00
Oct 04, 2009 | Craftsman 4 Cycle Blower/Vac
5 HP troy bilt chipper sherdder will not rev up under load
Either or do one of two things if the motor runs pretty well Start the engine and run it full throttle. Once there if it has a high speed jet turn the screw in to start with until the engine stumbles a bit and then turn it back about a half turn. When you turn it in you should here the engine peak out. .If it is blowing black smoke out the exhaust it means the high speed screw is to far out so turn it in until it smooths out.If the engine smooths out then you have cured the problem. Good luck.
Mar 18, 2009 | Troy Bilt 24b - 060f766 5hp Chipper...
I have 9 hp Craftsman chipper vac with a manual pull start I want to upgrade to an electric start What is involved? Is there a kit to do this?
If it has the option of electric start all you need to do is puchase the starter from Sears and bolt it on. No to hard at all. But for a more definite answer you need model and serial #'s
Kurt
Mar 18, 2009 | Craftsman 6.5 Hp Chipper Vac
Craftsman 6.5 Chipper vac
I have the same problem with no manual. You can go to managemyhome.com. & type in your model number & if it is in thier archives they will send a manual to you for free. Unfortunately they have not been able to find mine. Good Luck.
Nov 07, 2008 | Craftsman 6.5 Hp Chipper Vac
Craftsman 4 Cycle Blower/Vac Logo
121 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
