Question about GE (GTS16BBS) Top Freezer Refrigerator
FROST IN FREEZER WATER IN REFRIGERATOR DOOR SEALS SEEM OK
  • GE Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorFROST IN FREEZER WATER IN REFRIGERATOR - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 02, 2010
The freezer is frosting only on the right side of this bottom mount model. We defrosted it and cleaned it out, even it was emptied at one time and unplugged. Then it frosted again, in the same manner. ...
the problem is in the defrost system . ck the defrost terminator/ heater and if they ck ok replace the adative defrost control.. if your want to save time then repl the terminator and the board and call it a day . .. this should correct problem .. mm
Oct 06, 2010 | LG LFC21760 Bottom Freezer French Door...
Freezer is frosting
Even frost free freezers will frost up in high humidity, especially if there is a poor door seal. Defrost the freezer by turning it of and placing pans of hot tap water in the freezer. You can speed this along by helping to remove the ice as it melts. Check the door seal after you've defrosted the freezer, a bad seal is one of the big causes of frosting up the next biggest problem is usually holding the door open.
If it's a frost free unit, if the problem continues you'll need to have it checked out.
Jun 19, 2010 | GE GSS25JEM Side by Side Refrigerator
In-door water dispenser not working. tried lowering temp in frig to thaw line. Worked, but now line seems frozen again. ice in icemaker holder seems to be thawing and freezer is accumulating frost/frozen...
Defrost the freezer completely. Make sure the doors are sealed completely when shut. After defrosting plug back in and make sure the fan and the self defroster is functioning (your owner's manual should tell you how to reset the defrost timer). the problem may lay within the defrost system, and/or door seals and/or interior circulating fan.
Apr 30, 2010 | Refrigerators
Water leaking ( not much , but regular) from bottom of both sides. Freezer section now frosted up. does unit need a service? have had a look online and this seems to be common problem and no real...
the most common reason for frost buildup/condensation is doors not sealing properly(doors out of alignment).
use a spirit level to ensure unit is level,leaning back slightly but not touching wall,adjusters are on feet on the bottom of the unit,then look along the doors to make sure all seals are tight.lastly even though they say frost free it is worthwhile doing a total defrost annually(leave the doors open)and wipe out with bicarb and dry thoroughly.before switching back on.
clean out vents/drains at the same time.
then if it goes wrong you know its gonner cost......
Apr 20, 2010 | Samsung 24.8 Cu. Ft. Side-by-Side...
My Maytag side by side has frost that develops on freezer side
almost deffinately door seal.try hot cloth to warm seal and pull into shape ,close door ,if you look down seal it should stick to door frame all round.no air leaks...
Feb 11, 2010 | Refrigerators
Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
Oct 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Frost is building up at icemaker. Everything else seems ok
Does your refrigerator have a make and model number? Sometimes the frost is caused by a leak in the seal around door or the dispenser door remains open drawing air into freezer.
Jun 26, 2009 | Refrigerators
Frost is forming in freezer of side by side
There may be a switch on inside of refrigerator to regulate the sweat on outside of fridge.Also,door seal gets stretched to prevent good air seal.Open the door and insert a dollar bill. Shut the door,the door seal should be tight offer enough resistence that dollar bill does not freely pull out of door.If it doesn't,replace door seal.Hope this helps. Gregg
Jun 05, 2009 | Refrigerators
Why does my maytag fridge drip water around the freezer door?
Freezer door frames have a small heating element in them to stop that happening. Your element is failed.
Torn gasket seals just cause frost inside, but also cause the compressor extra stress if the seal is bad. This causes the compressor to keep running as yours does. They are cheap to buy and easy to fit.
With a 12 year old one, it is probably time for a new one. The new ones are more energy efficient and are cheaper to run.
Mar 23, 2017 | Sub-Zero 650 / O Bottom Freezer...
Condensation problem hotpoint mistral 8596
if the door seals are both ok, check and see if she has any open containers in the fridge juice ect that may be allowing moisture to escape. a model number and serial nuber off the sticker in the fridge would help me with more ideas.
Sep 25, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
GE (GTS16BBS) Top Freezer Refrigerator Logo
77 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
