Question about Sprint Hitachi P300 Cellular Phone
Getting alarm code 327 & 337. Replaced 'y' motor ran for a day.
C9050 code
Kyocera code c9050 Printers & Copiers Questions ... - Fixya
www.fixya.com > Forum > Tags > code c9050 > Printers & Copiers
Kyocera printers & copiers code c9050 related questions and answers. ... error code C-6 for kyocera km 1500 blingking code C-6 in my kyocera km 1500 c6-400
Oct 15, 2015 | Cars & Trucks
Got a motor don't know if its a 327 or 283 numbers GM 35 39700010 stamped on block tag # 639653 (1342)
Chevy Casting Number identification - Block casting numbers
outintheshop.com/faq/casting/castings2.htm
Chevy Block Casting Numbers. Use these casting numbers to identify the block you have. ... 283. car & Truck 2-bolt. 3790721. 64-67. 327. 2-bolt Chevy II Nova Recessed filter. 3791362. 66-67. 327 ...... Vortec Truck L-35. 12554290. 350. 94-96.
Sep 25, 2015 | Cars & Trucks
I have a 93 F350 5.8 with a code 327
you could try to remove the EEC and inspect the pc board for leaking capacitors i hope it helps
Nov 16, 2013 | 1993 Ford F350
1993 Ford F350 code 327
have you removed the egr and checked for plugged in the egr port or damage to the egr itself... i think it's more of a flow issue associated with the position of the egr and not the solenoid itself... koeo/koer tests are a pain even with a break out box... good luck as this year (early 90's) of Ford's are the worst for diagnosing computer/running issues
I have a 1994 mercury grand marquis. it has several codes that come up when i pull them from the check engine light. what are these code meanings, and what needs to be done to fix them. any help would be...
I'm giving you these codes from a haynes manual,
326 EGR circuit voltage lower than expected
327 EGR valve pressure transducer/position sensor circuit below minimum voltage
332 EGR valve opening not detected
337 EGR valve pressure transducer/position sensor circuit above maximun voltage
Nov 28, 2010 | 1994 Mercury Grand Marquis
O2 lincoln ls check engine light & fuel gauge went to empty the next day it wouldny start replaced fuel pump & fuel gauge ran fine drove about 40 miles the next day started it up check engine light...
You have two pumps,I guess you know that ,if you already did one. Did you check fuel pressure at the rail and check out the electronic pressure regulator? What codes are coming up and do they stay set?
Feb 05, 2010 | 2002 Lincoln LS
Service 4WD Light comes on. What exactly do I need to do?
have a dealer read the codes from the atc module..if has code 327 it will need an encoder sensor replaced..if code 2735 it will need a switch replaced in dash..if code 306 check grounds under cab mount ..if grounds are good replace encoder motor
Dec 27, 2009 | 2004 Chevrolet Tahoe
Microsoft streets and trips 2009 doesn't see my installed printers
Remove the program and re instsll it or use new one from torrents
http://torrent-finder.com/show.php?q=++Microsoft+streets+and+trips+&Browse=tabs&PageLoad=loadall&select=10&sids=1-23-314-36-2-323-4-3-6-84-35-10-344-316-30-249-24-28-361-15-334-18-276-296-29-37-60-17-343-58-306-325-337-327-14-57-12-44-330-252-253-48-359-305-56-108-313-54-51-273-351-72-78-79-68-80-73-264-258-332-55-303-350-245-307-340-41-353-341-21-5-26-31-9-77-251-226-342-64-65-246-16-256-338-333-348-331-97-279-105-87-319-320-89-93-99-100-104-124-287-299-298-109-262-268-113-114-347-293-274-119-263-322-349-315-140-282-267-110-292-244-49-133-122-125-257-277-144-284-103-137-311-312-149-152-123-132-143-142-291-283-358-356-85-141-121-101-288-147-324-52-153-154-280-150-317-346-269-345-336-339-329-120-354-357-155-156-157-321-355-360-162-163-166-160-165-167-169-
balboul@gmail.com
May 02, 2009 | Computers & Internet
My obd 337 code comes up knock sensor low voltage
go to the below link for a trouble shooting guide to this problem. It looks like the connector may be off or the knock sensor is dead open circuit.
http://gm.ws123.net/EN/documents/Matiz/sm-10l/5M2_1F07.en.html
Mar 16, 2009 | 1999 Daewoo Lanos
Sprint Hitachi P300 Cellular Phone Logo
21 people viewed this question
Top Sprint Cell Phones Experts
TekkiDave
 steve
steve
celticsel
celticsel
Level 1 Expert
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
