Question about Nokia N73 Cellular Phone
Disk error-cannot c... - Nokia N73 Cellular Phone
1782 disk control failure / non-system disk or disk error That is all it does
That means, there's an error reading the files of windows system, or something else to start your Operative System.
Try to reinstall your windows.
If you get errors when you try to install the windows, tell us the error on the installation. It can be an Hard Disk problem and you must replace it.
Dec 10, 2013 | Compaq Evo N800c Notebook
Cyclic redundancy check
A cyclic redundancy check error on a hard disk means that part of a file read from the hard disk doesn't match the expected value.
A cyclic redundancy check error, in other words, means that files on your hard drive are corrupted.
Repair a cyclic redundancy check error on a hard disk using the Check Disk tool in Windows.
Click "Start" and click "Computer."
Right-click the hard disk with the cyclic redundancy check error under "Hard Disk Drives" and click "Properties."
Click the "Tools" tab at the top of the hard disk "Properties" window.
Click "Check Now" under "Error Checking."
Select "Automatically Fix File System Errors" and "Scan for and Attempt Recovery of Bad Sectors" in the "Check Disk" window by clicking each option if it isn't already selected.
Start a disk check and repair by clicking "Start" in the "Check Disk" window.
Click "Yes" if the "Do you want to schedule the disk check to occur the next time you restart the computer?" prompt appears.
A disk can't be checked if it's in use, so you'll need to restart Windows to check it.
Restart your computer by clicking "Start," clicking the arrow icon to the right of "Shut Down" and clicking "Restart."
(External drives will not schedule to happen on restart it will happen straight away.)
Sep 09, 2013 | Verbatim 500GB USB Desktop 500 GB Hard...
Cyclic redundancy error
How can I fix Cyclic Redundancy Check on external drive?
This problem is caused by bad sectors on HDD. refer to http://www.goodlucksoft.com for more information
Feb 20, 2013 | Computers & Internet
What does error code 2881 mean?
Error 281 is a disk recognition error, bad disk, scratch on disk or disk contains moisture (dry it)
Try
1.- get out and reload the disk
2.- Clean the disk for Dust / scratch
3.- clean pick up lens (with a soft clooth or a piece cotton
4.- Replace the disk and check if the error message continue.
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Hitachi DZ-MV230A DVD Camcorder
I visualise this msg on pc 'non disk system error or disk error'
This error is caused by the boot device (hard drive, DVD, etc) not having the required Operating System files. You may need to find a different Boot Device, like maybe a DVD, with the boot files on it. Boot from DVD and reinstall HD files.
Jan 17, 2010 | Computers & Internet
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Non system disk error or disk error when turned on
this happen when the computer does not detect the hard disk, check the cable and power connections of the hard disk
Sep 03, 2009 | Computers & Internet
Non system disk or disk error
This error can be a couple of things. If the "boot block" on the disk has become faulty, the system won't recognize that the disk has an operating system on it and will generate this error message. If the disk is defective completely, the same error will occur. If you have a boot floppy or CD, try re-writing the boot block on the disk. If that fails to resolve the problem, the disk is defective and will need to be replaced.
Dan
Feb 25, 2009 | Compaq Computers & Internet
Nokia N73 Cellular Phone Logo
216 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
