I'm trying to install a laser printer and the usb is installed (maybe not right) it just won't work, I have a photosmart printer installed, no problems, Is there something I need to know aboout high speed usb?
    Problem Solver:
  • 13 Answers
1 make sure you delete and old usb drivers
2 remove the usb cable from the printer
3 restart computer
4 install usb software from cd or online
5 insert the printer ONLY AFTER you have installed the drivers
Posted on Nov 13, 2009
My printer will print and copy but won't scan. It
First, do you have the full-featured version of the software installed (installed on the computer before connecting the printer to the computer)? Second, do you have the all-in-one connected to a print server or USB hub? These can block the two-way communication needed for scanning. Try a direct connection. Also try a new USB cable and a different USB port (if you have any signal loss issues, it matters more with the scanner).
I hope this helps.
Mar 22, 2010 | HP PhotoSmart C4280 Laser Printer
My HP all in one printer works fine, however when I scan - it says "USB Not Connected" My cord is fine, my driver is up-to-date... any ideas?
the reason for this can be improper installation.. so try doing the installation again.. or run scan diagnostic utility that is available on hp.com
Oct 22, 2009 | HP PhotoSmart C4280 Laser Printer
New printer not recognized?
Here two causes are possible first your driver that you installed is not insralled properly so turn off your computer, reboot, delete HP Photosmart C4480... driver from the printer list icon and install again properly.(if you will not get the right solution of your problem then try the next step)
Second your U.S.B. cable maybe faulty so change your U.S.B. cable.(if you will not get the right solution of your problem then try the next step)
Third your U.S.B. port of computer is faulty so cahnge the port(many computer have more then one U.S.B. port if you have so try one(if you will not get the right solution of your problem then try the next step)
and
after this all you try your installation on other machine.
I hope you will get your problem solution.
thanks
TTYAGI
Apr 04, 2009 | HP Photosmart C4480 All-In-One InkJet...
Hp photosmart C4280 installed once worked great unplugged and moved problems. uninstalled reinstalled maybe 15 times now nothing works installation complete yet device icon says cannot detect device
HP printers can be very touchy about the way they are installed.
1) Disconnected the printer
2) Uninstall the software
3) Restart your computer
4) DO NOT PLUG IN YOUR PRINTER
5) Install the driver and only connect the printer when the installation tells you to.
The other source of problem is where the printer is connected to the printer, if it is connected to a USB hub (especially an unpowered one) it may cause issues. Try connecting to one of the ports at the rear of your computer.
Check your cable, maybe try another one, it could have become damaged in the move.
Oct 11, 2008 | HP Office Equipment & Supplies
Printer install problem
hi friend
u have to do this
1.plge in ur usb printer cable on other port
2.do not on ur printer
3 put ur printer cd in ur cd rom drive
4install ur printer software
5 in between the installtion ask to u power on ur printer then u have to on ur printer
5 completing the printer installtion
try to print
& thnx uing fixya
Mar 30, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP Printer photosmart C4180
Hi.
I think that the Drivers have failed to communicate.Just try the steps below.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP Photosmart c4100)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Thanks
Riz
Mar 10, 2008 | HP Photosmart C4180 All-In-One InkJet...
Installation Problems, Please help!
try downloading the software from the HP website and then reinstall the printer. But also try to uninstall it using control panel add/remove programs, restart your computer, and then reinstall using the downloaded driver.
Jan 27, 2008 | HP Photosmart C4280 Aio Printer
k24674
