Question about Kicker ZR1000 Car Audio Amplifier
When my zr1000 amp kicks on it automaticaly averheats and shuts off it is also hot to the touch what should i do
  • 28 Answers
One great amp !!! I would send it in to kicker. It looks like you may have one or more mosfets that are either shorted or on the way out. Does the amp have any protection lights that may give an indication of the source? Some thing that come to mind are: Shorted outputs, Speaker wires shorted or touching ground, power supply mosfet's
Posted on Nov 13, 2009
Trane twe036c140a1 blower motor kicks off and on and is hot to touch
if it has a capacitor id try replacing that first.
Jul 11, 2017 | Heating & Cooling
Yesterday by juicer kicked of the kitchen breaker? Twice.
You may just be overloading the circuit. Easiest correction - unplug something else that's running (or turn off a light) on the same circuit and see if the breaker still shuts off.
But wait - also important - was there any burning smell? If so, this is dangerous. It's a short circuit that occurs when a "hot" wire (black) touches another hot wire or touches a "neutral" wire (white) in one of your outlets. You should not use that outlet and have an electrician look at it. Or it could be a ground fault (similar to the short circuit - when a hot wire touches the ground wire on the side of a metal outlet box which is connected to the ground wire. For either of these, you need an electrician.
Apr 05, 2017 | Juicers
I have a Kawasaki 2006 zr1000 silver were do I find the right colour code Thanks
On my kwak (not a zr1000) the code is on a factory sticker under the seat.
Oct 15, 2014 | Motorcycles
Shut down automaticaly
Not much to go on, "shut down automaticaly" on battery or AC or both? A computer will shut down, or hibernate, if thats what you mean, that's a power setting? If a computer overheats it will shut down automaticaly to save the components from heat damage. If there is dust in the fan and vents it will shut down. If it is not getting sufficent air flow from vents on the bottom of the laptop through the vents on the side. One option is a Laptop Cooler.Is it shutting down when you are on it? When it's left unattended? Respod to this post for further assistance.
Nov 19, 2012 | Unknown Toshiba Satellite P755-s5385 15.6...
KICKER ZR1000 PROBLEM.NEED HELP PLEASE
Have you tried new rca jacks????? If not try them...If the problem persists, it may be the preouts on your stereo.....I have ran into that problem with a few stereos, especially pioneer.....thumping sound with the sound turned down, weird sounds etc.....If it still does it maybe try one of those line level converters.....(i used one in my last car when my preouts were messing up....)I just spliced into my rear outs
Apr 05, 2012 | Kicker ZR1000 Car Audio Amplifier
Amp kicks off after a few minutes of play. It will play again after a few minutes, but then kicks off again.
My best guess is that your over loading the amp. Check and see if the amp is hot when it cuts off. Most amps have a "safety" cutoff that will shut it off if it get to hot
Oct 26, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Kenmore Gas Dryer completely shutting off mid-cycle
sounds like you have a overload switch kicking out or its a thermofuse, or timer something is telling your machine its too hot or a thermofuse or some heat sensor....
Jun 08, 2009 | Kenmore Dryers
My koiler car amp shuts off and gets hot. when i shut off the car stereo and turn it on, it kicks back on and works till it gets out again.
Sounds like an overload...check the impedence of your speaker system and make sure that your amp is rated as stable at that impedence
Apr 12, 2009 | Koiiler XM-7676W Car Audio Amplifier
Kenwood amp kac-x401m
How long will the bass play before the amp kicks into protection mode and how loud are you listening to it? I've noticed with my amps that if they don't have enough air flow they will get hot and kick into protection mode. They will also kick into protection mode if you are running it at more than it can handle. Check your adjustments on both your amp and the head unit. Make sure you are not running more bass than the amp can handle.
Nov 04, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Car Audio & Video Logo
99 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
