Question about Toshiba Satellite U305-S5107 Notebook
Toshiba Satellite u305 touchpad mouse not working, I reinstalled the driver but it is not appearing under the device manager
3 Suggested Answers
TampaNative
  • 778 Answers
SOURCE: Hi! My touchpad mouse has stopped working in my
While holding the "FN" key, press the "F9" key and that should re enable your touchpad.
Posted on Apr 19, 2009
benwabnick
  • 2404 Answers
SOURCE: Toshiba Satellite Touchpad not working
Restore the defaults in the BIOS to begin with, this will make sure its not a setting in there that is disabling the mousepad.
Then in windows see if the touchpad is working. If not then take the keyboard out with the power turned off.
When you take the keyboard out you will see the ribbon cable that comes from underneath the touchpad. disconnect it from the motherboard and reseat it firmly back in. Then turn back on the motherboard and see if the mousepad works. If it still doesn't then try the shortcut key to enable it.
If it does't enable then that means its either going to be a mousepad problem where you would have to replace the top cover assembly or a motherboard problem cause it could be where the voltage required to run that mousepad is missing.
Posted on Jun 27, 2009
Touchpad doesnt work
Try reinstalling the touchpad driver.
You can download the touchpad and device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: -
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
May 03, 2013 | Toshiba Satellite A135-S4477 Notebook
Toshiba Satellite A65-S126 keyboard no longer works
If you have the disk or driver for keyboard then reload it.
If not then use the mouse and click on the Start button, use the mouse's right button on Computer (My Computer). Select Manage. When the Computer Management console appears, Select Device Manager. Expand the Keyboard Section. Right Click on your computer name and select Scan for hardware changes.
If this fails to reload the driver then right click on the keyboard item that says Unknown and select Update Driver Software.
Jan 29, 2013 | Toshiba Satellite A65-S126 Notebook
Touchpad not in device manager
Hi There,
The touchpad will normally show up under input devices in device manager. If you don't see it listed, check to see if your touchpad has a manual on/off switch located on the laptop keyboard (sometimes under specialized function keys)
If a switch doesn't seem to be the issue, try reinstalling the drivers for the touchpad, which should be available on the toshiba website.
Aug 06, 2012 | Toshiba Satellite P105-S6197 Laptop
Upgraded toshiba a305-s6852 from windows vista to windows 7 FN buttons no longer work'
"Don't mean to insult .. but did you go to toshiba's website and follow their instructions?
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2060005&rpn=PSAG0U&modelFilter=A305-S6852&selCategory=2756709&selFamily=1073768663
** FORTH FROM THE BOTTOM **
How to Upgrade Toshiba laptops to Windows 7
You will need your serial number to match against which path to take. They have an "installer" program that will help you get the drivers.
Jul 28, 2012 | Toshiba Satellite A305-S6852 Notebook
Hello i have a toshiba satellite u305-s5097 laptop and the sound on my computer is not working
Well first off you should ensure that the sound Driver is installed and working properly.
You can do this by going to the Start Menu, Right clicking "My Computer",selecting "Manage", then going to "Device Manager". Are there any yellow exclamation or question marks? If so, you will need to install the Driver for that particular device. The drivers can be found at the Toshiba website, under the Support section. If this is the problem, let me know and i can help you find the correct driver.
Mar 27, 2011 | Toshiba Satellite U305-S5097 Notebook
Toshiba U305-S5077 trackpad will not click by touch anymore
The touchpad driver might need to be reconfigured. Try the various options in the Control Panel and then Mouse properties.
Aug 17, 2009 | Toshiba Satellite U305-S5097 Notebook
My toshiba U305 webcam stopped working suddenly
Check in your device manager and see if your webcam has a yellow ! point on it if it does try to reinstall drivers.
Jun 11, 2009 | Toshiba Satellite U305-S7448 Notebook
My toshiba satellite u305-s5087 model has stopped giving sound.
try to check the device manager and see if there's a driver problem, you can reinstall the driver or just reconnect the device to your unit.
Apr 13, 2009 | Toshiba Satellite U305-S5097 Notebook
First check: Control Panel -> Mouse -> TouchPad On/Off
Second check for a button near the mouse pad, often there are buttons that will enable/disable the touchpad
Thrid use the shortcut key FN+F9(or what ever F key that is used by your laptop) to disable/enable the TouchPad.
Fourth try this software: http://www.kingzm.com/eng/files/download/MouseManager.zip
Fith
- Select Start, Settings, Control panel.
- Open System, click on Hardware, and Device Manager.
- Expand "Mice and other pointing devices", and double click on the entry below, that may be called "HID-Compliant mouse", or "Alps Pointing Device".
- Under "Device usage", choose "Do not use this device in the current hardware profile (disable)", and click OK.
Jan 20, 2009 | Toshiba Satellite A205-S4617 Notebook
DELL xps touchpad
Sounds like a driver glitch, from the device manager, try uninstalling it, then do a hardware search, it will locate it and reinstall the drivers automatically. If this doesn't solve the issue, then the touch pad has failed and needs replacing.
Jun 20, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Toshiba Satellite U305-S5107 Notebook Logo
283 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
