Question about Craftsman Garden
No gas when you prime it
No gas in bubble primer when you prime it
  • 486 Answers
1) Check fuel lines from tank for cracks, fuel filter in tank, primer bulb for cracks
2)Remove Carburetor
replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 13, 2009
Craftsman 550
Priming may not be the problem. First try putting some duct tape over the hole in the primer button. then try priming and subsequently starting it. This could indicate a need for a new air filter...I know it doesn't make sense, but it will probably be the answer to your problem. It was with mine although a different type of mower.
Jul 21, 2014 | Mtd 22" Yard Machine Push Mower
Why no gas going into primer bulb
There is a hole some where check prime bubble
May 14, 2014 | Echo Hedge Trimmer Throttle Cable...
Engine on 30"Craftsman 2009 snow thrower won't prime. Primer button and connecting tube look good. Primer button won't send gas to the carb.
the priming bubble can look totally perfect, but all it takes is a pin hole and right around the retaining ring is hard to spot a crack and you should also check fuel lines in tank
Jan 07, 2013 | managemylife.com
I have a 124l e-tech trimmer and the prime bubble wont fill
Sounds like you have an air leak. Either in the primer bulb is split or punctured, hole or leaking fuel line or primer bulb base, and is sucking air instead of fuel.
Aug 20, 2012 | Husqvarna 124L 28cc Gas Line Grass Lawn...
I have a honda FG-100 It has a new carb on it but the primer bulb will not prime. blows bubbles back in the take but wont **** gas.
This happens all the time. The hoses leading to the primer bulb are on backwards.
Switch them and you'll be fine
Mike
May 16, 2010 | Honda 25cc 4-cycle Mini Tiller
Is there a gasket under the primer bubble;it won't **** up gas
the pick up tube in the fuel tank is probably bad
Sep 16, 2009 | Garden
Primer bulb won't prime
it sounds like the filter on the fule line is cloged try to remove the filter and then try to prime the trimmer. it it does you need to replace the filter. just about any filter that will fit will do.
Jun 05, 2009 | Troy Bilt Tb70ss Gas Trimmer
Priming fuel system on a 8.1L diesel engine 2001chev 1 ton dual
Well, one problem is, if its an 8.1, its not a diesel. The 8.1, or Vortec 8100, is a gas engine. The DuraMax is a 6.6 engine. There is usually not a priming system on a gas engine, because the fuel pumps will usually get it through the smaller filters used quick enough you dont need them. However, if it is a DuraMax engine, then right on top of the fitting where you mount your diesel filter, there is a primer pump and an air bleed valve. What you do is, open up that air bleed valve ( its a little black plastic octagon shaped thing on the top of the filter mount) then you pump the primer (the silver button looking thing) until you get diesel squiting out the air vent without too many air bubbles or gurgles.
Jan 17, 2009 | 2001 Chevrolet Silverado 2500HD
Garden Logo
517 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
