Question about Janome MyLock 644D
Where I can found , the manual of janome 204D serger?
You can download the 204D manual at The Mule Wagon Antiques and Collectibles.
Posted on Jan 14, 2010
3 Suggested Answers
Tally Girl
  • 1129 Answers
SOURCE: how do I thread a janome 204d serger
Serger may have a threading diagram inside the front looper cover which should show the various thread eyelets that you need to pull the threads through and they may be numbered one to 4 also to indicate order of threading. The diagram is usually colour coded to match the tension dial colours and serger usually has colour dots on the different thread eyes to help you follow the thread path for each thread.
This video is great and hopefully will help you http://www.youtube.com/watch?v=zszJYQe2aws&feature=related, it has lay in tensions while yours has dials so just pull the thread around the dial right to left and then across to the next thread eye and this should pull the thread into tension. Dials are usually all set to 5 for normal stitch formation.
On my serger you thread up in the following order: top looper (second from right dial), bottom looper (right hand dial), then right needle, left needle; this video shows all threading going from right to left however, so if you have a numbered diagram inside your thread cover, then certainly use that order. But always loopers before needles.
Raise the thread aerial first before you start, put the cones onto the thread spools and if you have any cone holders (little plastic triangles) put them on the spools first to steady the cones. Now for each thread, take the thread tail from the cone, up through the aerial thread guide, then follow the coloured dots and take this down the front of the serger putting it into each coloured thread guide, through looper then up under the raised pressure foot. Repeat for next looper, then the needles.
Pull all 4 threads out under the foot to the left, lower foot, then chain off a little to start and test sew on fabric, adjusting the tensions if you need to.
Other adjustments are stitch length (usually a knob on right beside the flywheel numbered 1-4, blade position, a dial either left or right of the blade, press on the blade to release the tension on it before you try and move it. And differential feed, this is also a knob numbered 0.5 to 2 usually. If you can't see this on the right by flywheel then open up fabric plate (left cover) and look in there for these two adjustments.
I would suggest you start with tensions on 5, and stitch length of 2-3, and test sew on scraps of the fabric you wish to overlock. You can then either move the blade to cut wider or narrower to suit and adjust the two looper tensions if you need to close up the thread on the cut edge. There is no black and white settings as each fabric will behave a little differently, generally you adjust the looper tensions a bit until the stitch is encasing the cut edge and you have a seam width that suits the weight of the fabric.
Differential feed leave on zero unless you find you need it when a loose weave fabric goes wavy, then turn it down to close up the feeding. Sergers have two feed dogs, one before and after the foot and turning differential knob changes the ratio of feed between the two so either stretches the fabric, or pushes it together as it goes through the stitching sequence. So by turning differential feed up to 1.5 or 2 you are stretching the fabric and you can do a narrow rolled hem edge that is all fluted (lettuce edging).
I hope this helps you out a bit, if you are completely new to this machine and have never used a serger then I always suggest taking a class from a local dealer, it is really worth the money and time as they are quite different to sewing machines but once mastered, really change the dynamics of sewing and techniques are much more like commerical production with flat construction etc.
Posted on May 23, 2011
Tally Girl
  • 1129 Answers
SOURCE: My Janome 204d Serger won't form a chain
I would suggest that you check the needles again, make sure they are both fully up into the needle housing. Also they should be at different heights in order to form the stitch sequence.
It is important that you thread the loopers first in the sequence shown in your manual, then the needles. So you may need to recheck the threading again and make sure the threads are in all the eyes correctly, especially the lower looper. Also some overlockers, have a sliding eye on the lower looper for ease of threading, if yours does, make sure it has been slid back to normal operating position.
When you have checked the threading up, take all four threads under the raised pressure foot and make sure that the upper looper thread and lower looper threads are not crossing over each other. Lower the pressure foot and try to chain off again.
I hope this helps you to resolve the issue.
Posted on Oct 11, 2011
I am looking for a free download for a Janome MyLock 234 overlocker service manual. Where can I get this?
Service manuals are not normally free. $9.99 will get you one. Instruction manuals are free.
Janome Mylock 234 Sewing Machine Service Manual. Here are just a ...
https://www.pinterest.com/pin/515451119835333916/
  1. Cached
Janome Mylock 234 Sewing Machine Service Manual. Here are just a few examples of what's included in this manual: * Feed timing. * Upper knife timing.
[PDF]MyLock 234
janome.com/siteassets/support/manuals/retired/serger/inst-book-234-en.pdf
  1. Cached
Page 1. Page 2. TABLE OF CONTENTS. PREPARATION. Names of Parts , , . . . , . . . . i . , . . . . . . . . . . . e . , . , . . . . . 2. Standard Accessories . . . . , . , . _ .
Service Manual: Janome 234D (PDF Copy) - Janome Sewing Centre
https://www.janomesewingcentre.com.au/.../instruction-manuals/service-manual-jano...
  1. Cached
  2. Similar
Has your beautiful sewing machine started sounding a bit sour? With the official ... Covered in the Service Manual for the Janome My Lock 234D is: SERVICE ...
Service-Manual.net - Janome Service Manual Downloads
www.service-manual.net/ashop/Janome-Service-Manual-Downloads-All-Models.html
  1. Cached
  2. Similar
To facillitate ease of locating your model, you can use the drop down menus below to navigate our current inventory of Janome service manuals. Your model ...
Sewing Machine Janome MyLock 234 Instruction Book - ManualsLib
https://www.manualslib.com > Brands > Janome Manuals > Sewing Machine > 234
  1. Cached
View and Download Janome MyLock 234 instruction book online. MyLock 234 Sewing Machine pdf manual download.
JANOME MYLOCK 203 INSTRUCTION BOOK Pdf Download.
https://www.manualslib.com > ... > Janome Manuals > Sewing Machine > MyLock 203
  1. Cached
... 203 instruction book online. MyLock 203 Sewing Machine pdf manual download. ... (88 pages). Sewing Machine Janome MyLock 213 Instruction Manual. (41 pages) ... Sewing Machine Janome MyLock 234 Instruction Book. (41 pages).
Janome 234 Manuals
  1. Cached
View online or download Janome 234 Instruction Book, Service Manual. ... We have 2 Janome 234 manuals available for free PDF download: Instruction Book, Service ... Brand: Janome ' Category: Sewing Machine ' Size: 3.36 MB ..... Janome Decor Excel 2 5024 · Janome 2200XT · JANOME MY LOCK 204D · Janome 2149 ...
manualsoncd.com/product/mylock-234-sewing-machine-service-manual/
  1. Cached
Product Description. Janome Mylock 234 Sewing Machine Service Manual. Here are just a few examples of what's included in this manual: * Feed timing.
Janome MyLock 234 overlocker service manual Google Search
Jul 12, 2017 | Janome Sewing Machines
Newhome 743D overlocker. What kind of needles does it use?
From what I can discern, Newhome was a Janome product. Perhaps these needles will work:
Janome Overlock Serger Needles 5 Needles per Pack
Is this similar to your machine? If so, then the needles above may work:
Janome Mylock744D Overlocker Serger
I found some Janome 743D manuals online but they all appear to be in the UK, or elsewhere.
Jul 30, 2015 | Sewing Machines
How do i sussecfully thread my janome 204D overlocker machine
The detail for threading could not be more clear...there is a diagram on the inside door...ensure thread is pulled tight in tension units.
Nov 11, 2011 | Janome MyLock 204D Mechanical Sewing...
Lost manual janome overlocker 204D
You can purchase the manual and other parts for this machine at http://www.sewingpartsonline.com/janome-204d-parts.aspx.
Jun 27, 2011 | Janome MyLock 204D Mechanical Sewing...
Can you please tell me how to set up my Janome 304D overlocker to roll hem?
try this solution
http://www.fixya.com/support/t9307094-cannot_get_tension_right_also_trying
not exactly your serger model but technique will be very similar for rolled hem.
You need to set up a three thread overlock with the right hand needle, (take left needle out), and change the thread finger in the throat. Sometimes a switch to do this and sometimes it is a little piece on the foot that you change with a screwdriver.
Also, this solution http://www.fixya.com/support/t9280656-thread_janome_204d_serger is basic threading on 204D, it should be very similar to your model.
I have looked for a free download instruction manual for your machine without success. But you should be able to buy one from Janome or another of the online sewing sites like www.sewusa.com or www.sewingpartsonline.com.
]ve a manual you can somtimes find them on the Janome websit
Here is a link to threading up for 334D
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/New_Home_Threading_Diagrams/New_home_334_MyLock_Threading_Diagram.htm
Jun 05, 2011 | Janome Sewing Machines
I need a manual for janome Mylock 334D please
The manual is located on the manufacturer's website, here. Click "Specifications" then "Download Manual. It is a PDF.
http://content.janome.com/index.cfm/Machines/Sergers/MyLock_634D
Mar 13, 2011 | Janome MyLock 634D Mechanical Sewing...
Hi, I have acquired a used Janome serger, My Lock 234D, but it came without a manual. I'm wondering where I can download one, thanks!
Hi
I couldn't find a manual for the MyLock 234 on the Janome site.
There is one available free to download for the MyLock 204D.
http://content.janome.com/documents/File/ManualFile/MyLock204D.pdf
I think it's only a partial manual but it should be similar enough to help you get started with the basics of threading the machine etc.
Hope this helps
Nov 07, 2010 | Janome MyLock 634D Mechanical Sewing...
Have lost my manual for mylock 204d, want another one.
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
May 10, 2010 | Janome MyLock 204D Mechanical Sewing...
Janome 4014 manual
I,m looking for a manual for a janome MyLock 204D serger could you tell me where or how you got yours please. email prbertrand@live.ca
Nov 15, 2008 | Janome 6019QC Mechanical Sewing Machine
Janome MyLock 644D Logo
263 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
