Question about Ovens
DO I NEED AN EXHAUST FOR THE WASHER?
I JUST MOVE IN TO A NEW HOUSE WITH AN EXISTING WASHER/DRYER. THE WASHER HAS A HOT/COLD INLET AND A
DRAINAGE HOSE. THERE IS ALSO A PIPE COMING FROM THE FLOOR AND GOES TO THE DRAIN. THE PIPE WAS ACCIDENTALY CUT AND WENT DOWN BELOW THE FLOOR. THE ONLY WAY TO PULL IT OUT IS TO BORE A HOLE ON THE FLOOR. IS THIS PIPE REALLY NECESSARY FOR THE PROPER OPERATION OF THE WASHER? I HAVE SEEN A LOT OF WASHER INSTALLATION AND THIS IS THE FIRST I SAW THIS. PLEASE LET ME KNOW.
THANKS!
  • Ovens Master
  • 3,361 Answers
The drain pipe must be repaired or you will have water in the house when you use the washer.
Posted on Nov 13, 2009
Why the piolet does not lile inmy Ge wall oven when turned on
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Sep 07, 2014 | GE 24" Built-In Single Gas Wall Oven
Oven shuts down after few minutes
SAME CONCEPT FOR OVENS ::
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
Air Flow and Heat
Warning
Aug 28, 2014 | GE Profile JTP18 Electric Single Oven
Maytag oven blowing hot air from bottom vent heating house
Wanted to know if you found the answer. I have the same problem.
Aug 31, 2012 | Maytag Ovens
Oven only works when house is cold
all gas range ignitors have to be just hot enough. i would say put an amp clamp meter on it. if it draws over 2.8 amps its probably good. if under that its bad and replace it.
Aug 01, 2010 | Brown Stove Works TTM721-DK Gas Single...
The water fills and drain from the bottom of the washing machine. Have checked all the pipes no problem. Please advice
front load or top ? drain hose must be elevated to 36 '' 34 min. if hose on floor it will not work .. needs stand pipe . if its leaking inside you may have a hose off . reinstall and wala it works .. mm hope some of ans work for you ..
Dec 03, 2009 | Ovens
Wont drain
Be sure the drainage hose is clear. Grease and food can block it. Check the drainage pump. It will be at the drainage exit. The motor may be bad or it could have something on the pump blades that keep it from turning. ( especially if you hear it humming when it tries to empty)
Nov 03, 2009 | Ovens
Convection oven blowing cold air
If your fan is blowing cold air, it's the air inside the oven that circulates. It has nothing to do with the fan. Convection circulates the existing air in the oven. Sounds like you might deselect the convection setting if this continues to happen. We have parts, so please let us know if we can help any further. :>)
Aug 24, 2009 | Ovens
Lost the manual for a new world cooker
To get a new (pdf) manual ask at http://manualfox.com - they find you every manual.
Jul 31, 2009 | Ovens
GE Washing Machine That the Water Does Not Cut Off!
your washer valve is sticking, it should probably be replaced
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
Fan works but oven doesnt get hot
One of the switches looks to be a 5 position switch. 0=off, 1=Light, 2=fan
Feb 24, 2009 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
