Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I have a Mitsubishi wd 52525 model shows no picture.
My tv display a flashing blue light allowing to barely see the menu. The lamp is new. So what is the problem?
  • ulyssespena Nov 13, 2009
    Yes after I get the lamp to go green the blue flash comes on and my menu settings are hard to read cuz of the blue flashing.
    Yes original lamp from Mitsubishi
  • 10,594 Answers
Is that blue light flashing problem started after lamp replacement in your Mitsubishi WD-52525 ?
Can you please post screen picture here that shows problem to diagnose it?
Thanks.
Posted on Nov 13, 2009
  • Shahid Electronics
    Shahid Electronics Nov 13, 2009
    Are you sure replaced lamp is Mitsubishi original and not an aftermarket or alternate one?
    Lamp replacement is very easy and simple that can not hurt TV boards/ parts inside.
    How was TV picture before lamp replacement? Did you get lamp message in TV?
    Thanks.
    OK, it sounds DM board is bad. Please call local tv tech to fix it.
    This is not user level repair and requires qualified tv tech.
    Thanks.
Flashing lamp light on mitsubishi 52525
The lamp cover is not installed properly or the lamp door switch isnt working thats what causes the 32 error.
Apr 08, 2013 | Mitsubishi WD-52525 52" Rear Projection...
I have a mitsubishi wd-52525 tv and just replaced the lamp but the picture does not look as bright as before. no settings have been changed.
Try "initializing" a "factory reset" power on the tv then on the remote "menu 1,2,3 enter". Start the reset to default and see if the new refreshed settings help.
Mar 03, 2012 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 52'' TV Model WD52525
U restart the tv,u hear alots of clicking?That mean the Ballast is dead or have problems,that why ur picture lamp not sustaning the picture.Replacing the Ballast might or will sustance the picture.
May 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
New lamp replaced but yellow lamp light is flashing
Go to this Website they will list all Parts/boards and everything you need for this TV
WEBSITE:
Encompass Parts Distrubtion 1-800-638-3328
Jan 16, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525
Normal 0 The Mitsubishi WD-52525 has a serious capacitor problem as discussed in this forum overseen by a Mitsubishi certified repair technician: http://www.hometheatershack.com/forums/mitsubishi/11703-problem-mitsubishi-wd-52525-scrambled-picture-no-picture-2.html. There has been a worldwide problem in computers and TVs over thepast several years with faulty electrolytic capacitors (from Taiwan) thatdecay, dry out, swell and die. The power supply is often the firstcomponent to go bad, but other systems also degrade over time. As theforum explains , this problem is widespread in these sets causing multipletypes of display problems after several years of use. On my set, I also got a blue screen with a lighter blue ball in the middle. Mitsubishi is awareof the problem and will cover most of the cost of repairing the chassis, evenyears out of warranty, but apparently ONLY if you get an estimate from aMitsubishi certified repair station and contact their customer support BEFOREdoing any work on the set. I just followed the recommended procedure onthat forum and Mitsubishi is covering half the cost of my $700+ repair when my3+ year-old set recently died and showed only this blue screen on all inputs.
Mar 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
http://servicemanuals.vstore.ca/
Sep 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wd 52525 error code 34 lamp abnomality
the capictor problem is mostly for WS models
you can locate the dm model from this link
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
