Question about Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door
Can't get it lit
It's a Napoleon fireplace. it has a plug to the wall. It has an on/off switch. it has a gas line attached to it. I can't find the space or slot to light the pilot or how to make sure the gas is flowing to it.
  • 80 Answers
Instruction on a metal plate inside the fp bottom door
the knob will have pilot/ on/off marked on it on gas valve, you have to line the pilot word up with the white mark on valve then knob can press all the way in, now press it in hit the res or black sparker button and you should get pilot falme in a few tries, once you see flame keep the button in on valve for 30 secs then release turn it to ON and turn youe switch on
Posted on Feb 06, 2010
Testimonial: "FP bottom door didn't make a lot of sense. It didn't look like a door. I had to tug hard on a lower shelf up front to open the pilot hatch area."
Serial# location GSS36
Contact Napoleon at 1-(800) 461-5581 and ask for a AUTHORIZED servicing distributor in your area. You can also go to www.napoleon.com, put in your zip code, and it will tell you who is and isn't an authorized SERVICING DISTRIBUTOR for your fireplace. I hope this helps.
Mar 10, 2014 | Napoleon Fireplaces Napoleon 36 Inch...
Napoleon Fireplace won't fire
I would suggest calling Napoleon at 1-(800) 461-5581 and find an AUTHORIZED SERVICING DEALER in your area to diagnose the problem. You can also go to www.napoleon.com, put in your zip code, and it will pull up who is and isn't an authorized dealer in your area.
The company I work for has been in the fireplace business for over 35 years. Napoleon is one of the brands that we have access to. The BGD36CFG is not a simple unit to diagnose. If you can not find a servicing dealer in your area I would call a licensed HVAC but always default to calling Napoleon first. There is no telling why the fireplace will not ignite. Below is the
Grandville 36 CF BGD36CF
Jan 13, 2014 | Napoleon Fireplaces Napoleon BGD36CFG...
FIREPLACE WILL NOT TURN ON
Yes and no......
If the fireplace wont turn on from that switch, Most likley a diffrent switch
Dec 19, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
My fireplace wont stay lit with the glass on the min i take the glass off it will stay lit i have a good vent and it is propain could it be that there ant enough gas presure it is a heat n glo 6000 the...
The reason this is happening is that the overload switch, which is part of the safety features has gone bad. That's why the burner will only light with the glass off. The orange color of the flame from the pilot flame is normal for propane.
Unfortunately, this is not a DIY fix. If you can find a qualified service technician, that's the best way to go. As, Heat-n-Glow fireplaces are a basic, builder box line. And as such, have some quirks that other, more expensive gas fireplaces don't have.
Hope this helps solve your problem.
Feb 18, 2011 | Heating & Cooling
Where can I get a napoleon gid3014n gas fireplace insert product manual
I emailed the manufacter and they emailed an attachment containing the installation instructions. The fireplace insert hasn't been made in 9 years.
Dec 23, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
Problem lighting gas fireplace
my fireplace lights up for a short time and goes out after 5 or 10 minutes, please help with this problem.
Dec 08, 2009 | Heating & Cooling
Help troubleshooting an FMI GL-850E Gas Fireplace
It sounds like the Ignition Control Module went out, as I've heard the vibrating noise you speak of just before the module "dies." You most likely have the gray Robertshaw control module box located under the fireplace connecting the power to the gas valve. You will need to have a Certified Gas Fireplace Specialist look into this issue and replace, if necessary.
Dec 07, 2009 | Heating & Cooling
Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door Logo
561 people viewed this question
Top Napoleon Pool & Spa Experts
John Rodgers
John Rodgers
Craig Butler
Craig Butler
Paul Carew
Are you a Napoleon Pool and Spa Expert? Answer questions, earn points and help others
