Question about Sony PlayStation® 3 (80GB) Console
Playstation 3 freezes up when I play games.Only disc based games.
Kazong
  • 152 Answers
SOURCE: disk format
1) Turn on machine
2) Open Tray
3) With tray still open hold the reset until the tray closes.
4) Tap the reset once.
if there is a format disc error, it says "Please insert a Playstation or Playstation 2 format disc." It is accompanied by a sound similar to the browser, but with a more tense noise. This is caused by a disc being so badly scratched that it completely fails to recognise the format, or if there is a problem with the laser. Auto-Diagnosis (PlayStation 2 system) 1. Turn on the system without a disc inside. 2. Once at the Main Menu, press the triangle button to enter the Version Information Screen. 3. Highlight the "Console" option, and then press the triangle button again. 4. Next, press the X button, highlight "On", and then press the X button once more. 5. Now press the circle button twice to return to the Main Menu. 6. Press the eject button on the front of the console, and insert a disc. 7. Now close the disc tray, but DO NOT reset the system. 8. Highlight the Browser option from the Main Menu, and then press the X button. 9. In the Browser, an icon of the disc should appear on the screen. Highlight this icon, and then press the X button to read the disc. 10. If the auto-diagnosis is successful, the disc should load properly at this point.NOTE: The auto-diagnosis feature will return to "Off" the next time a disc is inserted.
Posted on Dec 18, 2007
  • 18 Answers
SOURCE: Playstation 3 freezes up while playing any game
This does typically sound like an chip overheating. If you have checked your discs and they are in good condition with no scratches then is would suggest that there is a graphics chip error due to being faulty or overheating. My advice is to take your PS3 to your local repair agent to be assessed correctly. Has the PS3 been chipped to play pirated games. This could have caused an issue with your PS3 as well.
If you do now want to spend money sending the PS3 into an authorised repair agent then my advice is.
1. Take your machine to your local games store and test one of thier new games on the system to confirm it is a PS3 error and not a disc error.
2. Alternatively you could hire a disc however some rental stores do not take good care of their discs and it we want to establish that the issue is console related first.
3. If the same problem occurs again then you will need to take the console to the authorised repair agent to get assessed correctly.
4. If the issue appears to be related to scratches on the discs then you will need to take them to your local rental store to have them cleaned or resurfaced.
Game discs often have much larger quantiies of data to transfer and this is why it may appear confusing as your console can still play movies ok. If there are scratches on the surface of the discs then for the same reasons as mentioned above the movies will play as there is less data passing and therefore scratches will be effecting less data than on a typical games disc.
If you have any other questions please leave a message for me and I hope this information has been helpfull.
Regards
John
Posted on Dec 02, 2008
  • 42 Answers
SOURCE: freeezing
Do you mean it starts the game then freezes? Can you hit the PS button and does it still view the XMB? If so your laser must be replaced.
Posted on Feb 12, 2009
SOURCE: my playstation 3 will not play any games or movies
most likely it is the blue ray lens.... you can buy a new one and put it in but very easy to screw up good if your not technically sound... you can find people online that you can pay to fix for you.
Posted on Mar 21, 2009
  • 16 Answers
SOURCE: problem with playstation 3 games and blue-ray
I had a similar problem. My PS3 was not starting the game discs when I inserted those to the PS3. Also those game discs were not visible in the game menu.
I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
Actually I was able to start the game disc with a special trick, which required start some application, such as a downloaded game, let it start, and then hit the PS home button. The game disc title then shows up under the game menu and from that point remains viewable until the disc is ejected or the console is turned off.
In case you have the similar problem, I was able to fix this problem by executing the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After the PS3 has executed this DB rebuilding operation, the disc games will be visible again under the game menu and are also starting automatically when inserted to the PS3.
Posted on Jun 17, 2009
Playstation 3 keep freezing
if its only happening on disc games i would say the lens is going bad.
Jul 24, 2014 | Sony Playstation 3 (PS3) Console
My system plays cd's dvd's but when i put a ps3 game in the disc wont show therefor im not allowed to play any games by disc
The Playstation 3 is a wonderful video game console, however, with heavy usage, the laser does eventually burn out. The first signs of the laser starting to burn out is that your game will start freezing during game play. Eventually the game will stop reading altogether (even though movies sometimes still work). Eventually movies will stop working and the whole laser will eventually die.
The following website sells PS3 lasers and also performs repairs:
http://store.richspsxparts.com/pl3isnotrega.html
Jun 16, 2011 | Sony Playstation 3 (PS3) Console
When i play games like call of duty the playstation freezes when the game is over, or when the host leaves the game. why? how do i fix this?
might be a disc problem, i got the same problem from a microscopic scratch on my MW2 disc, game still played single player and co-op but kept freeing at random times on multiplayer.
Apr 04, 2010 | Sony Playstation 3 (PS3) Console
5 min into a game and the sounds goes then freezes
plugged in ps3 says the hard disc data base will be rebuilt gets to 97 % then goes off ???
Dec 25, 2009 | Sony Playstation 3 (PS3) Console
3.0 Killed my PS3
Sounds like the laser diode burned out. If your under warranty send it in. If not you could buy a replacment and install it yourself.
Sep 11, 2009 | Sony Playstation 3 (PS3) Console
Half way throuh my game it will just freeze up.
cd drive is no good or is it gettin hot after you have not played it for a long time dose it work?
Mar 20, 2009 | Sony PlayStation® 3 (60 GB) Console
Playstation 3 Stopped Playing Blu Ray Discs and Games
It's a factory defect. I've fixed over 100 PS3's with the same exact problem. Your blu-ray laser went out. You need to contact Sony or if you're in Los Angeles you can contact me. I fix the problem for $120 and within 30 minutes. Sony charges $150+ and takes God knows how long.
Feb 19, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3
That means it can read some of the disc but not all. Are the discs clean? If so the bluray laser is dying. You will need to spend about $70 for a new laser or $150 to get a new unit from Sony.
Feb 09, 2009 | Sony Playstation 3 (PS3) Console
Play Station3 60G
Check for scratches on the game disc.
Aug 04, 2008 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (80GB) Console Logo
44 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
