Question about Fisher and Paykel CT560QX 23 in. Electric Cooktop
Please advise how i replace broken plastic shaft to control knob (mounted on top surface0 of ceran F & p hob
I KNEED NEW KNOBS FOR MY SCHOTT CERAN BLACK GLASS HOB
The reference to Schott, is the maker of the ceramic glass itself. The label outlining the manufacturer and model number will be located on the base of the cooktop. Once you obtain that, contact the distributor to obtain the required knobs.
Nov 14, 2016 | Cooktops
Hob ceran replace with new induction hob
Need looking at by NEFF , a big job .
Mar 16, 2015 | Neff Cooktops
Bosch Ceran Schott hob. Number in top left corner
We have this exact same problem, and I've not managed to track down a manual (we rent and the landlord is on holiday).
I've tried holding down all buttons for a time, combinations of buttons, and turning it off at the mains, but no joy.
Did you ever solve this?
[submitting this as 'post solution' but there is no button for 'say you have the same problem'!]
May 27, 2010 | Bosch Cooktops
Black hob top cracked in two places and small part
yes but costly.have u tryed home insurance accidental damage.
Sep 14, 2009 | Cooktops
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
I need a user manual
I need access to the spark plug module for replacement. The plastic stove top seems sealed to the metal housing. How do I gain access? Creda GH 102 series cooktop. Spark Module Replacement.
Apr 15, 2008 | Cooktops
Baumatic B40 Gas Hob : Gas not staying on.
we have the same problem... try removing the knob, ours works fine without the knobs ????
Dec 19, 2007 | Baumatic 24 in. B40 Gas Cooktop
Whirlpool Oven, Ceran stove top
I want to say that since I posted my original problem with black spots appearing on the Schott Ceran top, I took pictures of the top and attached them to a complaint sent to Maytag. Approximately 3 days later, a Maytag representative phoned and offered a brand new top-basically stating that there is a fault with the tops. They would not pay for the labor to replace the top. My husband downloaded the instructions from Maytag website and installed it himself. These spots actually appear from within the surface and are not the result of a boil over, etc. The spots on my burner grew to the width of the burner. If you search the internet, you will see many others with the same problem with the Schott Ceran tops. I will never buy another!
Nov 20, 2007 | Cooktops
Fisher and Paykel CT560QX 23 in. Electric Cooktop Logo
51 people viewed this question
Top Fisher and Paykel Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Fisher and Paykel Cooktop Expert? Answer questions, earn points and help others
