Question about Desa International Remington 12" Electric Chain Saw Unassembled 1.5 Pe
Does it run on 30 weight oil or a mixture of gas and oil?
    President:
  • 2,220 Answers
It is an electric chainsaw, you need bar oil. Your manual says use 30 weight non-detergent. That is what bar oil is, with a few additives to help keep it on the bar and chain. It can be purchased at home centers and hardware stores and is less expensive than most motor oils. HTH
Lou
Posted on Nov 13, 2009
  • 486 Answers
2 cycle engine oil to mix with gasoline 50:1 , 40:1, or 32:1 ration
It normally comes in a 3oz, 6oz, or 12 oz bottle, and it will tell you how much oil to add to a gallon of gasoline. 32:1 if you are unsure.
Bar and chain oil is seperate in a seperate tank. Best to use bar oil.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
What is the ratio of gas to oil for a 35cc engine
Mix 3.2 ounces of Poulan 2-cycle air cooled engine oil to one gallon of fresh unleaded gasoline to obtain the recommended 40:1 fuel to oil ratio.
Over a period of time oil will separate from gasoline. To properly insure oil and gas mixture, I recommend thoroughly shaking your oil and gas mixture before refueling your unit.
If the saw is to be stored for longer than 30 days - drain the fuel tank, re-tighten the gas cap, and start the unit and let it run until it stops.
Jun 09, 2014 | Poulan Predator 35cc P3516pr Chainsaw...
2 or 4 cycle oil for a Ranch King 6.0 lawn mower? What kind or type of oil should use?
If you mean oil for the crankcase use need 4 cycle oil Ususally 30 weight and don't over fill Most small engine do not even take a quart only about 20 oz.
If you mean to mix with gas ( I doubt this) but then you need 2 cycle oil depending on the mixture usually about 3 oz to a gallon of gas (3.2 oz / gal = 40:1 ratio, 2.5 oz/ =50:1)
May 24, 2011 | Briggs & Stratton Garden
I cannot remember the type of gas or the fuel mixture (gas to oil ratio if required) for my pw2050 2000psi pressure washer,last used 2006 cannot locate the manual,
Pump regular gas and no oil mix. Your engine has a dipstick which means its a four stroke engine.
The oil goes inside the motor. For summer use I recommend 30 weight non-detergent oil.
Change it out once a season *(Beginning would be preferred). Drain the gas out at the end of the season.
Hope this helps!
Feb 23, 2011 | Campbell Hausfeld PW2102 Gas Pressure...
Does a Ryobi trimmer S430 not use a fuel mixture?
the Ryobi S430 is a 4 cycle engine. As such it has an oil reservoir which takes 30 weight oil. It uses straight gasoline in the gas tank.
Sep 03, 2010 | Ryobi Garden
Gas to oil mixture for Model # RY 28020
Use 2-Cycle Oil For Mixture of 50:1. They come in 2.6 oz bottles and larger. Use 2.6oz (one small bottle) per 1 gallon of 89 unleaded gasoline. I use and this and it runs like a charm. You can get from HomeDepot or other hardware stores.
Jun 18, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
What weight oil do I use. New compressor not used
30 weight non detergent. Sears has this oil on the shelf or you can get the same at any auto parts place.
Non detergent is the key.
Refer to your owners manual for further information
Thank you for your service.
Oct 12, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Desa International Remington 12" Electric Chain Saw Unassembled 1.5 Pe Logo
85 people viewed this question
Top Desa International Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Desa International Garden Expert? Answer questions, earn points and help others
