Question about Mtd Yard Man: Trimmer Ym137 Electric 5.5 Amps Attachment Ready
I may have lost a spring and now my grass hog line
I have a 14 inch b&d grass hog trimmer. the line no longer comes out automatically. did i lose a spring? i cannot find replacement springs at the hardware store? how can one also put line in yourself when you run out of it. thanks michele
2 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: trying to replace ext spring on lawnflite 548
You don't specify which spring but if you take a piece of starter cord, tie it in a loop and hook it on the loose end of the spring, put in a long screwdriver, a piece of broom handle or anything similar, it will give you a lot more leverage to pull the spring. Once you get it to where it needs to go, you can maneuver it to get it hooked then just cut the rope and pull it out
Posted on Sep 15, 2009
Grasshog gh600
grasshog gh600 I'm not a pro; by know means but could be that it could be warp in the wrong direction,frist or may be a spring or something was left out.
Sep 03, 2012 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
The nylon thread has worn down. How do I get more of it to come off the spool which is still full?
Hi cmlontg152...
You will have the grass hog running and then bump the turning head on the ground and it will automatically feed out the line, the more you bump it on the ground the longer the line will be...don't make it too long at a time...only what you need.
Please take time to rate me
Jul 08, 2011 | Black & Decker 14" Grass Hog Xp...
I need a new spring to replace the lost one that makes the spool advance. Its a Grass hog that is a few years old. Not battery powdered, but electric. Can yoy tell me where to buy one or what size...
They have upgraded the old string heads (type 1) to a new string head (type 2). They say type 1 is no longer available. Please see part numbers 20 & 21 in this 14" Grass Hog parts breakdown diagram. The new string head is relatively inexpensive. If you don't want to get one, could I suggest you take the old spring (if you have it) and match it up with possibly a new spring at the hardware store. Sometimes you get lucky! Here is the parts diagram for it. Hope this helps!
http://www.ereplacementparts.com/black-and-decker-gh1000-type-grass-hog-trimmeredger-parts-c-4167_9518_9532.html
Oct 30, 2010 | Black & Decker 14" Grass Hog Xp...
What replacement line is used for the BLACK & DECKER Grasshog. 5,063,673 5,620,336 6,443,753 6,443,762
For the cordless Grass Hog, the replacement spool is AF-100. You can purchase these spool heads online or maybe find them at your local hardware store, but they may be hard to find because the Grass Hog is not made any more.
Jul 13, 2010 | Black & Decker 14" Grass Hog Xp...
How to put together the CST2000 and install a battery
Which part of the Grass Hog did you take apart? If you mean the spool head, that is easy to reassemble. The actual spool (the round part with the line coming out) goes into the cavity on the bottom of the trimmer, with the line poking out of the hole in the side several inches (not enough to hit the plastic guard). Then the cover (orange with the spring on it) fits on top of the spool so that the spring pushes on the spool and the two tabs on the side snap into the holes in the trimmer.
Unless you took another part off, that should be all you need to do to reassemble the Grass Hog. Turn it right-side up and turn it on to make sure everything works.
Jun 01, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
The automatic line feeder dosen't work
You can have mine. It wastes line by feeding automatically way too often. Black & Decker sells Junk!
Dec 14, 2009 | Black & Decker 14" Grass Hog Xp...
I have bleck and decker grass hog auto feed and it does not work
There is a smalll white part below the spool called a "lever". This is likely in need of replacement. Call Black and Decker at 800-544-6986 with your Model No, and Date Code (stamped on the trimmer itself near where the extension cord plugs in). If it is still under warranty they will send you the replacement part - if not, I loooked it up and it's less than $3 for the part itself.
May 25, 2009 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
Mtd Yard Man: Trimmer Ym137 Electric 5.5 Amps Attachment Ready Logo
49 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
