Question about AMD Athlon 64 4000+, 2.4 GHz (ADA4000DEP5AS) OEM / Unboxed Processor
No audio output from pc to amplfier - AMD Athlon 64 4000+, 2.4 GHz (ADA4000DEP5AS) OEM / Unboxed Processor
  • 832 Answers
Check the cord you use from the PC to your amplifier,
have it replaced it it is defective.
Posted on Nov 14, 2009
  • rolando ingking Nov 14, 2009
Do you need a ground wire between the turntable and receiver? if so, where to attach to the turntable?
Well read your guide, instead of easy ask things, a phono output has a ground wire, and if your tt has a line output, just use a cd or aux input. If your amp doest have a line input and your turtable only has a phone and ground output, you need to buy first a phono amplifier and connect that output to a line input on onee of your amplfier.... Jst buy a cheao one fron project for 100 euro
Sep 10, 2014 | Audio Players & Recorders
Amplifier in protection
That thump beat was called motor boating and is amplfier oscillation. It means that a driving transistor in the audio output circuit is bad. You will have to send this in.
Apr 21, 2014 | Car Audio & Video
How do i connect my tv to my amplfier for audio
Use the component audio output ports, or the optical output. Depending on your model... the TV's internal speakers may need to be switched to OFF in the setup menu.
Thanks!
Feb 23, 2012 | LG 42LC2D 42 in. LCD HDTV
I have Daewoo tv model # DTQ-20U6SC. The sound is just low. I'd like to know what the problem is.
Any sound problem can be confirmed only if the signal is traced and identified so as to confirm the section. You will need an AF- audio frequency - generator to inject and confirm the section where the amplification is low .
Also a check on the pre-amp output and a signal to the INPUT can confirm the output amplfier.
Finally check the speakers, test with a working speaker.
Sep 25, 2011 | Daewoo DTQ-20U9SC TV
Aai have the following AKAI Audio Stereo System and no Idea how to connect them. Please help Akai Model AP-D210 turntable Akai model CS-F14 Stereo cassette deck Akai model AT-K110 Fm Am Tuner Akai...
In general, outs to ins.
If nothing else, get the manuals for the preamp and the EQ. You'll probably have to pay for them.
Google it.
Akai PR-A04 preamplifier << This is the control center and where everything comes together.
Akai AP-D210 turntable (ONLY to jacks that say "PHONO"
Akai EA-G40 Stereo Graphic Equalizer (in the Tape 1 Out/In set)
Akai CS-F14 Stereo cassette deck (in the Tape Out/In set of the EQUALIZER) *
Akai AT-K110 Fm Am Tuner (to the Tuner inputs)
Akai DT-100 Audio Tuner (to the Aux inputs)
Akai PA-W04 Amplfier (to the amp outputs)
* This will allow you to Equalize the Tape on the Record or the Playback side.
Read some audio magazines or websites. Get to understand Tape Monitor Loops.
Don't use excessive EQ.
Mar 17, 2011 | Akai Audio Players & Recorders
Can't hook up to a flat screen tv
I can only guess as to the nature of your problem, but I'll try. If you're trying to hook up your amplfier and its a 5.1, or 6.1 amp you need to hook up the audio by using the orange output on the flat screen, it may be labeled "coax" or "hd audio out" or surround out, this is the one wire you need to reproduce the surrond sound with left, right, center and rear speakers, and also the sub woofer. The other outputs on your tv will be red and white or red and black, these are the analog audio out and you plug them into your amplifer too, but they won't be 5.1 sound, although your sub woofer will still work. I hope I have helped some.
Mar 12, 2011 | Audio Players & Recorders
How can i add external speakers to my lg 50pk950 tv and still control with my tv remote without also adding an amplfier?
Use a wireless speakers system and connect it to the Audio Output RCA jacks on the back of your set( red/white). You can find various style to fit your decor. Google it.
Nov 30, 2010 | LG Infinia Series Plasma HDTV 50PK950
LT-980/2 Car Audio Amplifier: Looking to see if I can hardwire a Power Acoustik ...
you want to use a car amplfier indoors in the house
yeah that can be done very easily
just wire it like you would inside a car but you need to purchase a 12v DC adapter
i would go for one with at least 3A output (the bigger the better it depends on how much u wanna spend) from personal expericance 1.5A works but when it gets loud the amp stops and restarts
May 16, 2010 | Power Acoustik LT-980/2 Car Audio...
I have lost audio polaroid flm 3232m
Try to narrow down the bad section of the audio signal chain by hooking up powered PC speakers to the audio line out to see if you do get the sound there, if you do then the problem can be in the power amplfier section, if you do not get the sound at line out then it can be in the sound processing circuits, here is the service manual: http://www.polaroidsupport.com/polaroid/docs/FLM-Series-26-32-37_ServiceManual_20070418.pdf
Mar 13, 2010 | Polaroid FLM-323B Television
AMD Athlon 64 4000+, 2.4 GHz (ADA4000DEP5AS) OEM / Unboxed Processor Logo
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
