Question about HTC Verizon XV6700 Cellular Phone
Randomly turns screen white have to shut off phone and turn back on to get rid of screen
Fone turning off randomly . had back off but no joy
Hold down volume down + power at the same time for 30 seconds... that should reset it without losing your data.
Mar 30, 2015 | Nokia Lumia 625 8gb Yellow 4g LTE...
My computer screen randomly turned white and won't
Your screen might be going bad. Try plugging an another monitor and see if it works or has the same problem. If the other monitor works, it's definitely your screen is bad. If the other monitor fails and does the same thing, then the video card in the computer is bad.
Mar 28, 2012 | HP Computers & Internet
Motorola w385 turns off on its own
check the memory on your phone. if your screen turns white and than automatically shuts off. sounds like you may not have enough memory available to open your pictures. go to menu than my content>options>check memory. this should tell you how much memory you have available. if you are zero memory available, you may have to contact motorola or your carrier to reset your phone, which you will lose all your contact information and photos. good luck!!
Jul 20, 2009 | Motorola Mobility W385 Cellular Phone
Phone shuts off and doesnt load all the way when you turn it on
the phone has multiple problems already, it has a software issue, you need to have the phone evaluated by a technician.
Jul 06, 2009 | Samsung SCH-u340 Cellular Phone
My phone just shuts off randomly
you might need a new battery but just to make sure take it to your phone company store and they will give you lots of help
Jun 28, 2009 | AT&T LG CU515 Cell Phone - Black
Phone doesn't turn on, randomly shuts off
This same problem hapnd 2 my fne i bet the smaller screen at the front dosent work either well the problem is the wire connecting from the screen to the main part isloose try tightening it,if this does not work squeeze the screen/middle part conecting the two
Aug 24, 2008 | Motorola Mobility RAZR V3
Sanyo Katana 1 - White screen
Yes- take the device to a Sprint store (thats who you actually talked to) and ask them to upgrade the software on your phone. This is a known issue and your firmware needs to be updated.
please rate solution. thanks.
Mar 19, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Screen problems
This might be a loose connector on the top of phone. What you want to do is open up the top section of the phone, there are four screws. once you remove the top cover there are two connectors, one that comes from the camera and the other comes from the keypad. gently remove this one (upwards) and clean with IPA (alcohol) and a brush. let dry and re-install making sure it connects securely.
Good luck
Nov 21, 2007 | Motorola Mobility RAZR V3
The same thing is happening to me and I didnt drop my phone at all... and this is the replacement phone from my insurance that I just got 2 weeks ago... My old razor would blank screen and I didn't do anything to that one either... I think they're just crappy phones now.
Oct 24, 2007 | Motorola Mobility RAZR V3
HTC Verizon XV6700 Cellular Phone Logo
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
