Question about Kenmore Washing Machines
Kenmore Washer 417.44052400 (Front Loader). Won?t spins during any cycle. It fills, drains, fills again and drains again ?a complete cycle. I do hear the motor running during. Yet no spin at all. Thus leaves the clothes wet.
  • rdaryani Nov 16, 2009
    Hey Guru, Thank you for your advise.
    Now I do need more info from you. After visual inspection of the back, I noticed that not only a belt was down (partly broken) but the vibrations shocks were broken too - some major failure.
    Questions: What else should I look for in terms of replacing parts? Should I consider purchasing a new one after this kind of damage. Note that this unit is about 4 years old and the new one will cost me about $500-$550.
    Thank you. I look forward to hearing from you. Ramesh
  • 6,784 Answers
HI. Ok, just to make sure this is not a simple control fault, I would advise to unplug the unit for five minutes. This will force a core reset. Both control modules will be forced to reset. Once the five minutes have passed, simply plug in the unit, and try to initiate a wash cycle once again. If the same errors continue to present a problem, and the spin cycle is not operating correctly, this will rule out a this particular fault. Move on to the belt inspection.
To inspect the belt, simply remove the rear panel. Twelve screws secure the back panel to the washer. Remove the 12 screws and remove the back panel. Once the belt and pulley are exposed, check the tension of the belt physically. If there is excessive play, this will be the reason for the no spin. the belt is stretched. If the belt is tight, and the structure of the belt is sound, The belt is not the issue.
Now. If all is well with the belt, this will lead to a failed Motor Control Board. This module controls the spin functions during the selected cycle. This will be the culprit. once this damaged device is replaced, the unit will spin properly.
Motor Control Board Part Number Is # 134409900
Posted on Nov 13, 2009
  • Michael Masters
    Michael Masters Nov 13, 2009
    Belt Part number #134051001(if needed)
  • Michael Masters
    Michael Masters Nov 16, 2009
    OK, I would consider repairing your unit at this time. these repairs will not exceed the cost of a new unit. Purchasing a new unit would be more expensive than actually repairing your existing unit. The total parts cost for these damaged parts will be $46.15, plus the sales tax. This will include the Shock absorber kit, and belt, as well. All instructions will be shipped along with both parts to help assist with the installation.
    My recommendation is to repair this unit. It is still very young, and the control boards are still operating properly. There is no need to purchase a new unit at this time, in my opinion. The actual service call for these repair are considered to be minor, and will not exceed the price of a new unit, also. The service call will cost just over $295.00. This is way below the asking price for a newer unit. If you are considering a Do It Yourself, I will post the necessary links below to direct you to the replacement parts needed. Remember, if you order from the site i will direct you to , All installation diagrams, and full scale instructions, will be shipped along with both parts. Simply click on the links below to be directed to the purchase pages.
    Replacement Belt(CLICK HERE)
    Replacement Shock Absorber Kit(CLICK HERE)
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Washer works on every setting but does not spin on spin cycle
IF ITS A TOP LOADER ITS POSSABLE YOU HAVE A BAD CLUTCH IT A FRONT LOADER YOU MAYBE USING TOO MUCH SOAP
Jan 12, 2010 | Kenmore Washing Machines
Will not drain or fill
just hit it with a hammer. thats what worked for my flat screen tv.
Sep 11, 2009 | Kenmore 43142 Front Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Kenmore front loader washer model 11042822201 won't drain and spin
As I have not received a response, I'm assuming these hints have taken care of your problem. If you have any more troubles, feel free to drop me a note back.
Jun 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 44832200 banging during spin cycle
The support spring beside the spinning hausing are cut replace w/new spring available appliances store. bring sample.
Jan 07, 2008 | Kenmore 44832 Front Load Washer
Washer will not Spin during SPIN CYCLES
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. (consult your manual to know where/how filter is cleaned). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 29, 2007 | Washing Machines
Washing Machines Logo
107 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
