Question about PC Chips M848ALU Motherboard
My Mm848a usb3 connectors have been knocked out their pins, they are all colour coded but the pins they go into have no markings, how do I know which pin takes which cable? Pin configuration is 5 on one side and 4 on the other but I only have 8 cables. 2 ground black 2 red 1 + 5v 1 yellow 2-d 1 green 2+d 1 blue 1+d 1 white 1-d Help
  • 329 Answers
As your cable color are not clear plz refer the following link and do reply back
http://www.usbman.com/Guides/BelkinMotherboard_cable_assembly.htm
Posted on Nov 19, 2009
Is the dell inspiron 580 a usb 2.0 or 3.0
I don't think your computer has USB3, because USB3 came after 2009. But that should not stop you from buying an USB3 hard drive. My computer did not have USB3, and I used USB3 drives, long before a bought a USB3 extension card. You always van connect an USB3 drive to an USB2 computer connector. Ans an USB2 drive to an USB3 computer connector. The slowest part in the chain, will dictate the maximum speed. But even with the USB3 drive, now on your computer, the computer can't use the full speed, but if you buy a new computer, the same drive can be used on a much higher speed.
I did put in a USB3 extension card, but it did not help much. My internal computer buss is slowing things down, so even my USB3 drives, most of the time only reach 35 Mbyte/ second. A speed USB2 could reach too. But connecting my drives to newer computers makes them almost 3 times as fast. And with the file sizes I'm sometimes have to put over, that really makes a difference.
Oct 30, 2014 | Dell Inspiron 580 Desktop Computer (Intel...
Can't find the second set of pins for my USB drive
According to the manual, if you have front panel USB, use the pin set labeled USB3 for these connections. The USB3 connector is located between PCI slot 1 and 2. If you are already using this for the connector labeled 1394....1394 is for FIREWIRE interface and this mainboard does not appear to support it. Be careful of that connection unless you are absolutely sure of yourself.
Dec 25, 2011 | EliteGroup K7VTA3 V6.0 (K7VTA3_V6.0)...
Which connectors are used for front panel, power on (red @white) and led ( blue @ white) please show a close-up view
On the motherboard the pinouts on the front panel should be colour coded, and marked with letters like in this picture >>>>>
The connectors are also marked corresponding to where the connect on the motherboard, like in this picture >>>>>>
If the board is not colour coded then the motherboard will marked with the same letters, you may need a strong light to see the marks.
Regards.
Feb 22, 2010 | Gateway GT5428 PC Desktop
I accidently removed 3 sets of jumpers (power, LEDS for hard drive) when removing the front panel of my E-machine T2893, and cannot remember which jumper goes to which set of double prongs on the mother...
Regards.
Feb 07, 2010 | E-Machines T2893 PC Desktop
Need pin position for motherboard fsb1066 power, reset, frontal doors...
Regards.
Sep 15, 2009 | Gigabyte Computers & Internet
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
Tower top mounted USB portss
The cables from the front panel USB connectors have a key in them that will line up with the missing pin on the board's USB headers. Just line up the connectors and plug them onto the board. It doesn't matter if you use USB1 on the board for the plug marked USB1.
Apr 12, 2009 | Computers & Internet
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
PC Chips M848ALU Motherboard Logo
Top PC Chips Computers & Internet Experts
David
David
Steven Burn
Steven Burn
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
