I turned off the power during system restore because noyhing happend for about 30 mins. Mycd/dvd drive does not work. I have downloaded 6 floppy disks which get me to the setup screen but I can not get beyond because the cd wont work. I have purchased an external dvd drive but that does not work either. I have all the family photos stored on the laptop if I can get access to the I will format c and start again
  • 6,826 Answers
Try it again ,but go back to a earlier point in time to restore from,and give it time ,it may take awhile.
Posted on Nov 13, 2009
I want to restore my computer to factory settings
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
Aug 02, 2011 | IBM USB Portable Diskette Floppy Drive for...
I have an acer aspire one D250 laptop and I tried to reboot and restore it. Now it lead me to a blank page that says B00TMGR is missing.press Ctrl alt del to restart. I tried to use ALT F10 and nothing...
*** Remove any external monitor as it will make entry into BIOS utility and recovery process difficult. ***
The following is from pages 29-30 of the 52-page D250 UserGuide.pdf located in folder C:\Book
I want to restore my computer to its original settings without recovery CDs.
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1. Check to see if Acer disk-to-disk recovery is enabled or not.
2. Make sure the D2D Recovery setting in Main is Enabled.
3. Exit the BIOS utility and save changes. The system will reboot.
Note: To activate the BIOS utility, press during POST (Power On Self Test).
To start the recovery process:
1. Restart the system.
2. While the Acer logo is showing, press + at the same time to enter recovery process.
3. Refer to the onscreen instructions to perform system recovery.
Important! This feature occupies 6 GB in a hidden partition on your hard disk.
Sep 30, 2010 | Acer Aspire 3050-1733 Notebook
Computer turns on, starts up ok... can hear the start up music, hard drive lightworks ok, screen goes black... after 10 mins. when this prob. started.... now it stays on (see the icons) for abt 1 min.- 30...
have you downloaded any new software? it might be the culprit if not try restoring to an earlier date when the system was working properly (like at least 4 wks ago) .. work quick since you only have 1.5 min go to start/all prog/access/systems tools/system restore...note when it shuts down it will boot up auto and you must click okay when prompt
Aug 19, 2010 | HP Pavilion dv9000z Notebook
My computer has frozen during shutdown it has never happend before.Please help !!!
this sometimes happens with operating systems.nothing to worry just press and hold down the power button of the pc for 5-6 seconds and you will see that the system will shut down completely.then just turn it on the normal way you do and it should work fine.if it is vista then it may give you a prompt to start windows normally.just hit enter on that option.
Jan 14, 2010 | Sony VAIO VGC-RA840G PC Desktop
System Restore
Depending on system restore i.e. are you restoring from a previous driver restore point or a service pack restore point, it can take 20 minutes to 2 hours.
Jan 02, 2010 | Sony VAIO Notebook
Hi i have a sony vaio LT series all in one pc, the thing is my wirless has stopped working, it happend b4 abt 6 monthes ago but used system restore to put it back to the previous settings and it sorted it...
GO to your manfacture webpage, then go to drivers download, choose your laptop model, and your operating system, and download the wirless driver, then install it, and this will fix your problem.
thanks for using Fixya
Oct 05, 2009 | Computers & Internet
My hpdv6000 recovery got stuck at 98% and showed 5 mins remaining then after 15-30 mins it moved to 99% and still showing 5mins! its been 30 mins no action seems its stuck. I started the process by going...
Hello Humanold,
Please check the following recovery steps:
Full recovery by using recovery partition:
1. Reboot the notebook PC.
2. Keep tapping F11 when the Compaq logo displays.
3. When the Recovery Manager appears, click Next.
4. When prompted to use the Microsoft System Restore program, select No and click Next.
5. When prompted to use the System Recovery, select Yes and click Next.
6. Select the option to perform the recovery without backing up files and click Next.
7. Upon completion of the process, recovery will display "The PC Recovery was successfully completed".
The recovery process will return your PC to the factory image.
Full recovery by using recovery disks:
1. Open the disc drive door and turn off the PC.
2. Insert the first Recovery disc in the disc drive and close the door.
3. Press the power button to turn on the PC.
4. The HP Recovery Manager window appears during the boot process.
If the HP Recovery Manager can access the hard drive, a prompt is displayed to backup the user files before continuing the recovery.
If the HP Recovery Manager cannot access the hard drive to fix the system errors, the HP Recovery Manager will overwrite all the data and reconfigure the entire hard drive to its original condition.
5. Follow the prompts to insert any additional recovery discs in the disc drive.
Sep 10, 2008 | HP Pavilion dv6000z Notebook
Please help
Try pressing F2 / Del key during startup. That should bring the bios setup. Now Restore that defaults & install OS on your HDD. If you are not using Floppy drive, disable the onboard floppy controller from BIOS.
Jun 20, 2008 | ASUS P4SP-MX Motherboard
DVD is stuck in Bose lifestlye 48 media player
We had a power surge during a thunderstorm that dimmed our lights, and after that the CD opened as normal.
A friend suggested that I pull the power connector, press the open/close button and hold it down as I reconnected the power connector. The power surge beat me to that, so I don't know if it works. It was more than "Tech Support" could offer however.
Mel47
Mar 11, 2008 | BOSE48 - Lifestyle 48 Home Entertainment...
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
