Question about Microsoft Xbox 360 Console
Lights dont turn on for control
My controller dont work
  • 3 Answers
The controller might be damaged buy an other controller
Posted on Nov 13, 2009
My dash lights dont work
Check your fuses. Also check the control knob for your headlights. If you turn the knob, it usually controls the dash lights.
Jan 05, 2016 | Jaguar Vehicle Parts & Accessories
Tip
How to program an rca universal remote without codes
If you have a universal remote but dont have the codes or the codes dont work then what you can try is to scan all the frequencys using the remote to manually scan to work for your telly or other equipment your trying to control.
Follow these simple instructions
1. Turn on the device you want the control to control ie the tv or dvd or stereo etc
2. You need to now press and hold the button for the device you want to control and also the power button untill the light on the remote stays on( for this case we are going to program it to control a tv) so press and hold the tv button and power button hold them down untill the light stays on
3. press the play button once every 5 seconds( a bank of 10 codes is being sent every time you press the play button)
4. when it turns the tv off wait press the rewind/reverse button and check it turns the telly back on if it does then you need to hold the stop button untill the light goes off.
Once you have done this check the remote is working properly ie changing channels ets if it dont work properly then follow the instructions again and try again you may need to do this a few times till it gets the right signal
on Jan 18, 2010 | Televison & Video
I CHANGE THE BATTERY TO REMOTE CONTROL AN DONT WORK AN THE UNIT THE GREEN LIGHT IS BLINKING
This is an alert. Your unit has a self diagnostics. The blinking light indicates a malfunction. check or clean the air filters. Go to the outdoor unit or your breaker box and turn off the power. Wait about 5 mins then turn power back on. Turn your controls to cool and temp down. If this dont work then it needs service.Call a service technician.
Jun 04, 2015 | Heating & Cooling
Steering wheel audio controls dont work when steering wheel is straight
you wll have to remove the steering wheel to find the problem iam afraid ,its called a serpent coil or whatever and this is playing up ,make sure ignition is off nd remove the airbag to get to the steering controls but whatever you do remove the airbag but do not unplug it or the airbag light will stay on
Mar 28, 2012 | Cars & Trucks
Dashboard lights dont work fuses appear ok but dont know which fuse controls dash lights
The parking and tail lights are usually on the same fuse as the dash lights so if the outside lights are working it sounds like the instrument dimmer control has failed. The electronic bits inside the control for these lights sometimes go faulty. A temporary fix is to remove the wiring plug that attaches to the back of the dimmer control and put a jumper wire across the terminals. If dash lights then work then replace dimmer control.
Oct 21, 2010 | 2000 Toyota Corolla
Dashboard lights dont turn on.
did you check the fuse? did you turn up the dimmer control ? other reasons may be a bad ground to the instrument cluster, or a defective dimmer controll
Jan 27, 2010 | 2001 Chevrolet Impala
2004 crown victoria lights dont work brake lights dont work turning light dont work
If it is an '04, the lighting control module (LCM) is most likely the culprit. The LCMs were largely no good for '03 and '04. It is located at the bottom on the instrument panel basically above your right shin. Easy to replace, but kind of pricey.
Jan 16, 2010 | 1994 Ford Crown Victoria
My dualshock 3 wont pair with my playstation , all the 4 lights flicker but the number 1 light dont stay lit.
Try attaching the controller via cable, then turn the controller on. This will set you to the #1 controller, then unplug the controller, it should stay on the #1. Then turn the controller off (hold PS button for 3 seconds) and then turn back on.
Oct 15, 2009 | Sony Dual Shock 3 Controller for...
HOW TO PROGRAM RCA RCU310 Remote Control
1. turn device on.
2. hold code search untill light stays on
3. press tv, vcr or whatever you want to program once. (light should still be on)
4. press on and off button untill your device turns off.
5. click enter on the remote. should be good,
6, dont forget to go outside now and then,
Mar 02, 2008 | RCA RCU310 Remote Control
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
