Question about Dual XDVD8181 Car Video Player
CAN I ADD A TV TUNER TO MY DUAL XDVD8181 HEAD UNIT
I have been looking around to see if there was a tv tuner that i can hook up or if i can even hook up a tv tuner to my head unit its a XDVD8181 Head unit by DUAL. How would i go about doing it
  • MR FIXIT08 Feb 08, 2008
    HOW DO I GET THE BRAKE BYPASS CODE SO I CAN EVEN WATCH THE DVD WHILE DRIVING, I GET THAT WARNING SIGN ACROSS THE SCREEN
  • 4 Answers
Just hook up a vhs or dvd player from home that has tv outputs, but you would need a power inverter for the power supply of the vhs, then put the vhs audio and videos outputs to the dual's input: the auxiliars. make sure the vhs has channel changing.
Posted on Mar 13, 2008
Is it possiable to hook a ipod,iphone to the DUAL XDVD 700. AND LOOK AT VIDEOS. and can you get local tv on this unit.
You can hook an ipod touch/iphone up to this provided you have an ipod video out cable and your ipod supports video out. This will allow you to connect the RCA out from ipod/iphone to RCA video in on your receiver. You will not, however, be able to browse your iOS or ipod system through your receiver. This method will only output the video to the screen of the receiver.
As for local TV, it's all a matter of where you live and if this receiver has a built in tuner. If it does, it may only have an analogue tuner which will give you 1-125 channels of fuzz since everything has gone digital now. You may get a couple of channels, but barely visible.
May 12, 2011 | Dual Electronics XDVD710 Car DVD Player
I have a dual xdvd710 would like to hook up xm radio to it what are the step to take
go to dual's web site and check under accesorys or get a fm tuner version wich will allow you to play xm/ sirus threw the fm :)
Sep 25, 2009 | Dual XDVD8181 Car Video Player
How can I watch Television on my laptop?
you may need an external TV tuner connected to your laptop, the cable signal/connection will be connected on the tv tuner.
Let me know for any clarifications
Sep 05, 2009 | Acer ASPIRE 5720-4649 Notebook
Tv tuner
Basically what I can see from what I have read one had dual tuner capability and one is set up for PCI Express. Both look like great cards.
http://www.hauppauge.com/site/products/data_hvr1600.html
http://www.hauppauge.com/site/products/data_hvr1800.html
Thanks
Armymason
Feb 24, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Weak or no signal
you would need to know if the tuner is picking up analog signals in the air well( stick a wire a little bit in the tuner connection to see if channels pick up good or use an antenna , if so there should not be a problem with the cable being hooked up to it , if there is a problem even with an antenna then the tuner is bad and will need to be replaced , and the cable could have caused it to go out , but make sure that the tuner is working or not first.
Nov 27, 2008 | Televison & Video
Dual xdvd 8180
Appreciate the direct "Ask Me".
Offhand (without actually seeing the symptom/display) and initially, I would suspect that the unit is video muting. You could try checking the antenna input.
A notable point is, to my knowledge, the TV tuner on this particular model is not built-in. It is an external/add-on device, might you have to check up on this; is it present, is it connected correctly, does it receive power, does it get control signals from the DUAL XDVD-8180.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 29, 2008 | Dual XDVD8181 Car Video Player
Sony projection tv with dual tuners; only one tuner appears to be working now.
To verify that the tuner is the problem, move the cable from the second to the first. If you don't get a signal, the tuner is bad. The main tuner is part number 859843000 and is available for $47.38 from tritronicsinc.com
Dan
Oct 07, 2008 | Sony KP-51HW40 51" Rear Projection...
Screen just went black
Think your set tuner is bogus. The other tuner that you used should work, but if it is not a cable tuner configured to your system it will not work either via the rf outputs or the audio video outputs. If that cable box works with another set then you have a real head scratcher on your hands.
Mar 24, 2017 | Sanyo AVM-2756 27" TV
Hook up
Purchased a rf modulator and hooked in to the tuner out to modulator and from modulator to tv that made everything work
Apr 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Dual xdvd710
If you can find a separate tv tuner with remote the run it through the unit rear input. But stand alone tuner is rare if it even exist. Search Ebay to see if you can find one. There is another way by hook up a small portable tv with video/audio output and use an adapter from RadioShack to send the signal to rear input of the unit, but picture and sound quality is only as good as the reception of the tv. Goodluck.
Feb 10, 2008 | Dual XDVD8181 Car Video Player
Dual XDVD8181 Car Video Player Logo
211 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
