Question about Ovens
Old gaffer and sattler ovens thermostat
Need new thermostats for dual ovens built in top is broiler and oven bottom is just oven. Can not find model # but have access to thermostats if I remove cover
2 Suggested Answers
  • 20 Answers
SOURCE: gaffer and sattlers built in oven, probably 1981,
cold be oven thermostat or elements faulty.
Richadr Saupe
appliance repairman Colchester
Posted on Mar 14, 2010
our 1985 gaffers and sattlers oven would not turn off tonight. Any idea? Its Propane oven
Posted on Nov 22, 2010
0 characters
1 Points
How do I turn off the timer on my gaffers & sattler wall oven?
Try rebooting the oven; unplug it for 90 seconds, or flip the circuit breaker off for 90 seconds, then back on.
Apr 17, 2016 | Ovens
My top broiler won't turn on. Everything else works fine. I have exchanged the top broiler element with the bottom. So I know it isn't the element.
Could be wiring. Did it work before? Maybe, never connected? Could be demand of two oven's and or broilers at the same time exceeded the wire and circuit breaker capacity when installed and therefore were never connected.
Otherwise thermostat. Probably need appliance Tec or Electrician.
Mar 04, 2015 | GE JTP27 Electric Double Oven
I have a 1965 gaffers & sattler wall oven with the oven on the top and the broiler on the bottom. It began having issues lighting even though the pilot light was on. Now the burner doesn't light up at...
My Mom has a 1965 Gaffler & Stattler Mark 21 wall mount oven, it had the "Same Problem", People may tell you that the flame switch is no longer avalible but I found a universal fit flame switch at Applance Parts Center, I took the old part in and had it matched up, with a minor modification to the thermal sensor mounting bracket, "drilling a larger hole and lightly crimping it", it's a perfect fit, "problem solved". You may want to try cleaning the pilot light area with a small wire brush first, if that dosn't work try a jumper wire on the two terminals of the flame switch, if that works then replace the flame switch.
This operation can be done without removing the oven from the wall mount, just remove the two screws from the panel at the inside rear of the broiler, you will find the flame switch behind the panel it has two screws two wires a thermo leed and a sensor tip that goes up to the thermo sensor mounting bracket above the pilot light, the thermo sensor mounting bracket has one screw and a nut behind it, you will also need to remove one end of the 1/4" pilot gas pipe in order to remove the thermo sensor mounting bracket, When your done puting it back togather, check for gas leaks using soapy water in a spray bottle, a dish soap solution works great, also check your vent pipe connections.
After I cleaned the dust and grease out of this old thing, the 45 year old clock and timer started working again.
My Mom is very happy, try and find new oven to fit the cutout and vent, we saved a lot of $$$,
"Good Luck".
Nov 18, 2010 | Ovens
Repair or buy new oven.
replace the element....they are not that expensive.
Jul 20, 2010 | Ovens
Dec 22, 2009 | Ovens
Whrilpool GR450LXHB2- The stovetop works, but the
It won't bake or broilIf neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring.
If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
It won't broil Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 25, 2009 | Ovens
Oven staying hot a long time after it was turned off
Thanks for your reply. I contacted an appliance repair person I have used before and he told me about turning off the breaker, which I did. He suggested using an oven thermostat to see if it was heating to the correct temperature as a first step. It may be the thermostat, I do not know what the controller is as presented by one of the responders. At any rate I learned that my breaker for the oven is by itself and is not attached to the stovetop which is good. I will have to weigh the cost of replacing a part on a 20 year old builder quality oven with microwave on top to a new one. Any ideas on a new problem free model are appreciated!!
Feb 12, 2008 | Ovens
Ovens Logo
301 people viewed this question
Top Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you an Oven Expert? Answer questions, earn points and help others
