Question about Cell Phones
My phone 3110c was security lock i lose my number
My phone 3110c was security lock i lose my security number what i do?
I am using Nokia 3110C. My phone has been locked, i forget security code, i can't access my phone.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jan 27, 2013 | Nokia 3110c Classic Unlocked Original...
PLEASE HELP ME Nokia 3110C master code i have a nokia 3110c but i forgot its security code. its security level is put to phone so i cannot use it with any sim card except the one i set the security code...
Hi i have checked your imei number and your phone is not stolen so i can give you the master unlock code, how ever this code wont work if you have entered the code wrong more than 5 times if you have done this then your phone is hard locked and will need taking to a phone shop to be unlocked.
your master code is 4410260430
let me know how you get on or if you need further assistance ok
Apr 25, 2010 | Nokia 3110 Cellular Phone
I put a Security Code on my Nokia 3110c and can't unlock it!
http://nfader.su/index.php Give your imei number there. If you don't have your imei number call *#06# from your mobile.
Feb 17, 2010 | Nokia 3110 Cellular Phone
Locked 3110c
Master reset code is 1140246131
Rate this fixya!
Sep 29, 2009 | Nokia 3110 Cellular Phone
I forget my security code nokia 3110c
Instead enter lock code. If you have not changed the lock code then the defaults is in the manual.
Aug 27, 2009 | Nokia 3110 Cellular Phone
Unlock security code in my 3110c cell phone
your master security code will be 1301572625
key this number in and change your security password immediatly.
use this code to change your security code
Mar 15, 2009 | Nokia 3110 Cellular Phone
Unlock security code for nokia3110c
Hi sir, i have nokia 3110c and i have forgot the security code which i had changed from default i.e 12345..and the new security code i had forgot...please help me out to unlock mine phone as if i have mine important contact numbers and data in dat phone pls help me out for this...
Jul 09, 2008 | Nokia 3110 Cellular Phone
Resetting Security Code
357593006548708.........for this phone try resetting the phone or formatting by entring *#7870# for resetting and *#7370# for formatting in any of the case you should have your original number which is 12345 as the new code after resetting of formating but for formtting you would lose every contacts so you are advice to keep a copy of every important dorcument.
for nokia 5300 also try resetting or formatting to restore the usual pin code "12345" and to do this first copy all contacts and information need first even is restting it(which you do not lose any information) ........... to reset enter *#7870# and to formate enter *#7370# please try the first method before proceeding to the second one.
for nokia 3110c please this is your master code   6003104322
May 19, 2008 | Cell Phones
Nokia 3110c mobile, i forgot security code.now how to reset security code?
Hi, I will be able to get you the master code to turn off the security code and reset to what it was when it was new (0000) it will remove the security code and won't ask for the code.
The code will only work if it is asking for the security code when you switch the phone on.
The code won't work if the wrong code has been entered more than 5 times, if it has the phone is hard locked and can only be unlocked using flashlead and unlocking software. Shops will not do this anymore as it is illegal!! You might be able to buy the software of the net.
If the phone is not hard locked i will be able to give you the master code that will reset the security code giving you access to your phone.
I will need your IMEI number, which is on the back of the phone under the battery and looks like 123456/12/123456/1 it is 15 digits long.
I will need this information as every phone has a different master code based on the IMEI number.
Let me know and i will be able to assist you further.
Apr 28, 2008 | Nokia 3110 Cellular Phone
Cell Phones Logo
63 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
