Question about Ldr Industries 520 1300C ADJUSTABLE SHOWER HEAD - CHROME
How do you adjust the spray on the handheld unit?
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
What do I use to clean the exhaust intake on my Echo PB2100?
With the unit cold you can spray some carb cleaner into the intake and the exhaust screen to remove fouling deposits.
Be safe and good luck
May 30, 2014 | ECHO, Inc. PB-251C Handheld Blower
Paint gun not shooting correctly
Seeing how you have really stated what the problem is (spitting, clogged, won't shut off, fan pattern wont adjust Etc) and there could be several different things wrong- lets go over some basic spraying A B C'S- always strain the paint through a strainer bag or cone this will remove any debri that might clog the tip, *THINNING when you spray or atomize paint it should always be thinned it will actually cover much better if you thin it with the appropriate solvent water for latex thinner for oil base you want to stay in the 15% range alittle bit more on hot days. The shape of the spray that comes out of the tip is called "fan pattern" or "tip fan" "fan size" you can adjust the fan pattern from 9:00 - 3::00 or sideways to straight up and down or to a small circle this is done by moving the "tip housing retainer" keep a piece of cardboard to practice and see. IMPORTANT:When you have finished spraying you need to clean the entire gun by running the right solvent through the gun untill nothing but clean solvent is coming out dissemble the gun remove and clean needle and needle housing this is not very complicated and is paramount to maintaining any spray equipment for sure the gun....
Perry Tradesman
Dec 29, 2013 | GRACO INC 3900 Handheld Paint Sprayer...
How do you adjust the spray on the Ryobi Paint station? How do you get it to spray more like a fan. it is brand new and it sprays in a straight stream instead of a spray fan.
It would have a tip that is adjustable and you can adjust the fan that way or if it isn't adjustable then the unit may have interchangeable heads for different spray patterns.
Feb 11, 2011 | Kitchen Ranges
Does not spray cleaner
It helps to always run hot water in the soap holding tank after you have cleaned the carpet to make sure the soap does not dry inside and clog. Make sure that the dirty tank water filter is clear of debris, I have noticed that if it is clogged it won't spray out solution. Another thing to try is, it usually will always spray out of handheld cleaning attatchment. steve
Jun 06, 2010 | Bissell 1699 ProHeat Clear View Upright...
Bissell 9500 proheat 2x wont spray liquid to the floor
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ghhdg
May 29, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Spray path is too wide. Is there a deflector available
I had the same problem with my proheat. The water would spray a wide path out the sides. I think it must be a defect as I have replaced my unit due to another problem. I purchased the Bissell machine without the heater and the nozzle is fine.
May 14, 2010 | Bissell 1425 Little Green ProHeat Handheld...
Shark handheld steamer heats up but does not spray
Try rinsing it out with CLR, it gets rid of calcium, lime and rust deposits i heard its very good.
Jul 10, 2009 | Euro-Pro Ultra Steam SharkTM II Hard...
Sprayer Question
Hose end sprayers are the simplest and least expensive of the category. A sprayer jar is attached to a regular garden sprayer. Concentrated material is added to the sprayer jar. An adjustment on the jar determines the amount delivered. The force of the water through the hose pulls the material up from the jar and mixes and dilutes it with the water. A built-in anti-siphon device prevents unused material from being pulled back into your water supply. Compression or tank sprayers are the most common type of spray equipment. Concentrated material is added to the tank. Water is then added to a marked fill line. The remaining air is pressurized by pumping the handle a designated number of times. A control lever on the wand controls the spray pattern and amount. Compression sprayers provide a precise, on target, non-drift spray good for soil and lawn pests. Adjust the sprayer for a coarse, drenching spray, a concentrated stream or a fine mist. Tank capacities range from 1 quart to over 3 gallon for handheld models. Homeowner type backpack sprayers hold up 4 gallons. The tanks may be made from polyethylene plastic, galvanized steel or stainless steel. In addition to treatments for pests and diseases, compression sprayers are designed for applying cleaning solutions for decks and siding. Backpack sprayers are operated in the same manner as the handheld compression sprayer. The over-the-shoulder configuration makes it easier to carry the heavier load of material. Some backpack models also use a lever-style pump to maintain pressure without removing the unit form your back. Powered sprayers rely on a gasoline engine for spray power. Great for larger yards or gardens due to portability and capacity (12 gallons). Dusters are a slightly different breed. Dry powders (mostly for blooming plants such as roses) are added to a canister and applied by manually pumping. NOTE: Compression sprayers deliver liquid under pressure. Compression sprayers are powerful and efficient tools. This fact also makes them potentially dangerous. Always read the manufacturer's instructions and safety precautions carefully.
Aug 27, 2008 | Sp Systems 02sv320065 Farm & Home 2 -...
No spray
Here are 3 common things that causes this problem:
• clogged spray tips
• defective solenoid valve in the base
• defective trigger microswitch in upper handle
Mar 16, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Ldr Industries 520 1300C ADJUSTABLE SHOWER HEAD - CHROME Logo
Top Ldr Industries Home Experts
john h
Tom Chichester
Are you a Ldr Industries Home Expert? Answer questions, earn points and help others
