Channels not working
My TV will not go past channell 13
  • Anonymous Apr 01, 2008
    I cannot seem to get my channels to go above 69. Manual set or auto programming. I do have a simple cable plan, but there are a few channels above 69. (8 is one and this TV has the +100 button on the remote but I have never used it.
    Yes i need assistance. TV is only a little over a year old. Thank you
  • tshay 03 Sep 07, 2008
    why my tv does not go past channel 13?
    Genius:
  • 1,694 Answers
Make, Model,chassis and servicer info off back of set would
help.....generally, enter set-up menu...select CATV then select
auto-program......14 and up should lock in memory........T.
Posted on Jan 08, 2008
Everything from Channel 14 and up won't reset
If you have just an air antenna and your tv is set for cable and not air, you will not pickup any channels past 13.
Nov 20, 2011 | Televison & Video
When we turn on the TV the channels wont go past 13 not sure why. the other tvs in our house goes up to channels 65 Lost the manual
If the tv was setup with auto tune it will only store the amount of channels(signals) that it can pickup
so if the signal is worse on that outlet it will find and store less channels
May 13, 2011 | Hisense LCD1504 15 in. Television
New tv and no picture past channel 13. What to do?
then maybe it can only find 13 channels from your signal then?
Apr 03, 2011 | Hisense Televison & Video
Use to be able to get all channels now can't get any channel past 19
check the menus channel setup and make sure you are in cable mode and not tv mode, put the tv in cable mode and do a channel search.
Jan 23, 2011 | Zenith SY1324S 13" TV
Skips past all channels after 13. CableVision
I don't know the exact step to set it because I don't know you model TV. When you go to menu set channels it should give you the option to choose cable or air. If you pick cable all your channels will be in VHF which is what you want. If you pick air the first 13 channels will be VHF and the rest will be UHF which cable don't work on. After you pick cable then auto program and you should get all your channels.If this helps you and I hope it does give me a vote please.
Mar 04, 2010 | Televison & Video
My toshiba tv only goes up to channel 12, when it reaches channel 12 it starts back at channel 1.
You will need to re-scan the channels, i don 't know where it is on the menu of this set. If you are on cable, you need to make sure your tv is set to cable tuning, or you cannot get channels past channel 13. Same is true for antenna if you are on antenna make sure you are set for this.
Nov 20, 2009 | Toshiba 36A40 36" TV
Programming Channels
Your TV is likely set for "AIR" tuning rather than "CABLE" mode. In this case channels above 13 don't tune correctly. The tuning mode is adjusted through the setup menu (it's been too long since I've seen one of these to remember exactly how the menu looks). Once you set the tuning mode for cable, all the available channels should come in properly.
But you've said you have satellite, so you should have a satellite receiver connected to your TV, and you'd be changing channels there rather than on the TV. Your TV would be staying on channel 3 or 4 (if using the satellite antenna output connection), or on the A/V input you have the satellite connected to (if using the direct A/V outputs). Am I missing something about your system?
Feb 18, 2009 | Mitsubishi WS-73905 73" Rear Projection...
Cannot watch channels past 13
Your tuner settings must be set on broadcast instead of cable. Below channel 13, they use the same frequencies so it doesn't matter. Find the tuner settings page in the menus and change the cable/air setting.
Jan 06, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
I have the 13 inch and...
If you get channels 2 to 13 nice and clear but the rest are snowy, it means that the TV is set to the broadcast channels, which means that for the channels above 13 it is tuning in the old-fashioned UHF channels. If the TV is set to the cable mode then it tunes in cable channels above 13. To do this, enter the menu and navigate to the tuner settings, set the tuner to standard cable and then do the autoprogram, and the tuner's memory will be set for your cable system.
Aug 03, 2007 | Emerson EWC1903 19 in. TV/VCR Combo
Channel set
Apparently your TV is set to the "standard TV" position. Before you auto program your set, set it to the cable mode and then do the autoprogramming. In the standard TV setting, you just get off the air channels 2-13 vhf and 14-83 uhf.where as in the cable mode you get vhf channels 2-13 plus your cable channels. Stargazer
Mar 17, 2007 | Daewoo DTQ-13P2FC 13" TV
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
