Question about RCA L32WD12 32 in. LCD HDTV
I have a RCA L32WD12 that suddenly turned off and on by itself. Now it will not turn on at all. The red power light is on, but the tv will not come on with remote or manually.
  • 11,361 Answers
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 14, 2009
Dry joins on the small pcb with the blue rele. On my Thomson 27LB130S5 with the same chassis (IFC130) and the same symptoms that solve the problem.
Posted on Sep 27, 2012
RCA L32WD12 will not turn on without several trys
Likely bad filter caps in the power supply---if you look inside and find this it may be a easy repair.
Dec 18, 2012 | RCA L32WD12 32 in. LCD HDTV
No power
Great link Ekse.
Keep in mind that those parts are pulled from TV and their life expectancy might be short as well.
I've fixed hundress of power supplies with the same failures, about 80% failed due to defective capacitors the other 20% is due to other components in the power supply circuitry.
Aug 08, 2008 | RCA L32W11 32 in. HD-Ready LCD Television
An RCA model L32WD12. will not turn on, what could be wrong
Hey folks: I found that the power supply in these rca L32wd12 to be full of open Capacitors as well as the relay card that has a SMPS circuit also to have bad caps. Replace all of these and this fixed the one I worked on. Remember all new caps are craps.
Jan 20, 2011 | RCA L32WD12 32 in. LCD HDTV
TV won't turn on!
The failure on these LCDs is mostly with a defective power supply. It appears like the voltage is not enough to make it work.
I repair these power supplies, let me know if you require further assistance. You can also write to jah2mil@hotmail.com for more info.
Oct 12, 2008 | RCA L32WD12 32 in. LCD HDTV
POWER WON'T COME ON
I have the same problem with RCA L32WD12
THIS TV IS ONLY A FEW MONTHS OLD HOW DO I GET SERVICE
JERRY
Sep 01, 2008 | RCA L32W11 32 in. HD-Ready LCD Television
RCA 32V434T Flashing Red Light
Flashing led..in protect mode..internal shorted component.
Aug 14, 2008 | RCA F32450 32" TV
RCA L32WD12
There is a small glass cartridge fuse located inside your tv. You must remove the back to access it.
Feb 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA L32WD12 32in. HGTV LCD Television
I had the same problem happen this afternoon, so I took it apart, and the source of the problem is the key controller panel (behind the buttons). It's held in place by 2 screws, if you take the case apart, which is literally only 15 or 20 screws, and then loosen the 2 screws holding the key controller panel on, and then use a small screwdriver to space it out from the button caps. Tighten the screws, and put it back together. Just be careful not to let it go too far to the other side, or you'll have a problem with the menu going on and off at random, which is just as annoying.
Nov 07, 2007 | RCA L32WD12 32 in. LCD HDTV
RCA L32WD12 32 in. LCD HDTV Logo
1,191 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
