Question about Samsung L83T Digital Camera
My samsung promising photographer L83T won't turn on, it's fully charged and i have replaced the battery. It worked fine after i replaced the battery but when i recharged it it now wont turn on or do anything. The shutter is open (if that makes a difference to the solution?) please can you tell me what I can do to make it turn on or fix it? thanks.
  • 561 Answers
Suspect that the battery may have been incorrectly charged and may be damaged.
suspect charger is not charging the battery properly.
try any reset that that camera may have.
Posted on Nov 13, 2009
Won`t turn on
Did you install the battery the correct way? The orange square on the battery indicates it goes perpendicular to the orange battery tab. Is the battery fully charged? If you place the battery facing the other way where the orange box is to the right of the orange tab then the battery won't lock in place naturally.
Feb 04, 2014 | Fujifilm FinePix HS50EXR Digital Camera...
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
I have samsung l83t camera,when i turn it on,he turns of after 5 secs.what to do?
battery fault most likely, charge it or try a new one. Memory cards issues can cause this sometimes so remove it and try, again.
Jan 08, 2012 | Samsung L83T Digital Camera
I have fully charged the battery. Sometimes I can turn camera on and lense operates but no vision on screen and not able to take a photograph. but other times the lense will immediately retract. If lense...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
Jan 14, 2011 | Pentax Optio SV Digital Camera
Black screen no image showing
black screen blur image showing cannot see subject to be photographed when camera power on,if press to take photo nothing shows, just black screen. it was fine one minute then nothing the next. battery is fully charged, memory card ok.
May 24, 2010 | Olympus FE-230 Digital Camera
I have camera samsung L83T it wont charge what happens is when i plug in socket green light comes on on charger then red ligth flashes a couple of timers then goes off any answers thanks
Hello :
It seems that the battery is dead [ can't be recharged anymore ] . Just replace it and problem will be solved .
good luck .
please rate !
Apr 02, 2010 | Samsung L83T Digital Camera
I can't download pics from Samsung L83T to 'My Pictures' Windows 7
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
Jan 23, 2010 | Samsung L83T Digital Camera
Charging battery for a samsung digital camera L83t
Here is the user's manual, drivers, picture for the Samsung L83T digital camera. http://www.samsungcamera.com/customer/download/cus_down_main.asp?key=l83t
May 03, 2008 | Cameras
Samsung L83t will not turn on! Fully charged but wont turn on.
mine was the same.i noticed the lens shutter was not opening so i opened it with my fingers and its fine now . i hope this solves it
Apr 18, 2008 | Cameras
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Samsung L83T Digital Camera Logo
178 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
